LED Package/ Die Sizes - WIP -
36 posts / 0 new
CRX
CRX's picture
Last seen: 19 hours 55 min ago
I am looking to put together information about the substrate and actual die sizes of the LED's that we use in our lights.
Any help with this resource would be greatly appreciated and save me some hours of time searching.
So if you know any numbers or have any failed de doming attempts and digital calipers laying around then you can help me put this table together Thumbs Up
Feel free to point out any mistakes or suggestions .
So far we have:
~~~~~~LED.Name~~~~~ ~Package.Size~ Diagonal.Max Total.Height Substrate ~Dome.Dia~ ~Die.Size~mm~ ~Die.mm2~ Köf3.Tests Djozz.Tests TA.Tests
Cree MT-G2 9.11 x 9.11 12.90 4.85 0.65 8.30 4.47r 15.70 @ @ ~
Cree XHP70 7.00 x 7.00 9.90 4.49 0.73 7.00 3.92 x 9.92 30.57 @ @ ~
Cree XHP70.2 7.00 x 7.00 9.90 4.34 0.56 7.00 5.61 x 5.61 31.52 @ ~ @
Cree XHP50 5.00 x 5.00 7.07 3.58 0.73 5.00 4.67 x 4.67 21.83 ~ @ @
Cree XHP50.2 5.00 x 5.00 7.07 3.50 0.65 5.00 4.82 x 4.82 23.22 ~ @ @
Cree XHP35 HD 3.45 x 3.45 4.87 2.80 0.65 3.45 2.35 x 2.35 5.52 ~ ~ @
Cree XHP35 HI 3.45 x 3.45 4.87 1.00 0.65 Flat 2.43 x 2.43 5.90 ~ ~ ~
Cree XM-L 5.00 x 5.00 7.07 3.02 0.73 4.34 1.97 x 1.97 3.88 ~ ~ ~
Cree XM-L2 5.00 x 5.00 7.07 3.02 0.73 4.10 1.98 x 1.98 3.92 @ @ @
Cree XP-G 3.45 x 3.45 4.87 2.00 0.73 2.60 1.40 x 1.40 1.96 ~ ~ ~
Cree XP-G2 (OLD) 3.45 x 3.45 4.87 2.36 0.83 2.60 1.29 x 1.29 1.66 ~ @ ~
Cree XP-G2 (New) 3.45 x 3.45 4.87 2.26 0.73 2.60 1.47 x 1.47 2.18 ~ ~ ~
Cree XP-G3 3.45 x 3.45 4.87 2.26 0.73 2.90 1.44 x 1.44 2.06 @ @ @
Cree XP-L HD 3.45 x 3.45 4.87 2.68 0.58 3.42 2.03 x 2.03 4.13 ~ @ @
Cree XP-L HI 3.45 x 3.45 4.87 1.00 0.58 Flat 1.91 x 1.91 3.67 @ @ @
Cree XP-L2 HD 3.45 x 3.45 4.87 2.68 0.58 3.42 1.88 x 1.88 3.55 @ ~ @
Cree XP-C 3.45 x 3.45 4.87 2.00 0.73 2.60 0.66 x 0.66 0.44 ~ ~ ~
Cree XP-E 3.45 x 3.45 4.87 2.00 0.73 2.60 0.92 x 0.92 0.85 ~ ~ ~
Cree XP-E2 3.45 x 3.45 4.87 2.26 0.73 2.60 0.92 x 0.92 0.85 @ @ ~
Cree XP-E2 Torch 3.45 x 3.45 4.87 2.26 0.65 2.60 1.41 x 1.41 2.00 @ @ ~
Cree XR-E EZ900 9.00 x 7.00 11.40 4.40 ~ 6.80 frame 0.85 x 0.85 0.73 ~ @ ~
Cree XR-E EZ1000 9.00 x 7.00 11.40 4.40 ~ 6.80 frame 0.96 x 0.96 0.92 ~ ~ ~
Lumileds Luxeon V 4.00 x 4.00 5.66 2.70 0.50 3.60 ? ? ~ @ ~
Luminus SST-40 4.95 x 4.95 7.00 2.4 0.60 4.52 1.99 x 1.99 3.99 @ @ ~
Luminus SST-50 9.00 x 7.30 11.60 4.30 0.75 5.60 2.25 x 2.25 5.00 @ ~ ~
Luminus SST 90 11.00 x 10.00 14.87 5.40 0.90 8.00 3.0 x 3.0 9.00 ~ ~ ~
Luminus SBT-70 11.00 x 10.00 14.87 1.54 0.68 8.92 frame 3.00r 7.00 ~ ~ ~
Nichia 219A 3.50 x 3.50 4.95 2.00 0.40 2.90 ? ? ~ @
