Suggest to me a UV Flashlight for US Currency
90 posts / 0 new
ARsee
ARsee's picture
Last seen: 1 week 3 hours ago
I want to buy a 18650 UV flashlight that best fits the role of checking US Currency Authenticity.
Jaxman, Convoy and Nitecore are some I have briefly looked at online.
After my posting this I will look into UV options further.
Those with hands-on experience/suggestions are who I am hoping to hear from.
Added
I want the best "out of the box" factory UV light that serves the intended purpose, over long term.
*NailBender lights are not a consideration*
Edited by: ARsee on 05/11/2017 - 14:43
BazzH
Last seen: 1 day 8 hours ago
I’ve got the Convoy S2+ with Nichia UV LED and the “black” filter lens. Highly recommended. Can’t beat Convoy S2+ on quality.
mortuus
mortuus's picture
Last seen: 7 hours 49 min ago
only downside on the convoy is that the light is overdriven so if u run the light too long u can damage the LED otherwise a good light for sure.
otherwise Jetbeam has a small one, runs on 1xAAA battery.
...where Frugal meets with Flashlight!
ARsee
ARsee's picture
I have edited my OP above to be more specific.
Thank you for the replies!
BazzH
The convoy is very good for EURO’s checking, so it should be good for US currency too. I checked my driver’s licence and ownership cards with it and was surprised how many UV tricks are in that too. For this money, it’s a no-brainer at banggood
ARsee
ARsee's picture
Is there a UV flashlight that is highly visible in daylight, or are they best suited in darker light only?
IIRC when traveling, airport security checks ID and passport with UV? They hold the light very close for inspection.
zachary6227
Last seen: 1 month 1 week ago
atbglenn
atbglenn's picture
Last seen: 32 min 39 sec ago
I have one for about a year now (with the filter and short tube ), and so far it’s been reliable. That said, I only use mine for a minute or so each time. Here’s a picture illuminating the pickguard on my bass in a darkened room with the S2+
ARsee
ARsee's picture
OK, atbglenn. I'm impressed by the one you have, image wise. Thanks for the photo!
So, these types of LEDs can not be used extended lengths of time or they burn out?
I don't understand. I assumed the UV could be used for crime scene investigations, checking for bodily fluids and such?
Are they being used intermittently under these conditions as well? Or, are those lights more of a special design and application?
As with all my purchases, I want the best I can get for money spent.
Lazy-R-us
Last seen: 10 hours 9 min ago
I think the ‘problem’ is that the Convoy is OVERDRIVEN. Which is fine if you want lotsa light for short periods of time, but will cause premature failure if used for extended periods. Similar to a ‘regular’ light run in turbo too long.
I don’t know if there is a lower mode available for the Convoy, or if it would require a driver swap to keep it in the green.
Lazy-R-us
ARsee
ARsee's picture
That's what I'm wanting to know as well. In real time use, what's the bottom line of these things, longevity wise without depreciation in performance
Thanks for bringing what you mention to the table.
Added
I want the best "out of the box" factory UV light that serves the intended purpose.
mortuus
mortuus's picture
sadly only 1 mode on convoy…
Speed4goal
Last seen: 5 hours 37 min ago
The convoy uses 7135 chips right on its UV light? Could unsolder one of the chips to lower the mode. Or if you contact Simon at convoy and order through him he can do it for you
djburkes
djburkes's picture
Last seen: 3 months 3 days ago
Check this thread out…djozz tested several uv leds. I built a UV light using a black Convoy S2+, a 1.5a mtn buck driver, and a Liteon LTPL-C034UVH365 led. It only has one mode but I build it for curing NOA61 when installing trits. It can be used with the standard 18650 tube or the 18350 shorty tube. I also used a black UV pass filter. She puts out a lot of nice UV light. I still have a few of those leds and UV pass filters…I’d build you one for cost of parts.
Here’s a couple of pics taken of a public restroom.
-X3-
-X3-'s picture
Last seen: 15 hours 51 min ago
Don’t worry, these ugly stains are probably détergeant Smile
I checked my bathroom at home and get the same !
