13576 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 9 min ago
FWIW, the Viltrox L116T is a nice high-CRI light panel which can be powered by a wall adapter and mounted on a gooseneck thingy or tripod. It adjusts from 3300K to 5600K in 100K increments, and stays below the BBL the entire time.
Can also be battery powered, but I don’t use it that way.
Illumenated
Last seen: 1 month 2 days ago
I’m already on the list but should I clarify which emitter now that there’s two choices?
If so I’d like one of the LH351D 4000K 90CRI please.
Patiently excited!!
caplang
Last seen: 3 months 4 weeks ago
I’m also already on the list and would like to have one of each emitter.
Xavier Blak
Last seen: 1 week 4 days ago
This looks nice. Put me down for 1 please.
joechina
Last seen: 13 hours 17 min ago
Here is a built video of a bench / desk lamp with a Viltrox
JasonWW
JasonWW's picture
Last seen: 20 min 38 sec ago
joechina wrote:
Here is a built video of a bench / desk lamp with a Viltrox.
Ah, I saw that when it came out. I could definitely use a light like that for soldering and making videos.
Click this to go to signature links.
duvallite
Last seen: 8 months 3 weeks ago
I’m in for one. Please add me to the list.
Agro
Agro's picture
Last seen: 3 min 13 sec ago
JasonWW wrote:
Not everyone is aware that there used to be some flashlights controlled by Bluetooth a few years back. You could remotely turn the light on and off, adjust the brightness, change the settings such as strobe rate, the number of brightness levels, have “dico” mode, etc… It seems pretty cool, but the one light that I’m thinking of didn’t actually sell very well because the flashlight itself was not very good. Then you have the problem of the company needing to keep the app updated. Eventually you’ll lose the ability to control the light through the Bluetooth and then you’re stuck with a really expensive regular flashlight. Even in 2019, I’m not sure there is a market for Bluetooth controlled flashlights.
I believe the solution is standardization. If there’s common BT API that’s used by many different lights and any app can control any light – the problems with manufacturer stopping updates is gone.
Now…maybe there is such standard already, just designed for a different class of lights? Smart light bulbs for example?
JasonWW
JasonWW's picture
Standardization such as all flashlights use one UI? Not likely to happen.
Agro
Agro's picture
No. No one UI. Use one way to talk with Bluetooth controllers, so any compatible controller knows how to turn on any compatible light. Or how to dim it down etc. The light can have any UI. So can the controller.
And not all of them – just enough to not have to fear about the standard dying out.
ToyKeeper
ToyKeeper's picture
If you want a standardized bluetooth interface which isn’t likely to die out, about the only way that can happen is to make an open-source driver with open-source firmware, get a couple brands to use it, and find someone willing to keep companion apps updated on several platforms. It might be doable within a year or two if someone was motivated enough to do it.
For now though, I’m mostly just trying to get companies on board with the idea of working with the community, and building a common firmware platform which supports a variety of hardware and a variety of user interfaces. Basically, trying to make it possible to do with flashlights what we do with computers — let the users mix and match hardware and software as desired.
chadvone
chadvone's picture
Last seen: 2 days 10 hours ago
Nothing to say about Bluetooth.
How’s the FW3A ?
I have started ordering extras
DunchBlaster
Last seen: 3 days 13 hours ago
Can I be added to the list for 1 with the LH351D emitters please?
Kuato
Kuato's picture
Last seen: 1 month 1 week ago
Absolutely interested. Two, please. (One of each emitter) Big Smile
DavidEF
DavidEF's picture
Last seen: 8 hours 21 min ago
Well, Flashy Mike used a self-written Bluetooth App for his 2018 scratch build contest lantern.
- The YKK Philosophy
zxgeoff
Can I be added to the list for an Hi CRI version
Ty Geoff
ToyKeeper
ToyKeeper's picture
That’s really cool. A working prototype is a big step forward. There’s still a lot more to the process for making a widely-used standard, though. With the code and schematics and stuff, and some motivated people, we could probably find ways to fit it into smaller hosts and extend the functionality and get it into lights by multiple companies.
Something I’d personally love to see is a USB-capable or bluetooth-capable bootloader which can be used to flash firmware over a fast and universal connection. This would enable all sorts of fun things.
For a little while, I toyed with the idea of flashing over the “optic nerve”, but it would take a couple hours and the link only goes one direction, so it wouldn’t be able to correct errors. Very inconvenient and risky. Bluetooth or USB would be a lot faster and safer.