Nichia 219B 3.50 x 3.50 4.95 2.00 0.40 2.90 1.48 x 1.48 2.20 ~ @ @
Nichia 219C 3.50 x 3.50 4.95 2.00 0.40 2.90 1.35 x 1.35 1.82 ~ @ @
Nichia 319AT 3.50 x 3.50 4.95 2.10 0.40 3.10 ? ? ~ ~ @
Osram Oslon Flat Black 3.85 x 3.65 5.30 0.60 0.40 Flat 1.10 x 1.10 1.05 @ @
Samsung LH351A 3.50 x 3.50 4.95 1.89 0.70 2.69 ? ? @   ~
Samsung LH351B 3.50 x 3.50 4.95 1.93 0.43 3.22 ? ? ~ @
Samsung LH351D 3.50 x 3.50 4.95 2.33 0.43 3.65 ? ? ~ ~ @
Edited by: CRX on 12/16/2017 - 06:42
The Miller
The Miller's picture
Last seen: 10 months 4 weeks ago
Awesome, this should be stickied, hint hint Wink
CRX
CRX's picture
Maybe once it’s finished, if people help to fill it out Wink
This will be part of my LEDs & Other Stuff thread but should also prove useful as a standalone.
leaftye
I suggest adding XB-D. We don’t use it in our flashlights, but many automotive lights use them.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
mattlward
mattlward's picture
Last seen: 3 weeks 6 days ago
Can you change the colors? I seriously can’t read that! Good dataset!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
MRsDNF
MRsDNF's picture
Last seen: 11 hours 11 min ago
Looks good CRX. Maybe include the voltage of the leds as well?
FlashMax
FlashMax's picture
Last seen: 8 months 3 weeks ago
Hi all, I found this and seems interesting at least to me, but maybe the experts he can go further.
http://www.unistars.com.tw/download/1515_WH.pdf
Max
Jerommel
Jerommel's picture
Last seen: 5 months 5 days ago
Die size in mm² would be nice.
The Miller
1.5*1.5 LED
0.6*0.75 die
luminous flux 120/110 @350mA
3.3V
5000 and 5700K
djozz
djozz's picture
Last seen: 9 hours 26 min ago
Nice project!
At least the XP-G die size is not correct yet, it is very close to 1.5 × 1.5 mm.
When I have time I will measure some leds for the table
The_Driver
The_Driver's picture
Last seen: 8 hours 46 min ago
Measured DIE-sizes of many well known LEDs can be found here (it's in German) and in other threads/posts of sma (he is also a member here on BLF). He even subtracts the area of the DIE where the Bond-Wires are.
Here are some interesting ones (all without dome):
Cree XR-E EZ1000: 0.92mm^2
Cree XR-E EZ900: 0.73mm^2
Cree XP-C: 0.44mm^2
Cree XML: 3.9mm^2
Cree XM-L2: 3.94mm^2
Cree MT-G2: 15.7mm^2
Cree XP-E2: 0.85mm^2
Cree XP-G2 (old 1st version 2012-2015): 1.66mm^2
Cree XP-G2 (2nd version, 2015, the ones that luminarium iculator likes so much): 2.18mm^2
Cree XP-L: 4.13mm^2
Cree XP-L HI: 3.67mm^2
Cree XHP-35 HI: 5.9mm^2
Nichia 219B: 2.2mm^2
Also some are easy to find elsewhere.
