Convoy C8 Mod - The WOW Factor
96 posts / 0 new
NeutralFan
NeutralFan's picture
Last seen: 5 hours 51 min ago
I bought a Convoy C8 XP-L HI V2 1A with guppydrv firmware from Mountain Electronics. I also bought a 42mm anti-reflective (AR) coated lens. Swapping out the stock lens with the AR lens was a very simple mod.
Overall the flashlight is a great value. It has great throw and I really liked all the modes (22 total) that came with the guppydrv. But I felt it was a little underpowered compared to the other flashlights I have. My family thought it was pretty cool since it throws really far for such a small flashlight, but it did not have the WOW factor that some of my other flashlights have (such as the Noctigon Meteor M43).
So I got the mod bug again and bought some cool parts from Mountain Electronics:
17mm FET + 7135 driver (MTN-17DDm)
- Bistro firmware (attiny25)
- Battery check
- Moonlight mode
- Temperature regulation
- Low voltage cutoff
20mm CREE XP-L HI V3 3C on Noctigon (metal core printed circuit board) MCPCB
- Neutral white tint
- Direct thermal path (DTP) LED
22 American Wire Gauge (AWG) silicone wire
I ordered the 17DDm driver with the spring and wires installed. The positive wire is soldered to the top of the spring and will be connected directly to the LED MCPCB – nice design.
Rationale for these parts – The stock LED does not have a DTP to the MCPCB. With the increased current from the new driver, the LED would heat up too much and eventually fail. An LED with a DTP MCPCB is needed to help dissipate the heat. The tail spring also needs to be bypassed (hence the 22 AWG wire) in order to support the increased current. The spring alone would have too much resistance and not allow the current to get to the driver.
A new switch is not needed since the switch that comes with a Convoy C8 is a quality Omten switch which can handle the increased current.
First, I had to take the flashlight apart. The bezel is easily unscrewed. The driver and tail switch are held in place with retainer rings. I tried with toothpicks and other items to loosen them, but they did not budge. My needle nose pliers was too big to fit into the divots on the retainer rings, so I filed down the ends to make them smaller. Then I was able to use the pliers to loosen them. They were on very, very tight! The driver retainer ring was loosed with the normal counter-clockwise motion, but the tail switch loosened clockwise.
I de-soldered the wires on the LED MCPCB and removed the driver.
I took out the 2 screws holding the LED MCPCB in place and pulled it out. Then I removed the remaining thermal compound using a cloth and isopropyl alcohol. This Convoy C8 comes with an integrated LED shelf.
I “tinned” the new LED MCPCB by putting some solder onto the solder pads.
After doing some research on applying thermal compound, I put some thermal compound on the shelf, spread it around with a flat plastic tool, and removed the excess with a lint free cloth. I applied a thin layer of thermal compound on the back of the LED MCPCB with the same plastic tool. I pressed the MCPCB onto the flashlight shelf and slightly twisted it back and forth a couple times. I then screwed the MCPCB securely to the shelf.
I pushed the driver wires through the holes in the shelf and soldered them to the LED MCPCB. I filed the excess off the sides of the driver PCB in order to fit it into the flashlight head. I rotated the driver a little as I put it back into the flashlight head and screwed the retainer ring back on. Rotating the driver allows the spring wire to more easily flex when the battery is placed into the flashlight.
I put the reflector spacer, reflector, and AR lens back into the flashlight head and tightened the bezel back on.
Now to the switch and spring assembly. I cut a small piece of 22 AWG wire, stripped both ends, and soldered 1 end next to the bottom of the spring onto the switch PCB positive contact. Then twisted the wire a little and soldered the other end to the top of the spring. I made sure there was a little extra length in the wire to be able to flex within the spring. I put extra solder on top of the spring to provide good contact with the battery.
I then put the switch and spring assembly back into the flashlight tail and screwed the retainer ring back on by rotating it counter clockwise.
Overall a pretty straightforward and not that difficult of a mod due to the high quality of the Convoy C8 flashlight.
Here is a neat moonlight mode picture.
To demonstrate the intensity of the modified Convoy C8, left is the Meteor M43 with Nichia 219C on turbo at 6,000+ lumens, right is the modified C8 creeping into the middle, both at 3 feet.
Here are some outside beamshots.
I am very happy with how the flashlight turned out and as my family can attest, it now has the WOW factor.
I’d rather use my flashlight around the house than turn on the lights.
giorgoskok
giorgoskok's picture
Last seen: 4 days 1 hour ago
It’s a hot rod C8 now.
Congrats
freeme
freeme's picture
Last seen: 12 min 48 sec ago
Classic C8 mod. cool
©freemex1thedeals.com
firedome
Really nice C8 mod! Big Smile
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
Yokiamy
Yokiamy's picture
Last seen: 13 min 4 sec ago
Very nice mod, and thanks for putting the time and effort in the pictures!
I am always happy as a kid when stuff arrives, and usually forget to take all the detailed pictures.
These pics really help a lot, since i wanted to mod my C8 as well, but started out modding S2+‘s first Wink
I have upgraded my C8 to the SMO reflector AR glass and dedomed my XML2-U2 1A, but found the beam quite ringy, so installed the OP reflector again, which smoothes out the beam.
Still a nice noctigon with XPL-HI, wire upgrade and spring bypass are still on the wishlist…
  BLF
MRsDNF
MRsDNF's picture
Last seen: 14 hours 33 min ago
Thanks for the descriptive mod. this should come in handy for anyone getting into modding. Thumbs Up
virencelights
virencelights's picture
Last seen: 2 days 14 hours ago
where did you catch the 22 AWG wire from ?.
thanks..
