Test/review of Arcas AA 2700mAh (Silver-red)
Official specifications:
  • Voltage: 1.2V
  • Capacity: 2700mAh
  • Size: 14.4 x 50.1mm
Maximum temperature raise at different discharge currents: 1A:+0,7°C, 2A:+1,4°C, 3A:+3,2°C, 5A:+4,1°C, 7A:+4,5°C, 10A:+0,1°C
The high capacity NiMH cell from Arcas.
Not much capacity, one of the cell improved a bit after some cycles, its peak performance was at 3A where it could deliver 0.5Ah.
Conclusion
These cells do not work, the rating is bad
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
These are the worst batteries I have ever seen!
edit: here is the 800mAh version.... https://budgetlightforum.com/t/-/45470
both dont look good.
Thanks for the test HKJ!
Wow that is horrific. At first I thought those numbers had the decimal in the wrong place!
