13471 posts / 0 new
zak.wilson
Last seen: 11 hours 20 min ago
I eagerly await momentary candle mode.
Ceilingbounce – flashlight testing and runtime graphs for Android
iamlucky13
Last seen: 4 hours 51 min ago
ToyKeeper wrote:
Just a quick update…
There should be a new batch of drivers soon, and I’m working on firmware updates. So far I’ve got the following…
The main thing is better thermal regulation.
Awesome! Thanks for keeping up the good work.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 34 min ago
CRX wrote:
Have you thought about/ would it be possible to incorporate a configuration lock for ramp config, ie the settings for mode numbers, max ceiling & floor can’t be changed unless a code is entered like the H17F or preferably like the LD4Power drivers?
Nope, I don’t have any plans for that. It’s easy to access, but that’s on purpose.
raccoon city
raccoon city's picture
Last seen: 54 min 36 sec ago
Wow, the FW3A heats up really fast on turbo...
I won't be using that anymore!
I'll test out the flashlight more when it gets dark.
Overall, I'm really impressed.
MtnDon
MtnDon's picture
Last seen: 6 hours 28 min ago
bigtrav261 wrote:
This was posted on the ‘Lumintop Family’ FB group:
“FW3C sample?who knows? Big Smile
!https://i.imgur.com/aA3YI8E_d.jpg?maxwidth=640&shape=thumb&fidelity=medium!
Nice color!! Thumbs Up
BLF Member Map Add your name and location.
BlueSwordM
BlueSwordM's picture
Last seen: 8 hours 17 min ago
Wait, that doesn’t look like machined copper.
That looks like electroplated copper. Love
It’s easy to see since the knurling has some black imperfections, meaning copper didn’t deposit well on the light.
ToyKeeper
ToyKeeper's picture
… or it’s just dirty.
It happens sometimes.
Tejasandre
Did we get any more info from @neil on the 219 cri?
BlueSwordM
Can copper get that dirty?
I though it only gets oxidized/patinad.
I obviously got too excited for my own hype.
Firelight2
Firelight2's picture
Last seen: 2 hours 4 min ago
I assume if you take your copper light and roll it around in some mud you can get it quite dirty. Evil
Keisari
Last seen: 2 days 11 hours ago
nobody wrote:
Lagittaja wrote:
P.S. Regarding the tint: looks good indoors but I’ll reserve my final judgment until after summer when it’s dark again.
I was scratching my head at this until I noticed where you were from LOL!
I’m facing the same issue; very little use for the light for the next 3 or so months. Apart from that and the fact the light seems too nice to carry and get scratched up, everything’s looking good.
Thank you team, mfg, everyone. The FW3A is even cooler than expected – in warm white of course.
Oh, the threads on mine were apparently dirty and loose on arrival causing the symptoms described by many others. Cleaning and reassembly fixed that.
JasonWW
JasonWW's picture
Last seen: 1 hour 6 min ago
As CRX and Teacher said, it’s probably been taken apart and baked. This changes the gray to orange.
It does not look like a different metal construction .
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
teacher
teacher's picture
/\ …. Thumbs Up .. Beer
JasonWW
JasonWW's picture
xevious wrote:
The issue was head tightness. Once I applied a little more torque to the head, it stopped doing that. What’s the physical dynamic at hand when this happens? As I understand it, with the inner tube not completely seated the emitter shouldn’t have current. So sufficient tightening makes for a solid connection and the light functions. Is there some “in between” state possible, where the inner tube has contact, but not fully, and thus there’s some kind of weak voltage issue?
Let me correct you here. The inner tube does not carry any led power. It only carries the very tiny switch signal.
The emitter gets current through the outer tube when the head and tail are somewhat threaded together. This is why you see the leds blink as you are threading them together.
It takes the precise tightening of the tail first, then the head, for the inner tube to make good contact and allow the switch to work.
The only in between state I can think of is the inner tube not making good contact which means the switch won’t work.
CRX
CRX's picture
Last seen: 4 hours 44 min ago
Ok, I just thought that once these levels were set up that people wouldn’t be changing them very frequently.
mitsuki08
Last seen: 1 hour 26 min ago
  • Fixed the bug maukka found — hold-from-off then release-and-hold in stepped ramp wouldn’t work until it had been on for a full second.
  • Made candle mode slightly more calm but also able to burn a bit brighter sometimes.
  • Beacon mode duty cycle is 100ms now instead of 500ms.
  • Made muggle mode do smaller thermal adjustments.
  • Rewrote most of the thermal regulation code. It should significantly improve pretty much anything related to temperature, except for the lack of factory calibration. (still in progress, running tests right now) It takes a while since I need to test basically every supported light, but the ones I’ve tested so far have all waited a sane amount of time to heat up, dropped quickly to a sustainable level, and then just … stayed there. None of this oscillation nonsense from earlier versions, and so far it has managed to step down at a point which is neither too early nor too late.
Also planning to do some other misc updates, as many as I can squeeze in before the deadline. Not sure which other tasks will get done in time. The top tasks are making “hold” auto-reverse in strobe modes, making momentary do the last-used mode instead of just the last-used brightness (so, momentary strobes), and generally making muggle mode a little nicer. Also debating whether to add ten-clicks-from-off as a shortut to thermal config mode. But I wouldn’t count on any of these things.
Is it possible to know when to order to get the updated firmware? Like a specific date where all FW3A’s shipped have this firmware? Thanks for all of your hard work updating it TK! Beer
raccoon city
It's now mostly dark here.
