13583 posts / 0 new
Henk4U2
Henk4U2's picture
Last seen: 3 hours 29 min ago
You want it good, fast and budget? Go ahead, pick any two (out of three).
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Whezzel
Whezzel's picture
Last seen: 3 days 9 hours ago
Please put me down for one of these.
kazibole
Last seen: 1 month 5 days ago
Can’t wait!
weklund
weklund's picture
Last seen: 3 days 13 hours ago
Me too … 2 with SST-20 … please.
... Happy Landings ...
trakcon
trakcon's picture
Last seen: 7 hours 18 min ago
Add another for me, please!
That’s a total of 2, both with SST-20.
Mike
JermsMalibu
Last seen: 1 hour 23 min ago
I’m leaning towards getting 2 as well (one of each). Please mark me down for another too, if it matters. Thanks. Smile
slmjim
slmjim's picture
Last seen: 1 hour 48 min ago
The following is from a relative noob's perspective.
Been lurking this thread since early on. This is my first group buy.  I committed to a light back in the early 1,000's (count, not Year AD) IIRC.  I did so mostly out of curiosity, with no expectations, so have not been disappointed with timing or anything else.
Fascinating process.  The challenges have been well documented IMO, and the issues with dealing through multiple individuals across different cultures have been educational to watch.
Kudos to all involved who selflessly spend their own time & resources monitoring the details, keeping the thread updated, and in general shepherding the thing along to fruition.  Thank You!
The discussion of emitters has been somewhat confusing to this writer, simply from lack of experience.  Modding is still some time in my future, so I'd like to make a good choice on the initial order(s).  Which brings up my question:
Could there be a synopsis added to post #1 that briefly describes the advantages and disadvantages of each emitter choice as related to this particular light/optics combination?  Nothing fancy, just some indication of CRI, total lumens, current draw and relative throw per emitter.  Runtime would be nice if only comparing basic modes but, the complexity would be daunting I suspect.  Perhaps links to deeper info per-emitter could be included for educational purposes for those like myself who aren't well versed on the finer points of the emitters being proposed.
slmjim
Great... Carnac the Magnificent tells me I just signed up for yet another expensive hobby.
Smile! It makes others wonder what you've been up to.
ToyKeeper
ToyKeeper's picture
Last seen: 58 min 3 sec ago
I added an updated copy of the comparison used in the emitter poll:
Emitter Comparisons:
Price Lumens Throwiness CRI Beam Heat
Cree XP-L HI $36 2800? **** 70+ ****
Luminus SST-20 $30 2400? ***** 95+ ****
Samsung LH351D $30 2800? * 90+ ****
For price and heat, lower values are better. Throwiness depends on personal needs and taste. For everything else, higher values are better.
Throwiness is a rough measure of candelas per lumen. It’s the overall beam shape. Even the throwiest option is not a thrower, because compact triples are floody by nature. At a guess, the range here is about 2 to 4 cd/lm, and common reflector-based EDC-style lights are usually about 5 to 10.
Beam is the overall beam quality, like smoothness and color consistency.
More peppers makes thermal management harder, reduces the sustainable brightness after step-down, and increases risk of damaging the emitters on turbo.
Values indicate approximate performance in a Carclo 10511 optic using a FET for direct drive on 1×18650. These have not been directly tested in the FW3A host, so this data is more of an educated guess than a measurement.
All of the emitter types are good, but here is the worst part about each:
  • XP-L HI: Costs more. Medium CRI.
  • SST-20: Green at low levels.
  • LH351D: Super floody. Green at low levels. May be unobtainable.
Visual estimate of the floodiest option compared to a throwy option:
BlueSwordM
BlueSwordM's picture
Last seen: 9 hours 13 min ago
Actually, the heat should be the same for the LH351D and SST-20 since they have about the same forward voltage.
ClaudeMBallz
ClaudeMBallz's picture
Last seen: 1 year 1 month ago
Quote:
I would also add for the XP-L HI: Low CRI.
What is the need for adding that? The CRI for each LED is plainly listed. Am I missing something?
John 3:16
BlueSwordM
Sorry, mistake on my part.
spaceminions
Last seen: 7 months 1 week ago
And I think it should be clarified with the two high cri options (without getting into specifics of duv) that their color is not as well-described as green as it would be if they were a cooler temperature, regardless of whether you say lemongrass or just say “yellowish/greenish color”. To me, the sst20 comes across more yellow than green, as I have probably mentioned.
