Upcoming Astrolux S42 18350/18650 quad w side button and usb charging
233 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 1 month 1 week ago
chinooker wrote:
RollerBoySE wrote:
I guess it’s really shame on us for, with their less than stellar track record, having trusted BangGood with “building” a flashlight…
and for pre-buying w/o reviews ! Facepalm
Yeah, both sides haven’t learned form their mistakes.. FacepalmSickSillyParty
2Q19
chinooker
chinooker's picture
Last seen: 38 min 40 sec ago
has anyone tried removing the brass retainer ring from their S41 and installing in the S42?
Tom E
Tom E's picture
Last seen: 54 min 47 sec ago
It lives!
 The mode changing is kill'n me! Guess this is why I wrote my own firmware... Why the delays? Ugh...
Pulsar
Pulsar's picture
Last seen: 7 months 6 days ago
Any battery rattle or anything with the fix? Does it still want to crush the negative side?
Horrible with this lights regular price that this has been overlooked to begin with
Tom E
Tom E's picture
Oh boy, definitely no rattle. Crushing the Batt- end? Well, maybe... It's darn tight in there. These are older EFEST cells, so might have been already some crushing. But it you see the cell sitting in the tube, just a little under the end, and knowing the tail spring has to completely collapse down to ~2 mm maybe, it doesn't look good.
So, the solder blob is probably not enough... frown
Jerommel
Jerommel's picture
Could it be an assembling mistake?
Maybe that spring should have been put inside the larger one in the tailcap?
(edit) O, so it’s still a little tight in there?
2Q19
patmurris
patmurris's picture
Last seen: 1 week 3 hours ago
Tom E wrote:
Bad News! These are not designed for batteries – even flat top unprotected 18350’s dont fit, 16340’s don’t fit. The spring on the driver side should be a flat profile brass pad, then it might be all good. The light is useless as shipped.
I’m expecting mine any day now… Facepalm
After the S41S crushed leds, now the S42 too short battery tube or whatever…
However, i ended up with a somewhat ‘free’ S41S after BG sent back a new head and agreed to sell the tail/switch part. Maybe we’re headed the same way again? Glad i didn’t pay the full price on this one.
I’ve no idea how to unsolder the driver spring without overheating the whole assembly… Can you share some tips?
Jerommel
Jerommel's picture
Just do it.
Pull the spring while heating.
It takes a long time before the other side of the PCB is hot enough to de-solder parts, if ever.
2Q19
chinooker
chinooker's picture
sounds exciting….
chinooker
chinooker's picture
Has there been ANY response from Astrolux/Bangood on these issues?
My buying habits hinge on good feedback…hint…hint.
I’m only VIP3 butt I might downsize next year
Tom E
Tom E's picture
More pics.
Uh ohh - cry
Fits well using the S41 tailcap. The spring is soft and maybe set deeper:
That's about 1.5 mm clearance with the solder blob job:
Now we're cranking... A BLF A6 tube fits, reversed, then need to add a washer in the tail:
My S41 head is glued up real tight, never was able to get it apart. Least I can't break posts... undecided
The tail spring is 1 mm diameter wire, sits in a 2 mm depth machined out depression. Full compressed it's still about 2.5 mm above the base (~4.5 mm compressed total).
m_a_schuster
Last seen: 2 weeks 2 hours ago
Actually for mine, things are even worse. I tried bypassing the tailcap with a paper clip between the battery and the battery tube, and it still would not power up. The problem is that the *front*(emitter) end of the battery tube is too short (or the threads in the head are too long), so it never touches the negative contact ring on the board itself. I proved that by screwing the battery tube in *backwards* so that it made contact, and then I was able to get it to power up using the paper clip on the negative side. Inserting a circular shim in *front* of the battery tube, just ahead of the emitter board, yields a working flashlight which can also be tightened without further compression damage to the battery. This is clearly a design/fabrication issue, and I told Banggood in my latest email. Awaiting a response.
Tom E
Tom E's picture
This setup works well for me. The o-ring is exposed though. With the solder blob on the driver, and the 1.4 mm thick copper washer shown above in the tailcap, the battery is not under stress.
Ohh - I managed to re-assemble the head w/optic with only one leg!
Oy vey, man, what a mad mod world Facepalm
chinooker
chinooker's picture
all of these work-arounds seem to skirt the issue of warranty (implied or otherwise)
we paid for working light, right?
scrumpypaul
scrumpypaul's picture
Last seen: 2 days 9 min ago
Exactly!! Yet to receive mine but if it too is faulty I have neither the time, tools, skills or inclination to bodge it together just to make it function.
patmurris
patmurris's picture
m_a_schuster wrote:
…This is clearly a design/fabrication issue, and I told Banggood in my latest email. Awaiting a response.
Still haven’t got mine, but i’m already preparing to write BG about it… Curious to see how it turns out.
whitecitadel
Last seen: 3 months 1 day ago
damn.
Postman bought one today, but I ordered another as a present for someone…. which they finally shipped a few days ago and is on the way.
Not opened it yet, if it doesn’t work will be very unhappy as BG customer services seems to have disappeared of late – they canceled my order for the tubes with loads of points and still won’t give me the points back or even answer emails!
m_a_schuster
whitecitadel wrote:
damn. Postman bought one today, but I ordered another as a present for someone.... which they finally shipped a few days ago and is on the way. Not opened it yet, if it doesn't work will be very unhappy as BG customer services seems to have disappeared of late - they canceled my order for the tubes with loads of points and still won't give me the points back or even answer emails!
My first email to them was answered within 24h.
