Upcoming Astrolux S42 18350/18650 quad w side button and usb charging
233 posts / 0 new
Tom E
Tom E's picture
Last seen: 4 hours 52 min ago
Just pre-ordered one w/219C's. Looks pretty good. Can't wait to get my hands on the survival hammer - I don't have one and need it.
Wut?
BooBooBear
BooBooBear's picture
Tom E wrote:
Just pre-ordered one w/219C’s. Looks pretty good. Can’t wait to get my hands on the survival hammer – I don’t have one and need it.
Wut?
If you know where to get one, let us know.
Tom E
Tom E's picture
BooBooBear wrote:
Wut?
It says right here on BG the S42 comes with one, so it's included smile
chinooker
chinooker's picture
Last seen: 45 min 8 sec ago
hope it looks like this
joechina
Last seen: 3 hours 27 min ago
Has anyone found a review? The only I found was Banggoods blog
https://blog.banggood.com/astrolux-s42-s42s-52409.html
tek-0
Last seen: 8 months 5 days ago
I wonder how the UI works? From the illustration it looks like you have to click through all the modes before the light turns off. I hope this is not the case.
patmurris
patmurris's picture
Last seen: 5 days 14 hours ago
joechina wrote:
Has anyone found a review? The only I found was Banggoods blog https://blog.banggood.com/astrolux-s42-s42s-52409.html
Good find!
Nice to see a copper head too… but i’m not fond of the ‘colored’ SS.
RollerBoySE
RollerBoySE's picture
Last seen: 1 day 23 hours ago
Copper head with aluminum body is the version I prefer; will it be offered?
patmurris
patmurris's picture
I would also be glad to see a plain aluminum S41 head…
mudguts
Last seen: 20 hours 58 min ago
Ive gone for one
mudguts
what would be a good choice of 18350 cell for this, xtar 18350 850mah unprotected, BASEN 18350 800mAh 12A. Trustfire TF 18350 Li-Ion 1200mAh Button Top 3.7v Unprotected, EFEST 18350 Batteries 3.7V Li-ion 800mAh IMR, my guess unprotected would be best.
Ford Prefect
Ford Prefect's picture
Last seen: 10 hours 59 min ago
+1
Black ano aluminum with the copper section please (bundle with a 18650 tube Cool
patmurris
patmurris's picture
Unprotected high drain would be best.
For the S41 i bought Enercig 18350 700mAh. Good performer.
I’m trying to get some Aspire 18350 1300mAh – tested at 1050 and probably capable of 7A.
chinooker
chinooker's picture
I’m heating my hoodie pockets with S41 and S41S using these
hold up to level7 very well “Ouch”
mudguts
Will button tops fit too?
RollerBoySE
Yes, just watch out for protected cells (they are typically too long to fit and also gives less output).
mudguts
patmurris
patmurris's picture
mudguts wrote:
would these be a good choice
http://www.candlepowerforums.com/vb/showthread.php?350974-Test-Review-of...(Red)
Those Efest 18350 will do.
Note they are somewhat ‘old’ – four/five years. There has not been much evolution in the 18350 format but more recent cells may have a bit more capacity (those test at 700 mAh). Make sure you buy new ones because LiIon cells do age even without use – or so is my understanding.
Jerommel
Jerommel's picture
Last seen: 1 month 1 week ago
They seem to be identical to Keeppower 18350 under the wrapper.
Could well be the same cell.
Probably not capable of 7 Amperes.
i.i.r.c. they’re good up to 3 Amperes.
2Q19
chinooker
chinooker's picture
with the 18650 tube on the S41S my button top Samsung 30Q’s are a press fit and even stripped a bit of the shrink-wrap off of one.
worked OK just too wide for the extension tube. Same with protected 18650’s
they work fine in the S41 extended tube
mudguts
scrumpypaul
scrumpypaul's picture
Last seen: 11 hours 22 min ago
mudguts wrote:
Do you think these may do
https://www.totallywicked-eliquid.co.uk/18350-800mah-imr-replacement-bat...
If you plan on getting these, buy them today and use the code DOUBLE15 to get 30% off – today (Sunday 21st May) only.
Erethryn
Erethryn's picture
Thanks, just ordered a couple of 18350s and 14500s.
Erethryn
Erethryn's picture
Got my order of 18350s yesterday, and they’re labelled Efest. Need to check the capacity, but as they’re labelled 800mAh, I assume that they’re the Efest IMR18350 800mAh (Red) tested by HJK.
http://lygte-info.dk/review/batteries2012/batteryIndexEfest%20UK.html (This is the index, as it keeps truncating the direct link to the battery review)
Roadie
Last seen: 3 months 4 weeks ago
Is there a belt holster that would fit the S42 (in the 18350 format)?
RollerBoySE
Roadie wrote:
Is there a belt holster that would fit the S42?
https://www.banggood.com/12_8×3_2cm-Astrolux-Flashlight-Protected-Bag-H...
Roadie
This seems to be for the 18650 configuration. Is there one for 18350?
chinooker
chinooker's picture
I have one and the S41 W/18350 fits if you leave the head above the elastic sides
being elastic you can push the entire body into the case and hit the bottom
butt the light is not secure and could conceivably fall out the open area at the base
works fine W/18650 tube installed
add…I had tried it with my S41S and it stayed in the upper position fairly well due to its grippier knurling
on trying it with my S41 it can by a little shaking, fall fully to the bottom part of the case
I can’t recommend this for use W/18350 configuration
Roadie
Thanks for your input.
chinooker
chinooker's picture
I am looking for a spacer/battery case that could be placed in the lower part of this case to hold the S41 in position in the upper part of the case
might work a-treat as these pocket rockets can eat a battery pretty quick in showoff mode
~1.75” length seems optimum, same as 10440 /AAA Thumbs Up
the width is partially flexible due to the elastic sides, as is square/round/oblong
as long as it can fit 1, or better yet, 2 18350’s
might make a very field-able case out of this genre