Card Carrying CRI baby https://b.thumbs.redditmedia.com/laMC7BGhREfYTRQjYe2I5FMjTF1IjrmM6bPLK9SKEXU.png
gpbeiew
Thanks TK!
caramba
caramba's picture
Last seen: 6 months 3 weeks ago
8000 posts Party
bansuri
Last seen: 3 hours 43 min ago
caramba wrote:
8000 posts Party
At last, a good laugh from this thread! Thanks caramba, any opportunity to use that old meme is a good one!
I heard that the light will get done quicker once the thread reaches 10k posts, I wonder if there’s any truth to that?
ToyKeeper
ToyKeeper's picture
Same Vf, same amps, but SST-20 makes fewer lumens… so it should also make more heat.
BlueSwordM
Uh, that would mean power is the same for both if the VF and current is the same?
I think heat should be based on power consumption.
All in all, the XP-L HI has the highest VF, meaning it emits less heat.
We then have the SST-20 65CRI which has slightly lower VF, consuming a bit more power, but not really enough to be significant.
Not available here, but would be nice for max throw.
Then, we have the SST-20 95CRI and LH351D 90CRI have the same lowest VF, consuming the most power and emitting the highest amount of heat.
zak.wilson
Last seen: 1 hour 22 min ago
If we’re listing the worst thing about each LED, it seems like performing far worse on a metric some people value highly might be worth a mention.
Ceilingbounce – flashlight testing and runtime graphs for Android
MtnDon
MtnDon's picture
Last seen: 19 min 18 sec ago
The power consumed produces two things; light and heat.
If one produces more light than the other then the one with less light output should be producing more heat, if the voltsage and amps are the same.
If it was possible to build a 100% efficient led all the power consumed would go into light output and there would be no heat.
BlueSwordM
Huh, I completely forgot about that.
Thanks MtnDon.
MtnDon
MtnDon's picture
Thumbs Up Beer
slmjim
slmjim's picture
ToyKeeper wrote:
I added an updated copy of the comparison used in the emitter poll: ---- Emitter Comparisons:
For price and heat, lower values are better. Throwiness depends on personal needs and taste. For everything else, higher values are better. Throwiness is a rough measure of candelas per lumen. It's the overall beam shape. Even the throwiest option is not a thrower, because compact triples are floody by nature. At a guess, the range here is about 2 to 4 cd/lm, and common reflector-based EDC-style lights are usually about 5 to 10. Beam is the overall beam quality, like smoothness and color consistency. More peppers makes thermal management harder, reduces the sustainable brightness after step-down, and increases risk of damaging the emitters on turbo. Values indicate approximate performance in a Carclo 10511 optic using a FET for direct drive on 1x18650. These have not been directly tested in the FW3A host, so this data is more of an educated guess than a measurement. All of the emitter types are good, but here is the worst part about each:
Thank You TK!  That's very useful for me.
slmjim
ToyKeeper
ToyKeeper's picture
It’s not low CRI; it’s just average CRI. Since you think it’s worth mentioning though, I added it.
TheOnlyDocc
TheOnlyDocc's picture
I really hope they can get the LH351D!
The Super floody beam is much more usefull to me. Can not wait to get my hands on it. Perfect UI, high CRI, E-switch, super floody and very compact.
If it works without problems it will be hard for any other light to beat it as my new EDC.
Thanks to all that spend their time and work to make it possible!
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
mikeyn
Last seen: 1 year 6 days ago
+2 please
mattadores
mattadores's picture
lionheart_2281 wrote:
mattadores wrote:
lol my only gripe comes with the exciting news of potential production within the next month or two..
OFCOURSE this project HAD to finally come to completion just as the D18, MF01S, MF01 mini and MS18 all drop….
I’m over the moon… my wallet is looking for new ownership
LOL, you haven’t been around here long huh?
lol only lurking… My wallet is not a fan of my new life decision
mortuus
mortuus's picture
Last seen: 6 hours 49 min ago
TheOnlyDocc wrote:
I really hope they can get the LH351D! The Super floody beam is much more usefull to me. Can not wait to get my hands on it. Perfect UI, high CRI, E-switch, super floody and very compact. If it works without problems it will be hard for any other light to beat it as my new EDC. Thanks to all that spend their time and work to make it possible!
yeah me too, but it seems that for now it will be not possible, maybe later on i dont know Sad
...where Frugal meets with Flashlight!
dropman
Last seen: 1 week 2 days ago
Probably asked before, but I cant find it. How difficult it will be to flash modified firmware to FW3A? Can it be done without disassembling and without soldering?
zak.wilson
teacher
teacher's picture
Last seen: 9 months 3 weeks ago
zak.wilson wrote:
Look what I found.
https://www.lumintoponline.com/lumintop-fw3a-triple-p1492292.html
Hmmm… I click the link & it take me to the Tool AA 2.0
But your link clearly says fw3a-triple.
