13583 posts / 0 new
Random Dan
Last seen: 1 day 4 hours ago
nvanlaar wrote:
ToyKeeper wrote:
Also, I hope this answers some questions:
I don’t think these don’t look like the same bodies/tubes… where did the first image come from?
Perhaps since Lumintop only intended to test anodizing, they didn’t bother cutting actual threads? That’s why the tubes look different and why the parts couldn’t be threaded together.
chadvone
chadvone's picture
Last seen: 4 days 12 hours ago
Great, what version has been fixed? I am not sure it would be worth flashing again, Its not really an issue for me. I think it could be a handy feature.
CRX
CRX's picture
Last seen: 3 hours 35 min ago
CRX wrote:
All is revealed Thumbs Up
(Or maybe not.. )
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 14 min ago
It’s probably not worth reflashing unless there are specific changes you care about. The event system rewrite has virtually no user-visible changes. Mostly, it just … doesn’t hang any more, and the lockout mode’s momentary moon now lights up on every press instead of just the first three.
Other recent changes include:
  • Fancier “blinking” mode for aux LEDs. Instead of being on high for 0.5s every 4s, it makes more of a clock tick or slow heartbeat pattern. (..oOo……o……oOo……o……oOo……o….. repeating)
  • Moved off mode’s aux LED config to “7 clicks from off” instead of hiding it inside lockout mode.
  • Added a moon timing hint, to help people time the button release correctly to stay at moon from off.
  • Added support for some new lights.
  • Fixed a stepped ramping corner case when two steps were exactly 128 levels apart.
  • Fixed a small thermal behavior corner case.
  • Broke and fixed sunset mode.
  • Added more documentation.
  • Source code and build system improvements which don’t affect functionality.
Most of this makes little or no difference to the user interface.
Looking forward, most of the stuff which needs to happen is just hardware support… but more visible changes could happen too:
  • Tint ramping (on the lantern, and any other dual-tint lights).
  • Factory reset function.
  • Make the ramp auto-reverse in more modes, not just the main ramps.
  • Rewrite the thermal regulation… again.
  • Improve interaction between LVP and aux LEDs.
  • Configurable timer for sunset mode.
  • Possibly make strobe duty cycle configurable, or add a randomized strobe.
  • Maybe other new stuff, depending on what new features appear in new hardware.
nvanlaar
nvanlaar's picture
Last seen: 4 hours 31 min ago
This sounds plausible.
“Facts don’t care about your feelings.”
~Ben Shapiro
cabfrank
Last seen: 2 hours 30 min ago
TK, really amazing.
M4D M4X
M4D M4X's picture
Last seen: 3 hours 54 min ago
cabfrank wrote:
TK, really amazing.
she indeed is!
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
ToyKeeper
ToyKeeper's picture
More progress on grey anodizing… I think this was the second attempt to get a nice dark grey color:
About the parts not being together, Neal tells me: “not the production item, they will cut some screws before assemble”.
So the theory seems to be correct. It looks weird because the threads aren’t there. If I understand correctly, the ano factory took these pictures. And since the threads are cut after anodizing (so they can carry current), it wouldn’t be possible to put things completely together at this stage.
Firelight2
Firelight2's picture
Last seen: 1 hour 7 min ago
Thank you for clarifying that TK.
Also, that looks great! Love the dark grey ano! Thumbs Up
Agro
Agro's picture
Last seen: 3 hours 47 min ago
djozz wrote:
Quote:
Also, I believe that Emisar D4 tests have shown that FET was not as inefficient as people predicted
A led driven to the max is inefficient for two causes: high current and high heat. A FET driver at PWMed lower modes has one cause (heat) removed so the led during the pulses runs at higher output than if at max continuously.
It really works like that. Example: I made a 18650 zoomie with a Osram KW CSLNM1-TG and FET+1 driver. If I use a high current cell it is overdriven at max resulting in angry blue light. But at slightly lower setting (so still high in the FET region of regulation) the led colour is normal. The led still receives the same current (but pulsed) so the difference I presume is caused by less heat.
OK, I found that:
http://budgetlightforum.com/comment/1168928#comment-1168928
ToyKeeper wrote:
djozz wrote:
the PWM is so fast that the peaks do not end up fully at 3A, this could be checked on a scope
IIRC, maukka scoped this on the D4 a few pages ago and found that theory to be true. The pulses have a slow enough rise and fall time to act as a very weak lowpass filter, so short pulses never reach full height. (edit: scoped output, but that works because the LED activation time is much faster than the FET driving it)
Still…is it caused by FET model? Battery chemistry? Something in the circuit?
