13583 posts / 0 new
Sudsy
Last seen: 4 hours 7 min ago
I’d like to be put on the list for a third light, please. I guess I’m going to need a high CRI version later also.
Thanks!
ianfollett
Last seen: 1 year 4 weeks ago
I would like to purchase 1.
saypat
saypat's picture
Last seen: 23 min 35 sec ago
… the FW3A is just a flashlight, right Wink
4492011
Last seen: 2 days 13 hours ago
Please send me the code
Neal
Neal's picture
Last seen: 23 hours 9 min ago
Spiderlight wrote:
Will I get a tracking code after shipping?
every package will have a tracking number
bushmaster
bushmaster's picture
Last seen: 3 hours 47 min ago
No….it seems to be a quest—maybe a grail.
Keep your nose in the wind and your eyes along the skyline.
Del Gue
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 15 min ago
byarnell05 wrote:
Sorry if I missed this but was the most optimal battery ever discussed?
Probably a 35E cell or a Panasonic 3400 mAh cell, or something similar. This light isn’t about maximum lumens on turbo, it’s more designed for practical daily use. And for that, the highest mAh rating is typically best.
It just needs to be an unprotected cell to make it fit. Flat-top and button-top should both work.
Paul321 wrote:
Well this maybe my first mod, I just have to find a suitable MCPCB, any suggestions?
Since you’re in the US, I’d suggest a Mtn triple from MtnElectronics.com. They come with a variety of different emitters already soldered on; just pick your favorite type.
wle wrote:
maybe i missed it, but are there any beam shots?
or discussion of the pattern, in words>?
Maukka’s review has very detailed information about the beam pattern, including quantitative graphs of the intensity at different angles.
http://budgetlightforum.com/node/65619
Tally-ho wrote:
iamlucky13 wrote:
$36 dollars for a candle
For a submersible candle.
A submersible candle which, unfortunately, still doesn’t have a good diffuser cone available.
The best fit I’ve found is the Fenix AOD-S, but it’s not great. I’d like something more like the Olight TW1 or TW10… but with the correct diameter to fit this light.
WalkIntoTheLight wrote:
I’m not sure I’m into “candle mode”, but I’ll see what it’s like. “Sunset mode” seems more useful for my purpose
I’ve used both. They both have a self shutoff timer, but sunset mode’s brightness and timing is hardcoded while candle mode’s brightness and timing are configurable. I still need to bring sunset mode up to par, but it hasn’t been a priority.
saypat wrote:
If I did not want any trace of a rose tint, which emitter of the 3D or 7A would I choose?
and which Carclo would give the MOST flood? 10509?
I think what you’re looking for is LH351D.
Both 3D and 7A have a rosy tint, since they’re both below the BBL. And they’re both meant to be relatively throwy. But LH351D is typically not rosy, and it is much more floody.
As for optics, 10508 and 10509 both look almost the same during use. They’re both very floody.
idleprocess wrote:
navel-gazing
Welcome to BLF! Smile
Your coupon code is scheduled to be sent in the second batch, sometime tomorrow. Messages are happening in the order people requested lights, so the most recent ones are last.
sunnyqueensland
Last seen: 1 year 3 weeks ago
I would like one. Thanks
Neal
Neal's picture
gottawearshades wrote:
This is an exciting time.
I guess nobody can say when the SST-20 will be available?
we will try to find the best SST20 for the FW3A,
supplier said next month will have
DB Custom
DB Custom's picture
Last seen: 2 days 12 hours ago
I know it was said a little ways back, the thread is hot and everything gets buried fast, but ToyKeeper? Cool white eliminates a target downrange better than warm white. I’ve got pictures proving it with both emitters in a GT hitting a water tower at 1.9 miles, in a light rain. I’ve got pictures both looking down the beam and from the side at a closer range (I drove to within a few hundred yards of the tower and shot photo’s from off line right, very plain to see that the cool white was putting more light with higher resolution on the tower.
At long distances high CRI is really irrelevant, so the warmer High CRI emitters tend to be better for close range work where the eye can actually see the color difference. This may, once again, be a preference thing, but my photo’s show clearly to me and my friends that I modded the GT’s for that the Cool White out throws a warmer tint.
Now, most of this won’t come into play with this flashlight as it certainly is not a thrower. The optic design just isn’t capable.