I was afraid that 7A would be too warm, but it's fine.
I like warm tints.
Superb flashlight!
Figgy
Figgy's picture
Last seen: 7 hours 5 min ago
need this light with a 18350 pipe option too O_O
raccoon city
The light is so short with an 18650, that my hand barely covers it!
It wouldn't fit in my hand if it were any smaller.
Figgy
Figgy's picture
It wouldn’t fit in my hand if it were any smaller.
meh at least with the 18350 will be a lot easier to have it as a keychain light Big Smile and when someone needs light boom blind the whole area for a few seconds lol
xevious
xevious's picture
Last seen: 6 hours 8 min ago
Thanks for the correction. I understand what you’re saying, but light behavior puzzles me. So I make about a 1~2mm turn of the head while LEDs are powered, which cuts power. I then press the switch and I get a moonlight strobe. Easy to reproduce. So does this mean outer tube contact is still good but switch senses insufficient power because head isn’t fully tightened?
ToyKeeper
ToyKeeper's picture
Nope, that’s above my pay grade. I don’t get information like that.
I sent a new build though, and I think the drivers are getting made in a few days, and I think I heard the 219C model might ship in a week or so… maybe it could end up with new firmware?
Anyway, the build I sent includes the following updates:
  • Rewrote the thermal regulation. Should be much more stable now.
  • Added momentary strobes. Pick a mode in the strobe group, turn the light off, then go to momentary mode. It should do the last-used strobe. Or, to do a normal (steady) momentary level, turn the light off from a normal ramp mode first instead. Only normal ramp modes and strobes are supported though … there’s no momentary battcheck, no momentary sunset, and no momentary lockout. What would that even mean? It does do momentary candle though, since it’s easier to allow that than not.
  • Made “hold” auto-reverse in strobe modes.
  • Made lockout mode’s momentary moon use 2 levels instead of 1. The second click goes to the other ramp’s floor.
  • Added ten-clicks-from-off as a shortcut to thermal config mode.
  • Fixed a minor bug in lightning mode. The brightest flashes should be full power now.
With the new thermal regulation code, here’s what I measured with a fresh 30Q cell:
For comparison, here’s an earlier version measured by Bob_McBob:
It worked, but it had a lot of jitter. So I fixed the jitter (among other things).
These updates apply to all build targets, not just FW3A. I spent the entire day running thermal tests, and every tested light worked pretty well. The only exception so far was a D4S, which was unexpected. It bounced a little before stabilizing. I haven’t been able to test an original D4 yet though.
xevious
xevious's picture
I like your updates! Wish there was some way to update existing lights. Will definitely pick up an SST-20 when they come out. Thanks again, TK. Beer
goshdogit
goshdogit's picture
Last seen: 5 hours 42 min ago
Thanks for the improvements to Andúril, TK! You continue to spoil us. Thumbs Up
Momentary strobe sounds neat, and stephenk will certainly enjoy it.
Improved candle mode and brighter lightning strikes will be awesome. I think the shorter beacon flashes are a good move.
I’ll definitely be updating Andúril on the dozen lights I have using it. Thanks again for all of your hard work!
saypat
saypat's picture
Last seen: 4 hours 26 min ago
momentary strobes? Hoo-yah!
teacher
teacher's picture
Your in luck, there is a way. You can re-flash them with the updated firmware. Thumbs Up
xevious
xevious's picture
Yeah, I should have qualified with “Wish there was some way for ME to update existing lights.” Wink I don’t have the necessary hardware and lack the knowledge of the program to deploy it into the EPROM. I’ve flashed custom ROMs on my Android phones… if I can do that, should I be able to flash Anduril onto my FW3A?
teacher
teacher's picture
I would ‘think’ so… but I am certainly not the person to ask. Wink
I just know it can be done & the hardware/stuff to get going is supposedly pretty cheap.
Klayking
Klayking's picture
Last seen: 5 days 19 hours ago
Aye, the hardware is really cheap from China. Mine took forever to arrive though. I flashed a D4S easily enough thanks to the driver having little acupuncture holes, meaning I didn’t have to desolder anything. I haven’t tried it on a flashlight that I’d have to do surgery on yet, as I’m terrified of bricking it like I did when I tried to perform my first emitter swap.
Short tube D4 works great for that! Absolute most power you can reasonably get on a keychain. I have seen someone attach their keys to the tripod hole on a BLF GT though. Can’t imagine that’s fun to try and fit in your pocket.
ToyKeeper
ToyKeeper's picture
They’re not much brighter. It was maxing out at ramp level 143/150, and now it goes to 150/150. I doubt anyone will even notice.
About that though, momentary lightning is kind of neat. The way the algorithms work, every time the button is pressed, it triggers a new lightning flash. This wasn’t even strictly on purpose; it happens as a happy side effect of some other code I added months ago. Each button press cancels any pending timers and drops back to the FSM library’s inner main loop, so it stops whatever it’s doing and loops back around to the beginning of the next lightning strike.
TBH, it’s kind of a pain. Some lights are easy, like the BLF Q8… but the FW3A is obnoxious to reflash. It requires unsoldering the LED wires and pulling the driver completely out to get access to the MCU.
I’ve only updated one of mine so far, and that was so I could run some thermal tests. I used the oldest one which still works, in case anything went wrong. I don’t like having a soldering iron inside the ones I actually use, at least if it’s not absolutely necessary. It adds wear and tear that I’d prefer to avoid.
I really like newer designs which can be reflashed by pogo pin adapters. Those only take a moment to update.