Luminus SST-50: 2.25mm x 2.25mm = 5mm^2
Luminus SST-90 & SBT-90: 3mm x3mm = 9mm^2
Luminus SBT-70: circular, 7mm^2
Luminus CBT-140: circular, 14mm^2
Some guesses from me:
Cree XHP-70: 4 x XP-L
Luminus CSM-360: 4 x 3mm x 3mm = 36mm^2 (largest power led array?)
mrheosuper
Last seen: 1 month 1 week ago
Didnt know that sst-90 is such that big
I always thought it’s same size of mt-g2
Forgot my pen
The_Driver
mrheosuper wrote:
Didnt know that sst-90 is such that big I always thought it’s same size of mt-g2
The SST-90 ist much smaller than the MT-G2…
Agro
Agro's picture
Last seen: 34 sec ago
So XP-L HI and HD have different dies?
Seems to contradict exactly the same voltage characteristic…
CRX
CRX's picture
Always looking for better information…
Lothar
Lothar's picture
Last seen: 17 hours 12 min ago
Here are some of the SST-40 properties I could find. Still looking for die size though
Package Size: 4,95 × 4,95 mm
Diagonal Max: 7,00 mm
Total Height: 2,86 mm
Dome Diameter: 2,26 mm
Die size: ???
Source: http://www.luminus.com/products/Luminus_SST40W_Datasheet.pdf
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
Agro
Agro's picture
The SST-40 datasheet above actually specifies die size. It’s called “LED Emission Area” and it’s 4.0 mm.
Enderman
Enderman's picture
Last seen: 4 days 2 hours ago
4mm squared.
The die size is 2mm x 2mm.
Agro
Agro's picture
CRX, could you add SST-40 to the first post?
CRX
CRX's picture
Yeah I’ve been meaning to update this.
Agro
Agro's picture
Using a picture from djozz:
Coupled with WebPlotDigitizer I calculate LH351D die size to be 2.166*2.166 mm or 4.69 mm².
ADDED:
Also, XHP35 HI was measured to be 5.32 mm² actually:
http://budgetlightforum.com/node/58076
ADDED:
And Luxeon V is 6.43 mm²:
http://budgetlightforum.com/node/58842
CRX
CRX's picture
Thanks mate.
JasonWW
JasonWW's picture
Last seen: 6 hours 28 min ago
CRX, I was noticing some odd things concerning the xhp70, 70.2, 50 and 50.2 Die.mm2. or die area.
For instance, the 70.2 is just 4 x xml2 (I think) so the total surface area would be like in your old chart 15.68 mm^2. Why does you new chart show a much larger area of 31.52 mm^2?
CRX
CRX's picture
I keep meaning to come back to this to update it, I think I copied those numbers are from koef in this post. LES not die size probably.
“The total light emitting surface (LES) area of the XHP70.2 is 31.52 mm² (0.0489 sq in) in size. The four single dies are 7.88 mm² (0.0122 sq in) each.”
The_Driver
Those numbers are probably with and without dome (half).
JasonWW
JasonWW's picture
The xpl Hi, HD and xhp35 Hi, HD don’t show a huge difference.
The_Driver
The difference is basically the same for 99% of all standard LEDs. The dome doubles the apparent die size.
JasonWW
JasonWW's picture
I believe the dome increases the apparent die size by about 50%, not 100%. Look at the examples I mentioned, there is no big increase at all, much less doubling.
Overall, you’re missing my point. The LES should not be on the chart. We want the actual die size like length times width. Perhaps another column can be made to show LES or the effects of the dome.
CRX
CRX's picture
Noted Thumbs Up
The_Driver
Nope, definitely 100% (lets say 80-120%). This has been measured by multiple people, see here for many examples.
But I get your point. I was thinking about the pictures. Sorry. Smile The numbers in the chart are wrong for some of the larger Cree LEDs.
CRX
CRX's picture
Corrected values welcome too..