And as far as changing emitters goes, this one should be quite easy to anyone that already knows how to reflow an emitter. The bezel comes off, the optic comes out, de-solder the leads and remove the MCPCB, do your deed and reverse the process. I can usually do this in less than 10 minutes when everything is cooperational. Wink
Edit: Buy a new MCPCB with your preferred emitters on it and the swap can be done in minutes, it’s as easy as desoldering, replacing, resoldering and reassembly, a few minutes. Really.
bushmaster
And our current coupon code will apply then?
Del Gue
Helios azimuth
Last seen: 2 hours 40 min ago
Hi Dale. Did you test the theory that warm tints penetrate fog, smoke and dust better? If not, I might get both of these tints on th FW3A and see. Thanks.
hsiddharta
Last seen: 1 year 1 week ago
Thanks
Tobehz
I’d love to purchase a light!
Thanks
JasonWW
JasonWW's picture
Last seen: 16 min 16 sec ago
Don’t worry, you will not be ripped off.
DB Custom
DB Custom's picture
Helios, in order to penetrate smoke or dust the beam is going to have to be tight, as with fog a broad floody beam will merely make a wall in front of the viewer. The triple Carclo optics are going to make more of a wall than they will allow for any kind of real penetration, a different kind of light will be needed in that instance. In heavy dust or smoke, you’re just not going to see into it more than a short distance with anything less than an intense beam and that will in itself be limiting in the small hot spot. It’s a tough scenario to break through.
Correllux
Correllux's picture
Last seen: 1 year 2 weeks ago
If it’s not too late, put me on the list for one light.
I have to say that I am really thankful and so impressed by the work and time input of so many here on BLF – on this project but so many others as well. My old account has probably been purged by now and I’ll be darned if I can remember what it was anyway, so I had to make a new one…have been lurking off and on for several years, learning and appreciating the fantastic content. TK, Fritz, Tom, Neal, everyone involved in this light for the last couple years, big thanks to you for everything you all contributed – this really does look like a winner. I have some LH351 5K 90CRI on the way from digikey and will probably put those into this light but even with “just” the XPL HI this package has so much going for it. Can’t wait to get it. Still getting to know my FT03 so something to pass the time until then. Smile
oweban
oweban's picture
Last seen: 17 min 28 sec ago
True, but the same light and emitter class with CW vs WW for penetration – while on a clear night CW will throw more, will CE get more caught up on particles in the air? Suppose there’s only one way to find out, really Wink
NWoodsman
NWoodsman's picture
For those who need an update, just passed 1187.
jdh00
jdh00's picture
I’m interested in one.
Neal
Neal's picture
coupon still work
Neal
Neal's picture
package include:
1*FW3A flashlight
2*o-rings
1*user manual (English+Germany)
Neal
Neal's picture
package include:
1*FW3A flashlight
2*o-rings
BlueSwordM
BlueSwordM's picture
Last seen: 3 hours 58 min ago
Ok, I’m back in for 1 unit.
When the SST-20 comes out, I’m going to buy it.
gman7228
Purchased one submersible candle / golden lightning generator. Thanks to all on this forum. Especially to Toykeeper – an articulate genius.
gman7228
There are 10 kinds of people in the world. Those that understand binary notation and those that do not.
LoPan12
Last seen: 11 hours 36 min ago
I would like to respectfully request two please. One for XP-L and one for SST-20 which will be a separate purchase if I understand correctly.
Thank you!
Unloco
Last seen: 5 hours 46 min ago
Today I received the code but I will wait until there are LH351D and SST-20 to buy them together, in a single order.
teacher
teacher's picture
Last seen: 9 months 3 weeks ago
idleprocess wrote:
teacher wrote:
idleprocess wrote:
Got the discount notification pretty much to the estimated minute using the correct variables and placed my order. Looking forward to receiving this in a few weeks!
Glad you got it figured correctly when you used the ‘correct variables’ instead of your earlier faulty assumption ones. Thumbs Up
These things are important insofar as navel-gazing goes.
Cute… I like that. Big Smile Big Smile Thumbs Up …. That is special. Wink
When you posted THIS comment, calculating your personal PM delivery time with incorrect “variables”…. Facepalm . I simply posted THIS, correcting your faulty assumptions so you would get a much more correct & harmonious outcome when you redid your calculations.
If this somehow offended you or hurt your feelings…. my apology.
oweban
oweban's picture
Facepalm
idleprocess
idleprocess's picture
Last seen: 18 hours 35 min ago
Not at all. Precision is generally a good thing.
Just an exercise that moved the needle of delivery … pretty much zero.