ToyKeeper
ToyKeeper's picture
I think it may be caused by a small resistor in the circuit which is specifically designed to take the edge off each FET pulse. This was done to prevent excess voltage spikes and electrical noise within the driver, but it also seems to have the effect of increasing FET efficiency slightly.
teacher
teacher's picture
Last seen: 9 months 3 weeks ago
Thank you TK for the info & the picture…. that is looking good!! Thumbs Up
ludolf
Last seen: 5 days 8 hours ago
Please add me to the list. One piece with LH351D emitter.
Thanks.
pinkpanda3310
pinkpanda3310's picture
Last seen: 16 hours 6 min ago
Aah, that makes sense.
I’m not really fazed about the colour. So long as it insulates the sleeve where it’s supposed to. The pictured light must be proto 3 ?
I’m very happy that we’re getting some communication now.
teacher
teacher's picture
pinkpanda3310 wrote:
(snip)
Amen!! Thumbs Up
Thank you TK for picking up the communication sharing roll on this ‘Group Buy’!!
I can only imagine how difficult that has been for you since you were virtually receiving no information to share with us until recently.
Your efforts are noted & appreciated.
For without your efforts I imagine most of us mortals would be completely ‘in the dark’ concerning the FW3A.
Tjohn
Tjohn's picture
ToyKeeper wrote:
More progress on grey anodizing… I think this was the second attempt to get a nice dark grey color….
Hopefully there is a cold blue steel tone to the original, similar to what is seen on my old Nokia 830 dumb phone.
If so, would some call it ‘gun metal’ ?
JasonWW
JasonWW's picture
Last seen: 54 min 32 sec ago
Did they mention whether the dark lines/overlap are now gone or perhaps hidden? If so, I’d call it a successfull compromise and move forward.
Jerommel
Jerommel's picture
Last seen: 5 days 14 hours ago
Well, it’s still a nice looker, despite it not being clear or light grey dyed.
DB Custom
DB Custom's picture
Last seen: 2 days 9 hours ago
Right you are Jerommel, it IS a nice looking light, just not the light we signed up for in the beginning.
nottawhackjob
Last seen: 23 hours 53 min ago
IMO other than the electronic switch I honestly don’t see watt all the hoopla is about this flash vs watts already out there.
Outwardly IMO it’s an average design with essentially a TI patina. Ok. Woo hoo.
Now if it had a rotary mechanical sideswitch dimmer that was hidden behind a sliding cover that could give me some “hardness”. Or if heads with different led configurations were swappable by just unscrewing then yeah definely woo hoo. Basically a glorified P60. Or magnetic charging, woo hoo.
For this amount of effort and angst I almost expect Bluetooth, a wireless remote, and a camera. Oh, and of course a talking free battery. LOL
Ya know watt? I guess I’m prolly unenLIGHTened.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
chadvone
chadvone's picture
Yeah, its a big deal to me.
nottawhackjob
Ok I can see that. For me though I’m just kinda too old KISS fashioned on certain things.
To wit, a good precise uber reliable momentary switch (forward clicky) IS my electronic switch. LOL
Man, I’m dating myself. Wait that doesn’t sound right. Shocked
DB Custom
DB Custom's picture
What a wonderful offer tatasal! I can’t accept it though, you hold onto that beauty and enjoy it please.
PM sent….
cabfrank
Nottawhackjob, the size and the firmware are elite for an edc. That is what does it for me. I suppose you are correct in that it is not a giant leap ahead, because of the Emisar, which is similar in some ways. I like them both, but have been holding off, waiting for this one.
SKV89
Last seen: 48 min 36 sec ago
CRX wrote:
Well, instead of waiting around or moaning about the FW3A’s production  I had to get creative and make my own version ;)
The more I look at this the nicer this looks. I like the quad better than triple. Perhaps Lumintop should make a FW4A since there isn’t a rear clicky quad in existence and it will be more efficient. Perhaps use 21700 batteries instead of 18650.
cabfrank
That would be great, after this one.
nvanlaar
nvanlaar's picture
+1 Thumbs Up
~Ben Shapiro
hank
hank's picture
Last seen: 28 min 39 sec ago
It’s alive …. and twitching!
I want one.
CRX
CRX's picture
Thanks mate, now there is a copper version Wink
Yes, lets not distract them Big Smile
teacher
teacher's picture
+1 . Wink
