13576 posts / 0 new
raccoon city
raccoon city's picture
Last seen: 36 min 49 sec ago
teacher wrote:
So, in summary; there are plenty of flat top batteries that will fit the FW3A even ‘if’ no button tops fit at all. Beer
Now I don't feel so bad about buying flat top 18650 cells!  ;)
I wanted button tops, but couldn't find any for the cells I wanted.
KawiBoy1428
KawiBoy1428's picture
Last seen: 10 hours 3 min ago
teacher wrote:
From my highly non-technical & less than scientific research Hat , my predictions for FW3A Battery Fitment are…..
  • Most all 18650 Flat Tops will work.
  • Most 18650 Button Tops will (most likely) not work. This will depend entirely on the height of the 'Button Top' installed on the cell... but it ain't looking good for "button tops".. . Wink
These findings are based on the stated Maximum battery length of 66mm for the FW3A. Thumbs Up
Since both pair of my calipers are hiding from me at the moment Facepalm , the measurements listed below are taken mostly from LIION Wholesale & MTN.. with a couple from Illumn & IMR.
Flat Tops
  • Efest 18650 3000mAh Flat Top / 65.02mm
  • Efest 18650 3500mAh Flat Top / 65.25mm
  • Hohm Tech Life 18650 3077mAh 20.7A Flat Top / 65.12mm
  • LG HG2 Flat Top / 65.20mm
  • LG MJ1 Flat Top / 65.0mm
  • Panasonic/Sanyo NCR18650GA Flat Top / 65.30mm
  • Samsung 35E Flat Top / 65.3mm
  • Samsung 30Q Flat Top / 64.85mm
  • Sony/Murata VTC6 Flat Top / 65mm
  • Vapcell 18650 20A Flat Top 3000mAh / 65.0mm
    _______
    Button Tops
  • Efest 18650 3000mAh 18650 Battery – Button Top / 67.1mm
  • LG HG2 – Button Top / 67.0mm
  • LG MJ1 Button Top / 66.8mm
  • Panasonic/Sanyo NCR18650GA Button Top / 66.8mm
  • Samsung 30Q Button Top / 67.3mm
  • Samsung -35E Button Top / 66.9mm
KB1428 “Live Life WOT
Yoav.Klein
Last seen: 1 day 22 hours ago
Hi,
Please sign me up for one more light (for a total of 3 flashlights).
Thanks!
DavidEF
DavidEF's picture
Last seen: 9 hours 7 min ago
raccoon city wrote:
Now I don’t feel so bad about buying flat top 18650 cells!  ;)
I wanted button tops, but couldn’t find any for the cells I wanted.
MOST Flat-top cells will work for MOST lights that claim to require button-top cells, if you put a blob of solder on the top of the flat cell top so it can stick above the wrapper. Wink
disclaimer: I can’t prove this. I just think it’s true. (and it probably is) YMMV Innocent
- The YKK Philosophy
JasonWW
JasonWW's picture
Last seen: 10 min 8 sec ago
Why make assumptions when Toykeeper has already said the FW3A was designed to fit both flat top and button top?
I think 66mm is the “safe” number so as to assure fitment, but I bet it will fit slightly longer cells. Not 69mm-70mm protected cells, though.
I’m sure we’ll hear more about what fits and what doesn’t fit later on..
Click this to go to signature links.
alexirc
I’m interested! Looks like a great EDC.
raccoon city
I've heard that as well.
Maybe I should put disclaimer in my signature that says I'm not a modder, and I do not solder.
Firelight2
Firelight2's picture
Last seen: 42 min 33 sec ago
raccoon city wrote:
...Maybe I should put disclaimer in my signature that says I'm not a modder, and I do not solder.
There's something special about having an $8 flashlight that you modded with $80 in aftermarket parts.
It's never too late to start modding! tongue-outlaughingtongue-out
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 55 min ago
I’m hoping it’ll fit button-top cells, at least. Earlier prototypes did.
I’m also hoping things will happen quickly. But I’m hearing that LH351D may be delayed longer than expected, because they were apparently not ordered back in December when I thought they were. And it sounds like there’s some sort of difficulty in getting them. So I’m kind of wondering if it would make more sense to use SST-20 instead.
I know it has come up before, which is why I mention it, but what do people think of the idea?
Here’s a very brief summary of the biggest differences:
  • LH351D has a wider, flatter, floodier beam. Probably more lumens.
  • SST-20 has a narrower, throwier beam. Illuminates farther away.
Both can still have hit-or-miss tints depending on the exact bin used.
To be clear, XP-L HI 3D is still a “yes”. If I understand correctly, XP-L HI should be able to go to production as soon as the driver fit issue is worked out. The question is only about the LH351D version.
teacher
teacher's picture
I’m not making any “assumptions” at all. You left out, in your quote; the part that qualified what I wrote. Facepalm
“These findings are based on the stated Maximum battery length of 66mm for the FW3A.”
Yet you say…. “I think 66mm is the “safe” number so as to assure fitment, but I bet it will fit slightly longer cells.”
Sooo….. which of us is speculating & making assumptions??
I’ll take your bet too, if we can agree on an ‘upper limit’ of length. Wink
It may very well take a bit longer battery/cell. But what I wrote was simply written based on the stated maximum length of 66mm for the FW3A.
