NEW Skilhunt S3 PRO CREE XHP35 HD 1600lm / HI 1400lm Flashlight
16 posts / 0 new
freeme
freeme's picture
Last seen: 40 min ago
Another quality product by Skilhunt.
SPECIFICATIONS
  • S3 pro HI / HD USB rechargeable tactical LED flashlight
  • LED: CREE XHP35  HD / HI
  • Max output: 1600 Lumen / 1400 Lumen
  • Max runtime: More than 1 month
  • Max beam distance: 306 meters / 371 meters
  • Waterproof: IPX-8
  • Impact resistant: 1 Meter
  • Battery: 1×18650
  • Rated Range: 2.8V ~ 8.4V
  • We recommend to use a 18650 lithium battery with excellent discharge performance.
  • Dimension:
  • Length 143.7mm/5.66inch
  • Head diameter 36.0mm/1.41inch
  • Body diameter 25.4mm/1.0inch
  • Weight: 125g /4.4oz(exclude battery)
  • Accessories: Operator’s manual, Spare O-rings, Spare Tail cap Rubber Boot, USB cable, clip, lanyard
UI
Simple tactical mode (the main light flashes 3 times when switching to this mode):
When the tail switch is locked on:
Click the side button to change brightness : Low L1 – Medium M1 – High H1 – Turbo T1, Cycle;
Quickly double-click the side button directly into the S1 Strobe, click back to last used brightness;
Hold press the side button 0.5 seconds into turn off state:
Click side button to Turbo T1 brightness; Quickly double-click to S1 Strobe; Hold press side button 0.5 seconds to Low L1 brightness;
When Full press tail switch turn off:
Full Press tail switch again turn on to memory last used setting.
《《《《《《《—————-Hold Press side button 3 seconds to switching ——————–》》》》》》
Extended multi-mode (the main light flashes 1 time when switching to this mode):
Quickly double-click the side button to switch Sub-level(i.e between L1 & L2), turn off memorized the last used brightness.
When flashlight in brightness mode, quickly triple press the side button to Strobe (S1), then double-click to switch S1/S2/S3 mode, Press side button back to previous brightness Or turn off memorized the previous brightness.
Click side button to last used brightness; Quickly double-click to Turbo brightness; Hold press side button 0.5 seconds to Low brightness; Quickly triple press the side button to Strobe mode.
Credit to Skilhunt.com
Edited by: freeme on 05/10/2017 - 23:39
freeme
freeme's picture
Reserved.
tantrik77
Last seen: 6 months 1 week ago
I think this looks awesome. I will be buying one for sure if they offer a NW option. I love Skilhunt products. An XHP35 HD in NW with this form factor is perfect for me.
I see the new S2 Pro has NW options for the HI and HD emitters. Will the S3 Pro offer tint choices for both emitters as well? I sure hope so.
Will you be getting any codes or doing a group buy on this or the S2 Pro? They are both already listed for pre-order at Gearbest.
EasyB
Last seen: 1 day 1 hour ago
Performance is a bit underwhelming, but looks like a nice light nonetheless. You could get pretty much the same performance as the HI version (output and beam intensity) from a convoy M2 with XPL HI and FET driver.
Box
Last seen: 1 month 4 weeks ago
Freeme any code for this light? Thanks mate
freeme
freeme's picture
It will be on my list soon. cool
Bruno28
Last seen: 1 month 3 days ago
Interested if well priced. Thanks Smile
Bruno28
when will this one happen? Smile
blueb8llz
Last seen: 3 hours 49 min ago
Anyone got this light yet? Curious on the performance. Was thinking this light or Jaxman x1s
casi29061965
Last seen: 6 hours 29 min ago
Interested.
cyropro
Last seen: 5 hours 36 min ago
Looks interesting. I’d take one depending on price
Rusty Joe
Rusty Joe's picture
Last seen: 1 week 2 hours ago
How long does it stay in turbo?
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
BobTB
Last seen: 16 hours 55 min ago
I recently bought one of these torches, and I’m a bit disappointed actually. My stock Convoy C8 xp-l hi is outperforming it. I’m using NCR18650B in it, and was wondering if it will improve with a Samsung 30Q maybe??
HunterDan
Last seen: 11 months 1 week ago
I need help finding a flashlight! not sure how to do this forum thing. I am a hunter and I am looking for a good flashlight for darkness, tracking, distance. Any help would be appreciated. was thinking about the Skilhunt S3 Pro but I am not a flashlight enthusiast so I couldn’t tell you if that would be good or not. Please help!
BobTB
G’day HunterDan, I have been using Klarus G35 for spotlighting. It has been the best light I have used so far. The thrunite TN42 outperforms the klarus but is a bit heavy and bulky. If you want a bit smaller and cheaper than klarus, try Utorch UT02. Also I use a Convoy C8 xp-l hi for a rifle mounted torch with a rat-tail switch.
vidramon
Last seen: 1 day 12 hours ago
Hi, you can see review of this light :
http://budgetlightforum.com/node/56645
and here
http://budgetlightforum.com/node/55123
Do you want to mount a light on your rifle ? On how much meters you shoot in the target ?