"Hey -X3-, do you have a flashlight ?"   "-X3-, can I borrow one of your flashlights ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire : 30+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
LightRider
LightRider's picture
Last seen: 15 hours 27 min ago
X3 wrote:
Don’t worry, these ugly stains are probably détergeant Smile I checked my bathroom at home and get the same !
Seriously though! Is that detergent? Please say yes!
djburkes
djburkes's picture
Yeah, my washing machine looks a little rough. I scared the crap out of my daughter…I put laundry detergent on my hands and put hand prints coming from her closet across the ceiling in her bedroom and down the wall to her bed. I showed her what the UV light could do so I told her to take to her bedroom to see what all would fluoresce and she started screaming Evil
ARsee
ARsee's picture
djburkes wrote:
Check "this":http://budgetlightforum.com/node/45696 thread out...djozz tested several uv leds. I built a UV light using a black Convoy S2+, a 1.5a mtn buck driver, and a "Liteon LTPL-C034UVH365 led":http://www.mouser.com/Search/ProductDetail.aspx?R=LTPL-C034UVH365virtual.... It only has one mode but I build it for curing NOA61 when installing trits. It can be used with the standard 18650 tube or the 18350 shorty tube. I also used a black UV pass filter. She puts out a lot of nice UV light. I still have a few of those leds and UV pass filters...I'd build you one for cost of parts.
Put me down as accepting your offer, DJ. I have no problem with letting you build me one.
PM me for any further correspondence needed.
That bathroom image, I was a custodian at a Community College. Adults are just as DISGUSTING as kids!!
I don't buy the comment being detergent. On the toilet, yes, some of it. Now imagine that filth spreading throughout the whole facility on anything you may come in contact with throughout your time there. The filth IS everywhere.
Since my time way back as a carpet cleaning tech, I experienced everything imaginable from urine, to excrement of dead people of every form.
LightRider
Notice how the cleanest part of the toilet is the seat…
ARsee
ARsee's picture
It's the angle of the light..LOL!!
When you see a dark spot moving on the seat, shoot from afar!!
PM responded to, DJ Wink
Herb Tarlek
Herb Tarlek's picture
Last seen: 2 weeks 1 day ago
Brilliant.
I want a cool white light about as much as I want Cool Ranch Soda.
"Gerecht pointed his light. Like us, he was carrying an eyeball-melting flashlight that carried for a long ways. Monster Hunters wanted all the lumens." --Larry Correia, Monster Hunter: Siege
patmurris
patmurris's picture
Last seen: 14 hours 56 min ago
If you are not familiar with UV lights and applications you should probably do some research.
My modest understanding is that fluorescence occurs at different wavelength depending on the substance or material. Thus crime scene investigators probably want powerful lights that can reveal a broad range of fluids and materials with a wide range of wavelength.
However, for currency checking, i would guess you don’t need something very sophisticated or powerful. Some cheap UV/purple light may be enough?
One thing to keep in mind is that using a UV light for an extended time does require protection glasses.
I tend to think a Convoy UV S2+ is overkill for what you need. Just occasionally playing with mine a few minutes gives me a head heck.
You should check what wavelength are recommended for your application.
Jerommel
Jerommel's picture
Last seen: 1 month 15 hours ago
No.
You ‘need’ a true 365nm UV LED plus a filter (to block the visible light coming from the LED) to really see the fluorescent bits.
Cheap 400nm LEDs do not do the trick for money detection and the like.
On another note, unfortunately UV LEDs have a rather high Vf.
Like close to 4 Volts.
So the fun is over pretty soon with a normal linear driver (like with 7135 current regulators)
Best would be an AA light with boost driver and current regulation, as to not exceed the maximum current.
So for example, the little Jetbeam would be ideal, but it doesn’t have the filter in it, and i have only seen tiny ones for ridiculous prices…
You could buy a 20.5 mm filter and make it smaller and try to put it in the head… Hmmm… Tired
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
KelG
Last seen: 2 weeks 6 days ago
Supfire has an AAA 365nm flashlight.
http://cnsupfire.en.alibaba.com/product/60544855199-803424572/High_quali...