Personally, I don’t care either way. But I thought someone might find the data useful. Maybe they will, maybe they won’t.
oweban
oweban's picture
Last seen: 6 min 18 sec ago
My vote is wait on LH351D, so people have the option of throw or flood.
Tom E
Tom E's picture
Last seen: 1 day 9 hours ago
Yea, my $11 ZY-T11 clone quad mod:
    - quad MCPCB from MtnE, quad 10621 optic (MtnE I think), 4 LH351D's from MtnE, alum S2+ spacer sanded down, 2 brass screws
    - CK OSHPark driver, Blue BeCu spring, SMD parts, wires
    - UCL lens
    - light pipe from DigiKey, switch from Digikey/Mouser
    - ohh, and can't forget one copper penny, ~1978
Just shipping alone? Yikes! Makes you wonder...
cabfrank
Last seen: 8 hours 32 min ago
I would, of course, want the XP-L version as soon as it can be done. Next, i would say do the SST-20, if it can be done sooner. Then, do the LH351D, when the good tint emitters are available. I think a lot of people would really like the SST-20, and probably plan to make that swap anyway. I would personally get one of all three, and then a second one of whichever I like best.
MascaratumB
MascaratumB's picture
Last seen: 6 hours 19 min ago
Firelight2 wrote:
It’s never too late to start modding spending lots of money in flashlights that may go from junk to jewels, or spending lots of money in pieces and tools when you could be buying new flashlights!
I fixed it for you Firelight Big Smile Innocent
EDIT: what Tom E said Big Smile
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
JasonWW
JasonWW's picture
teacher wrote:
Personally, I don’t care either way, but I thought someone might find the data useful. Maybe they will, maybe they won’t.
It might be misleading.
I’d wait till later.
ToyKeeper
ToyKeeper's picture
True. Though in this case it’s more like “flood or … more flood”. And if that’s still not enough flood, there are two levels of even floodier frosted optics which can be used.
teacher
teacher's picture
Not for anyone who reads fairly well.
oweban
oweban's picture
Also very true! SST20 with frosted optics could fit the bill nicely, and is quite quick and easy to swap out.
(that said, it won’t affect me as I’ll be going HI; 4000K is too warm for me Sad )
netprince
Last seen: 5 hours 31 min ago
I’d buy an sst20 version, if its a good tint.
cabfrank
As said above, there isn’t really going to a throw/flood option, they are all “floody”. I think the SST-20 would be a great option. I honestly might even prefer it to the LD, depending on how much lumen difference there will be.
saypat
saypat's picture
hoping to receive it by Christmas -
KawiBoy1428
2019 or 2020? Big Smile
teacher
teacher's picture
Ouch….. FacepalmBig Smile
BlueSwordM
BlueSwordM's picture
Last seen: 10 hours 15 min ago
Same thing here.
Doesn’t really matter if it’s using an SST-20 setup, or an LH351D setup.
In a light with such small TIR optics, more throw is always beneficial, so an SST-20 option would be great, especially since it has even better R9 in the CRI spectrum.
I do prefer using the LH351D in lights like the BLF Q8, but for the FW3A?
Full on SST-20 4000k 95CRI.
Coscar
Coscar's picture
Last seen: 4 hours 26 min ago
Free Beer tomorrow !!
Im not a Pessimist …. just an Optimist with a lot of experience
BurningPlayd0h
BurningPlayd0h's picture
After hearing your comments on LH351D’s beam profile in a TIR triple/quad, and now seeing plenty of beamshots of them… SST-20 all the way.
If people want more flood a wider TIR optic is easily available, or they can just use DC Fix/scotch tape like many of us do for lights already.
Firelight2
Agreed.
It’s all a matter of personal taste. But I find that LH351D is just a bit too floody for me. I much prefer the extra punch of XPL HI or SST 20.
I expect when I get my FW3A I’ll probably swap out the emitters for XPL HI (probably two 5000K and one 4000K) and the optic to 10507.
SST 20 is nice, but I find it looks a bit too green-tinged. Also compared to XPL HI, SST 20 with its lower Vf it draws more current which causes the head to heat up faster resulting in the driver ramping down output faster.
ToyKeeper
ToyKeeper's picture
That’ll produce a pretty strange beam pattern. XP-L HI + 10507 tends to have fairly visible artifacts, and you’d be getting artifacts in two different colors.
DavidEF
DavidEF's picture
That might be exactly what he’s going for. Look at his username. Maybe he’s going to run it on candle mode and watch the artifacts flicker all over the place. Party
funkychateau
funkychateau's picture
BurningPlayd0h][quote=funkychateau][quote=teacher wrote:
funkychateau wrote:
Nothing to lose by doing that.
Its a balancing act between fitting shorter cells (how they were designed and sold by the original manufacturers) or longer button-top/protected cells. You always sacrifice some fit on one end of the spectrum for more on the other.
No need to consider protected cells, just unprotected button- and flat-tops. It seems that this model has limited its ability to accommodate a range of cells by using a short set of springs. Resistance shouldn’t be the reason – this light should draw substantially less current than the Emisar D4, which accommodates both flat- and button-top cells pretty well.