On their request I uploaded and linked to a YouTube video demonstrating the identity of the product and that it would not power up. Now, no response after the same period of time.
I had posted a negative review on the Banggood web site which they responded with a message indicating that this was a rare occurrence, and that CS would work with me to find a solution. Having additional information on the exact cause of the problem, I added a comment to my own review this morning. My comment was posted, and then disappeared several hours later. Perhaps there is a rule against commenting on your own review?
Roadie
Last seen: 4 months 1 day ago
Your review seemed to be a 4-star review too, was that altered?
m_a_schuster
The overall star rating is computed from the individual component ratings, using a formula that I could not figure out. You cannot change it directly.
Firelight2
Firelight2's picture
Last seen: 22 min 39 sec ago
Tom E wrote:
Ouch there… Just got my 219C S42. Will try it out and take some #‘s.
Bad News! These are not designed for batteries …
Yikes!!!! Facepalm
mudguts
Last seen: 3 hours 31 min ago
Hi
Mine works with 16340 cells
Sprinkles
Anyone try removing the driver yet?
Firelight2
My S42 XPG3 arrived today. I haven’t had a chance to test it yet (no batteries here at the office). However, my preliminary impressions at a glance:
  • Anodizing looks perfect
  • As others have mentioned the USB port cover won’t stay in place. The main problem appears to be that the socket in the bottom of the head for the rubber cover just isn’t deep enough. The result is the cover falls out of position with even a light touch. I’m not sure I’d want to pocket EDC this light without either gluing the cover down or wrapping a rubber band around the head of the light to hold the cover in place.
  • The tailcap shroud is too short. At least on my sample even with the tailcap screwed down fully I can still see half the tailcap o-ring.
  • The o-ring on the body tube at the tailcap came well lubed. The o-ring on the body tube at the head of the light was unlubed.
  • Tailstands perfectly without the hammer thingy screwed in. However, I’m not a big fan of having screw threads at the back of a light like this. Those screw threads make the tailcap approximately 7mm longer than it needs to be. Why make a tiny light if you are going to add unneeded threads and the back to make it bigger again?
My overall initial impression without having been able to actually operate the light yet: Manufacturing quality looks good, but the light appears to have a number of design defects that should have been caught before production.
whitecitadel
Ok, so having been slightly worried, unpacked mine and its the XP-G3 I ordered as a gift.
The battery is a tight fit for sure, I am using an EFest 700mA unprotected, brand new.
I must be doing it wrong, as it works ok here for me.
The springs are at both ends on mine, seems to compress just fine, its a tight fit to get the last turn or so on for sure but it does work. The battery does seem to be a bit “dented” I suppose now at both ends, but everything working as it should as far as I can see. I noticed on the tube the tail cap end was greased, but the head end was dry. There was also some oil on one end of the tube (left a ring on the table) so I wiped that down as that would have been reducing metal-metal contact on the tube.
I can’t test 18650, as BangGood cancelled my order for the tubes (still waiting for points refund – they cancelled not me!) and I only just re-ordered yesterday so still waiting.
By the way, tubes on flash sale yesterday when I ordered.
Can’t seem to get into programming mode, so stuck low-mid-high-turbo
Tom E
Tom E's picture
Dbl click to flip to 7 modes.
Hhmm. I guess I could have crushed my EFEST 18350 as well to make it work, but don't think that's how it should be. Those dents you created are typically worth tossing the cell for. I'd say from the pics, yours is the same as mine. If you have to crank on tightening the light up, you are typically doing damage. There's an amazing amount of force than can be applied on threading a tube tight. I've done it before a couple times at least.
The best way of testing this is: remove the tailcap, insert a cell into the battery tube, press down pretty darn hard on the cell til it doesn't go any further by finger. If the cell still is above the lip of the tube, you got problems, because that lip must make contact to the aluminum around the tail spring in order to have an electrical return path for the Batt- signal. The threads are anodized so won't conduct electricity.
m_a_schuster
Regarding damage to LiIon cylindrical cells from axial compression, see my post:
http://budgetlightforum.com/comment/1139931#comment-1139931
I figure my Nitecore 18350 is compressed way less than 1mm, so perhaps I'm safe.
Using your test, the battery definitely protrudes above the rear lip of the battery tube. That's why I increased the reach of the battery tube by shimming the front end. It also makes it possible to use the 18650 battery tube which suffers from the same problem (i.e. the driver board is glued in place 1-2mm too deep for either battery tube to reach it).
I just read elsewhere that Banggood has realized this is an issue from numerous buyer complaints and is working on a fix. From a business standpoint, mailing out some 2mm thick front-end retaining rings is a lot cheaper than replacing the same number of battery tubes having longer threads on the head end.
Tom E
Tom E's picture
I'm still using a couple EFEST cells with minor dents as well. No clue what all that really means - top cap for 4 mm with a 18650 - might mean something or nothing for a 18350. I don't know enough about them internally. All I know is what's been said here, which is to toss damaged cells, though I don't listen well to advice anyway, specially my own smile.
I will though stop doing what I was doing that caused the damage, usually that is...
RollerBoySE
RollerBoySE's picture
Last seen: 3 days 12 hours ago
That could work, but what about the (maybe) resulting exposed o-ring?. The important thing, not to lose face completely, is for BangGood to act proactively and fast.
m_a_schuster
On my specimen, shimming the front of the battery tube allows the tailcap to be completely seated, so the o-ring is not exposed. However, yes - depending on how thick the shim is, you then run the risk of the front o-ring peeking out a tiny bit.