M4D M4X
M4D M4X's picture
Last seen: 2 min 32 sec ago
Manker once told me that Nextorch has some kind of patent on the "programming via USB" thing
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
DavidEF
DavidEF's picture
Yes, it isn’t the end, but I think it’s a good beginning. With, as you said before, some open source hardware and firmware, it could grow bigger, faster. What do you mean about the bootloader? Are you talking about a bootloader in the flashlight?
hank
hank's picture
Last seen: 3 hours 6 min ago
Tom Tom
Last seen: 9 months 4 weeks ago
It’s early days yet. Pogo pin connections are a start, allowing a “bare metal” re-flash.
Putting a bootloader into the MCU, whilst obviously possible, would just be a waste of space and resources, of no utility to the vast majority of consumers who would never use it, nor want it, nor even know how. And adding cost. Nevermind the complication of adding USB or Bluetooth connectivity.
These are just torches. They should not be over-complicated, just because it is possible.
Easily turned on and off-able is my test, combined with handing them to “muggles” to see how they manage.
Even I need crib sheets to understand some none-intuitive BLF stuff, I cannot retain all of it in memory, and no, my brain is still pretty sharp. It may make perfect sense to the designers, but, practically, a lot of it is unused/unusable. I like to play around with new things like all of us, but after a while determine a configuration that suits me, and never change it afterwards.
Configurability, and personal choice is great, but is it actually necessary, or worthwhile, in such a simple basic device as a torch ?
Frankly I think that some of the people developing code might contribute to the greater good better, if they applied their talents instead to e.g. 3D printing, CNC control, and other such useful stuff.
As for the hardware designers, ploughing the same old furrows, no real innovation, well, if it still works for them and their customers, so be it. The clever ones are probably too busy in their day jobs to be distracted with trivial things such as torch drivers.
I think that I have reached “peak torch”, and don’t have a use, or a want, never-mind a need, for much more.
hank
hank's picture
well, consider how far we’ve come from the days when all the “budget” flashlights came with “next mode memory”
Imagine a world in which the manufacturers had stayed with that kind of flashlight .
Tom Tom
You can get plenty of head-torches where you just have to wave your hand in front.
Thought control ? well that might be coming.
So little innovation actually happening here.
E.G. an “Ultimate” lantern that doesn’t even have a PIR motion detector to turn it on. And off.
Never-mind any sort of remote control. Bluetooth, WiFi, even just a dedicated keyfob.
Even my Poundland selfie stick came with a bluetooth remote button that works. Coin cell included. For £1.00
Meanwhile the discussion there still seems to be all about USB C vs. micro.
And how the battery-bank output is so difficult. Again, I can go to Poundland and buy one there, that even includes a poor 18650, for £1.00, and works very well. Boosts up my ‘phone nicely, when required.
Basic stuff.
Rxich
Last seen: 4 days 6 hours ago
EDDDDDITTTT-
I’ll take one of each, XPL-HI & Samsung emitter,
that is whenever it is done
Johm
Last seen: 2 hours 14 min ago
Please put me down for 1 light with Samsung emitters.
This is a sweet looking light, thank you guys for doing this.
Agro
Agro's picture
Remote control of lights is useful. And once you get BT you enter security nightmare. Firmware upgrade is a necessary but deeply insufficient band aid.
Boaz
Boaz's picture
Last seen: 17 hours 44 min ago
bushmaster wrote:
Well......fine then. There must be some kind of .............. No, there isn't.............there's nothing you can't do with your phone, is there? I stand corrected. :TIRED:
Oh yes there is one thing people can't do and that's get off the damn thing .
       Get off your phone  !!!
Catnap
Catnap's picture
Last seen: 14 hours 30 min ago
Interested in one with LH351D
ToyKeeper
ToyKeeper's picture
If it counts, most of my “real” work is about making information infrastructure — making the plumbing which lets computers and the internet work, developing operating systems and other stuff people rely on but don’t think much about. Last I checked, my code is used on at least a sixth of the internet.
I generally try to keep all that away from my hobby time though. Flashlights are a nice break from work, a way to relax.
teacher
teacher's picture
Wow, “at least a sixth of the internet”!! Shocked . Shocked
As an average mere mortal, I am honestly seriously impressed!!
I had no idea TK…. much respect for your work besides the flashlight hobby!! Thumbs Up
