13632 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 3 hours 37 min ago
BOO5TED wrote:
That’s funny because my FW3A I got from Neal has the silver clip, bronze ring in the head but no black retaining ring in the tail.
It’s not strange at all. The changes were not made at once, but over time. The silver clip and bronze retaining ring were early changes and the other ones are newer.
In fact, the silver clip and bronze ring were mentioned 2 or 3 weeks ago iirc.
scosgt
Last seen: 1 week 2 days ago
The copper I received Thursday from Illum has the brass ring in the head, black ring in the tail, V1 tube and longer threads. So there is a mix.
Once again, most of the reported issues seem to be on account of the driver board not being centered. If the brass lock ring touches it, it shorts out the signal from the switch through the inner tube.
Just loosen and re-center and for me at least all the problems went away.
Mine also has the two piece lens
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 56 min ago
The issues with the driver being off-center appear to be the same issues the light was originally delayed to fix. So it’s disheartening to see that those issues stuck around so long. However, if I heard correctly, the design was finally changed in the latest batch to make the driver fit better.
Not sure why there was ever a fit issue at all though, since the first few prototypes were fine. It didn’t become an issue until later.
shirnask
shirnask's picture
Last seen: 5 min 47 sec ago
The fit of the brass ring in the head has a lot of play so when it is tightened down it can be slightly off center -at least that was an issue on a few of mine. Just have to take care when tightening to make sure ring is also centered
JasonWW
JasonWW's picture
It was probably a case of the driver manufacturer not realizing the tolerances needed to be so exact. Their pcb boards might have a tolerance range of 0.6mm which is no big deal for most lights, but is a big deal for this light. So the pcb manufacturer might err on the side of caution making the boards a tiny bit smaller. This is better than too big like in the past. Still, too small means the driver might not be perfectly centered.
This is my guess.
If Lumintop did not contract out the drivers and instead made them in house, then they could probably stay on top of the tight tolerances.
JasonWW
JasonWW's picture
I would guess that Lumintop machines the retaining rings themselves, so I don’t know why they can’t get a better fit. Maybe that was their first run of retaining rings and they are going to refine the fit on the next batch of rings.
What was the early ring made of, aluminum? It fit better, right? They may have switched materials, but kept the same cnc profile. The brass might cut differently than the aluminum and changed the fitment of the threads. It’s certainly possible. Or they did change the machining profile to compensate for the different material, but changed it too much.
They will probably never tell us these small details, but we can clearly see they are trying to make improvements where they can.
Tally-ho
Tally-ho's picture
Last seen: 3 hours 19 min ago
Found on reddit : 18350 tube for FW3A
byarnell05
Last seen: 2 days 19 hours ago
Add a new pocketclip that will work with that and I’m in!
JasonWW
JasonWW's picture
Someone posted their home made version somewhere around here. They found an 18350 tube from another light and then made their own inner tube. Is that what we’re looking at or is this made by Lumintop?
If Lumintop, then it’s a big deal. If homemade, then it’s ehh. Good for that person, but not those who want to buy it.
Tally-ho
Tally-ho's picture
Pictures of the FW3A 18350 tube are from Martin’s facebook account so it might be official : https://www.facebook.com/172854069727800/posts/936991549980711
It’s a bit odd that it hasn’t been announced here first since the FW3A is a TLF/BLF flashlight. :/
M4D M4X
M4D M4X's picture
Last seen: 20 min 9 sec ago
I think Lumintop designed this accessory, not a BLF team member Wink
I did not share the pics here because it's not easy using the phone Sad
planned to do so tonight from my PC
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
Tally-ho
Tally-ho's picture
OK martin, no big deal.
So there is a 18350 tube with a machined cigar grip ring and a 2nd one without ?
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 min 59 sec ago
Somebody? Did not find a 18350 tube…I bored the tail end and machined the tube to a press fit…the Ti/mini is at a Jewelry store to be Laser welded inside the tube as I machined a double lap joint for extra strength….
. Sent a bunch of pictures of my builds to Neal who in turn sent to Lumintop to get the ball rolling, thank Neal for pounding this into Lumintops head, they didn’t want to do it initially…
. Neal sent me this badass Titanium clip I guess for helping?… so I mounted it… added trits…
. Not too bad for being “Homemade” I guess… Big Smile
KB1428 “Live Life WOT
PBWilson
Last seen: 38 min 36 sec ago
Very cool! That mokume gane clip looks very excited to be on that light!
KawiBoy1428
Hahaa yep excited, I wanted so badly to put it on the FW3a mini but it is too long… so looking into finding or designing shorter clips for my mini FW3’s I plan on making more of the “Homemade” Ti/mini’s for a few close family/friends…
mopar440_6
Last seen: 7 months 17 hours ago
I want that clip on a Cu version. That needs to be an option.
Cereal_killer
Cereal_killer's picture
Last seen: 8 months 3 weeks ago
Direct from lumintop:
Gunga
Gunga's picture
Last seen: 1 hour 8 min ago
Awesome. I think rubber grip ring myself.
Binford
18350 version looks nice.
Geuzzz
Geuzzz's picture
Last seen: 24 min 21 sec ago
I think it looks strange. Maybe it looks better without the rings. Kawiboys version for the win for now.
christoph
Last seen: 53 min 28 sec ago
Separate so we can use it if we want or not. One more thing, COPPER please!
Chris
Chris
christoph
Also:)
Chris
PBWilson
I would say that the rubber, removeable ring would be better for me. I’d buy one for each of my lights.
cabfrank
Last seen: 2 hours 30 min ago
Removable ring is better I think. By the way, what are the current best 18350 cells?
It would be a good idea if those could be sold with the tubes.
Johm
Last seen: 2 hours 40 min ago
The rubber one looks better.
Cereal_killer
Best in what way? I use Vapcel 1000mAh (purple) in all my 18350 lights but the largest available capacity is what I base my choice on, there may be a higher current option if you want more output at the cost of runtime.
cabfrank
I guess both high drain and high capacity leaders. I haven’t used anything but 18650s in quite a while.
JasonWW
JasonWW's picture
KawiBoy1428 wrote:
Somebody? I did not find a 18350 tube…I bored the tail end and machined the tube to a press fit…
Not you, someone else.
KawiBoy1428
Was it this………..
lightdecay
Last seen: 2 min 20 sec ago
Removable ring is much better.
KawiBoy1428, that looks great. Incredible work. Also, that clip is lit. Thumbs Up