Virence ArmyTek Viking Pro Quadtrix 9080 E21A 5700, Virence Skilhunt H04 Quadtrix 9080 E21A 5000k, Virence Jetbeam AAA 9080 E21A 5000k,
Virence Jetbeam AAA Nichia HCRI Red Led.
luminarium iaculator
luminarium iaculator's picture
Last seen: 13 hours 59 min ago
Very neat and tidy which only tells that you are pro in this business Thumbs Up
sp5it
sp5it's picture
Last seen: 10 hours 19 min ago
thanks..
Fasttech got plenty of those.
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
Sledgestone
Last seen: 2 months 2 days ago
Did you measure the Lux after the mod?
Jerommel
Jerommel's picture
Last seen: 2 hours 14 min ago
NeutralFan
ZFL-M60 wrote:
where did you catch the 22 AWG wire from ?. thanks..
I got all my parts from Mountain Electronics. This was the first time I used silicone wire and it was really easy to work with since its so flexible.
NeutralFan
Sorry, but I don’t have the equipment to do that. Maybe some day. I’d also like to get a clamp meter to measure the current.
NeutralFan
Yokiamy wrote:
Very nice mod, and thanks for putting the time and effort in the pictures! I am always happy as a kid when stuff arrives, and usually forget to take all the detailed pictures. These pics really help a lot, since i wanted to mod my C8 as well,
You are welcome. I’ve learned so much here on BLF so I’m glad I can help others.
ImA4Wheelr
Last seen: 1 week 3 days ago
First class build.  You changed the stuff that matters and kept the stuff that didn't need to be changed.  As stated above, this thread is gold for aspiring modders.  More than that though, your attention to detail manifested in an excellent result.  The amazing pictures clearly reflect that level of attention.  Congrats!
Edness
Edness's picture
Last seen: 6 months 1 week ago
Very nice! I have a clear version in transit from china. I was going to go the same route…same LED and driver. But the clear version with XP-L HI U6 3A has a DTP board and AR lens. I’m hoping I’ll like the tint as I’m a huge fan of the V3 3C tint. Since I have a spare BLF A6 FET driver, I’ll just pop that in. Perfect budget thrower!
NeutralFan
ImA4Wheelr wrote:
First class build.  You changed the stuff that matters and kept the stuff that didn’t need to be changed.  As stated above, this thread is gold for aspiring modders.  More than that though, your attention to detail manifested in an excellent result.  The amazing pictures clearly reflect that level of attention.  Congrats!
Thank you ImA4Wheelr, I really appreciate your kind and thoughtful comments.
Speed4goal
Last seen: 1 year 1 month ago
Congrats on the build now you’ll be building more and more and end up with a c8/x6 army.
Try a dedomed xpg2 s4 2b from mtn on your next one. Even the new style xpg will still get you about 165k lux. About 800 yards of throw I believe. Mine with a dedomed xml2 u4 1a has 700 yards of throw.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
SoCalTiger
SoCalTiger's picture
Last seen: 3 months 5 days ago
This is a great post and thank you for all the detailed pictures!
CRX
CRX's picture
Last seen: 1 min 28 sec ago
Very Nice Thumbs Up
SoCalTiger
OMG you’re right about the retaining ring being on there TIGHT. I just tried to remove the ring on the head and quickly bent a cheap awl in the process. I guess a driver swap is going to be a little harder than I thought lol
Lightbringer
Lightbringer's picture
Last seen: 3 hours 23 min ago
Will the 2B end up being too warm? I just got some 1As for dedoming, figuring it’d end up as a 3*.
Lightbringer
https://www.amazon.com/gp/product/B000NPR2P8/
Works a treat…
Had a small issue with them (not a flaw), Tekton went well above and beyond to make it right. Inspiring, ended up getting more stuff from them as a result.
NeutralFan
My homemade snap ring pliers cost $1.99 from Harbor Freight and also fits (just barely) my Supfire M6 retainer ring that is about 42mm wide. I like how the filed down ends fit snuggly in the divots/holes so they do not slip or mare the retainer rings.
KawiBoy1428
KawiBoy1428's picture
Last seen: 54 min 55 sec ago
I might have missed it in your detailed process description and related pictures, but did you check the integrated shelf for flatness?
I normally stone/lap the shelf flat and the mcpcb, then check contact to each other, better contact, better thermal transmission Wink
KB1428 “Live Life WOT
PBWilson
Last seen: 13 hours 35 min ago
Being new to modding flashlights, your thread is a big help for me to see how things fit together. What’s next?
Thom2022
Last seen: 2 years 4 months ago
Nice write up. Great detail and good photos.
If later down the line you want some extra wow then drop in a dedomed/sliced XPG2/XPG3.
The G2 will require a regulated driver (qlite is a good option) whereas the G3 should be able to handle short bursts of direct drive if well heatsinked and will be able to put out ~900 OTF lumens but being a smaller die it will out throw any XML or XPL.
Just an idiot with a soldering iron.
AdrianWA
AdrianWA's picture
Is this the same driver with new C8 ghost?
I want to try and build myself. I was planning to get the Convoy C8 host from BG. Cheers
NeutralFan
There was some machining marks including a dimple in the middle, but overall the shelf seemed pretty flat. I didn’t notice any unevenness between the LED MCPCB and the shelf.
NeutralFan
I have parts coming to make a JAXMAN E2L Triple LED flashlight. I’m looking forward to see how it all comes together.
NeutralFan
You will need to buy a 17mm driver and a 20mm MCPCB LED in addition to the host.