Not sure of its performance, though.
BLF = Buy Lotsa FlashlitesLaughing
ggf31416
Last seen: 8 hours 53 min ago
There is also the non-nichia jaxman u1 (18650) and jaxman e3 (aa). The uv output is lower than the convoy (There were some tests where the difference was quite visible) but they are still close to 365nm and have a filter (they are available at the
Jaxman store)
Lateck
Last seen: 1 month 16 min ago
I just recently got the Nitecore CU6. Not real bright in the UV area but it works well. In my research it has been one of the best fot looking at bank notes (money).
Most threads here and on CPF are a few years old at best.
The Convoy with the proper led has been noted as the best dollar value.
My reason for the CU6 is that it can do UV and be a carry light both.
My 2 cents, Lateck.
LightRider
Wow! 3000mW of 365 UV. Impressive.
AnhTran
Last seen: 1 hour 19 min ago
Anyone know how is the strength of UV light from the Convoy in comparison with UV component of the sun?
Hugh Johnson
Hugh Johnson's picture
Last seen: 3 hours 58 min ago
ARsee wrote:
That’s what I’m wanting to know as well. In real time use, what’s the bottom line of these things, longevity wise without depreciation in performance
Added
I want the best “out of the box” factory UV light that serves the intended purpose.
All led’s depreciate in performance. From what I understand the lifespan rating isn’t to failure. Rather, it’s to 50% brightness.
Mkduffer
Last seen: 2 days 5 hours ago
I have both the Convoy S2+ and the Jetbeam Jet-UV. I also own an Nitecore Tube-UV and a Ultrafire WF-501B.
I’ve tested these on $10, $20, $50 and $100 bills. Didn’t have a $5 in my wallet.
I bought the Convoy and UF at the same time. The Convoy was clearly superior but both were too big to conveniently carry on a daily basis, which is why I bought the Nitecore. I checked the specs and the Nitecore is supposed to emit at 365nm. This surprises me as I wasn’t impressed with it. Ended up giving it to my daughter, so I can not honestly say I compared it directly against the others, but I also recall that I ordered the Jet-UV specifically because I wasn’t impressed with the Tube-UV. Take it for what it’s worth.
I don’t know for certain, but I think the Ultrafire that I own emits at around 390 nm. It easily fluoresces the strips in the $10, $20 and $50 bills, however with the new $100’s, the strip was not illuminated in a significant way. From the back, the strip is barely visible in certain spots.
Both the Convoy and the Jetbeam were able to fluoresce all of the currency notes in my test group. Holding the Jetbeam about a foot from the notes, I’m easily able to see the glowing strip. It’s more evident in low light, but even under direct fluorescent light, I’m able to make out the strip. In my kitchen, under what I estimate to be approximately 50 footcandles, I’m still able to detect the strips. It’s faint with the Jetbeam, but detectable. If I move the light to within 3 inches, the strip is easily visible. I’m running an older Sony NiMH AAA battery which only has about 300 mAh capacity remaining, but for what I do, works fine. Waiting for the battery to die so I can replace it with an Eneloop. Big Smile
I realize you said you wanted something powered by 18650, but if you can be swayed from that, you might consider the Jetbeam. Otherwise, I like my Convoy. The UF can be purchased in a 365nm version, but I don’t have any experience with it.
People say I’m a flashaholic like it’s a bad thing…
jon_slider
Last seen: 1 hour 14 min ago
Both the convoy and the Cu6 have 3000mW 365nm UV
The tube claims to be, but is not actually 365nm, it won’t fluoresce the red strip on a US 100, the other two above will.
Both the Convoy and the Jetbeam were able to fluoresce all of the currency notes in my test group. … It’s faint with the Jetbeam, but detectable. If I move the light to within 3 inches, the strip is easily visible.
great to hear there is an AAA option with a true 365nm UV, even if it is very low power compared to the 18650 models
Convoy S2, Cu6, are both 3000mW 18650 powered
HDS has a 700mW version that is CR123 powered
