13583 posts / 0 new
Kalihi
Please put me down for one.
Thanks!
pepinfaxera
Last seen: 2 hours 33 min ago
BeardedRaleigh wrote:
I would like to be added to the list one more time. Total of 2 please. Thank you See Post .
It is at No. 289 and 578 of The Miller: Interest list
Do you want two more units? …… Total 4 units?
And you are listed as #289 and #578 and 945 and 946
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
AlexGT
AlexGT's picture
Last seen: 2 min 10 sec ago
After following the GT thread until I got mine, I totally forgot about this light, please sign me up for one if there are still spots available…
Thanks!
dyang
Last seen: 11 months 4 days ago
pepinfaxera wrote:
Updated list
Latest: See Post … AlexGT
Until The Miller or the Team take over
I still don’t see my username on the interested party list… Am I supposed to do something different than simply stating I’m interested?
SpAwN
SpAwN's picture
@dyang, the first post can’t be edited because The Miller is not here. See my post above.
pepinfaxera is listing it kindly in this post here: http://budgetlightforum.com/comment/1255476#comment-1255476
And you are listed as #890 and #891
dyang
SpAwN wrote:
@dyang, the first post can’t be edited because The Miller is not here. See my post above. pepinfaxera is listing it kindly in this post here: http://budgetlightforum.com/comment/1255476#comment-1255476 And you are listed as #890 and #891
Thanks for the info! I was hard to navigate/locate post that had the update.
Wyre
Wyre's picture
Last seen: 1 week 39 min ago
When The Miller gets back, could I have a second unit added? I believe I am number 58 on the list.
Thank you
pepinfaxera
You are in the interest list nº # 969
Help list for whoever takes over the OP, “The Miller” or “The Team”
fritz15
fritz15's picture
Last seen: 1 year 4 months ago
Thanks for keeping the list up to date!
pepinfaxera
Thanks to you
Thank you for this magnificent lantern design that you have given us
Google translator
StevenK
Please add my name to the list for one!
Recently brought the Q8 BLF, what a flashlight!
Persechini
Persechini's picture
Which one is currently the working design?
Quote:
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 4 min ago
A) …
B) …
C) …
Trick question. The answer is: D) None of the above.
It’s being revised.
Persechini
I’ve been thinking about this light, but design plays a big part in my purchase decisions, guess I’ll wait until it’s more definite
In my Tree
Pulsar
Pulsar's picture
Last seen: 4 months 6 days ago
Throw me in to darkness wrote:
Same, the bottom shiny milled version looks absolutely top notch to me.
I do not think I would have marked myself interested if it looked different from that version, which was the initial one.
I’m still going to follow here of course as anything could arise.
Same, but still watching in case they go back to a more appealing design.
Jiffy
Last seen: 10 months 2 weeks ago
If I remember right, the prototype was the wrong anodising and the plan is to have clear anodising so it will be shiny like the bottom pic.
ChrYoko
ChrYoko's picture
Last seen: 4 months 4 days ago
Yep, Shiny version is the most beautifull one !
Spiderlight
Last seen: 3 weeks 3 days ago
I don’t care about design.
I just want it bright and robust.
The Jinx
The Jinx's picture
Last seen: 3 weeks 2 days ago
Is it too late to join the list? If not, please include me
SpAwN
SpAwN's picture
same here, and small size factor, if the lenght keept around same as proto type it would be great if not still nice.
joechina
Last seen: 2 weeks 3 days ago
On a normal lamp with contact issues you normaly sand the ends, lube them and you you are fine.
What about this lamp? Sanding one end seems bad.
I guess conductive lube on the ends is also a bad idea. Any lube recommendations?
Or how much fidelity is necessary to troubleshoot and assamble it?
Is it a finicky light?
zak.wilson
Last seen: 1 day 4 hours ago
Major brand lights (Fenix, Acebeam, Klarus) have been using nested tubes like this for a while to enable an e-switch in the tail (usually ill-used for instant strobe) and/or USB charging without turning on the tailswitch. Mine have been trouble-free.
Ceilingbounce – flashlight testing and runtime graphs for Android
FlashMax
FlashMax's picture
Please add me to the list. Thanks
Max
FlashMax
FlashMax's picture
Max
pepinfaxera
Post # 2221
Post # 2222
Have you repeated the #Post?
or … Do you really want two units?
FlashMax
FlashMax's picture
Just one, it seems to be a mistke. Thanks a lot
Max
SKV89
Last seen: 10 min 7 sec ago
ToyKeeper wrote:
DB Custom wrote:
how neat would it be if this light used 3 carefully selected tints to emit a near perfect output?
I like how my tint-mixed quads turned out. I haven’t gotten a triple to look quite right though.
It should be doable with XP-L HI and a frostic optic, but it’d probably be easier with three high-CRI Nichia 219c emitters instead, since they’re less tinted to begin with. Perhaps 4000K, 4500K, and 5000K. Together they should look pretty good, but I haven’t tried it.
I’m not sure if 10511 is frosted enough to make the tint-mixed result look good. It might be necessary to use 10508 or 10509, but that’d make it a lot floodier. 10511 might be okay if we don’t mind having a few different colors of mild artifacts.
Wow mixing the Nichia 219c tints would be so awesome! I would love to see that in action and would be nice if we have the option to add money for custom features similar to how the Emisar D4s are sold.
ToyKeeper
ToyKeeper's picture
I don’t expect tint-mixing to happen. It’s not really in the Overton window yet, and it would mean tripling Lumintop’s investment. Instead of a single reel of 3000 emitters (1000 lights), it would mean committing to three reels of 3000 each, or 3000 total lights.
Even if Lumintop wanted to make three times as many units, they’d probably just offer it in three different flavors.
teacher
teacher's picture
fritz15 wrote:
We also posted our impressions here but if you’re not following every post you don’t really have any chance of finding it since the topic here receives so many more replies. And unfortunately, it’s not possible to update the original post by the miller.
Anyway, this week or next week we’ll send our feedback to Lt and then we wait until the next prototype is ready.
You could create a ‘Team account’, as was done in the BLT GT thread; and ask sb to change the original post ownership from the miller to the ‘Team account’. That way the OP (original post) could be updated with the needed information.
It worked well in the GT thread once it was done.
Sarge930
Last seen: 21 hours 36 min ago
I’m in for two
