My Convoy L6, lighted switch, TA FET driver plus mods
127 posts / 0 new
rizky_p
rizky_p's picture
Last seen: 3 days 17 hours ago
JasonWW wrote:
Yeah, that can do it.
Thanks for the Help Jason. Thumbs Up
My convoy L6 does feels like Giant D4 now.
JasonWW
JasonWW's picture
Last seen: 34 min 38 sec ago
There’s a lot more features though. Like memory in ramping mode. Did the D4 have batt check, 3 fast clicks? I like that one.
Click this to go to signature links.
rizky_p
rizky_p's picture
Jason i wonder do you ever sleep? i just woke up few hours ago and fetch kids to school and here you are still answering question. Big Smile
Got to try that memory in ramping mode thingy I read the narsilM manual, but to be honest i am rather bewildered i am sure i’ll get the hang of it someday and yeah D4 also have batt check since it is basically a scaled down narsilM right?
As far as ramping and normal operation goes it feel similar to D4, i just feels that D4 output is severely limited by its size i dont have that feeling with Convoy L6.
JasonWW
JasonWW's picture
I usually sleep days and work nights. Plus it’s my day off so nothing much to do.
A lot of stuff was cut off of the D4 firmware. Memory in ramping is exactly what you think. You turn on the light, adjust to the brightness you want, then turn off light. Next time you turn it on, it’s at the same level. I tend to use both of my sig lights at about 75% (?) of turbo. It’s almost full brightness, but run cooler and last longer. After that’s it’s click on, bam, click off. Over and over again.
I do security work at night, so I’m always using my lights.
JasonWW
JasonWW's picture
Here’s my video on changing settings in NarsilM.
https://youtu.be/xrwP3gG0I_A
Here’s my video showing a few basic narsil stuff.
https://youtu.be/F_Vm5mq99TQ
I’m gonna do another video showing all the features of Narsil soon.
rizky_p
rizky_p's picture
ah i see no wonder Big Smile ,
I guess you have a perfect job for the hobby and that L6 sure fits the job nicely, i never found a really useful stuffs for my lights as i lives in the urban area and every corners are nicely lit up, i need to make an excuse to use them Innocent
btw. my TA driver doesn’t have “indicator light” feature as the pin is currently use as voltage reference so i just use the LED side button instead as power on indicator just like you did. Now few more weeks for my transparent side switch from Simon to arrived.
rizky_p
rizky_p's picture
the one using Supfire helps a lot.
thanks.
JasonWW
JasonWW's picture
Yeah, I forget why sometimes. It’s because the 2S design needs that extra leg on the mcu to read actual battery voltage (not the lower voltage the LDO produces for the mcu to operate on). Jeez this stuff is technical. Lol
You can give up low voltage protection to have the indicator feature, but that’s not smart. Lvp is more important.
rizky_p
rizky_p's picture
yeah that is true but you know we like LED even the small one. Wink
JasonWW
JasonWW's picture
I didn’t say LED, I said “indicator” feature. You can still have basic LEDs for the switch, but you don’t need the fancy programmable switch LEDs.
steel_1024
steel_1024's picture
Last seen: 1 day 12 hours ago
Thank you, JasonWW
XHP70.2 5000K
moon
moon
Sorry for my poor english.
JasonWW
JasonWW's picture
Very cool. I see you chose the thickest part of the switch hole to file your grooves in. The top and bottom are thinnest and a lot quicker and easier to file. No big deal, though.
Also, be prepared for people to try and buy it from you. Lol
rizky_p
rizky_p's picture
i did try filing the switch hole but found out that the one i tried was thick so i cancel that, didn’t know there is a thinner part.
JasonWW
JasonWW's picture
I thought I mentioned it, but I might not have. Anyway, I updated my original post with that information.
It’s very easy and quick to file the top and bottom lips because they are very thin. Check this pic to see how thin it is.
rizky_p
rizky_p's picture
ok i just add the SMD LED on the side switch pcd i am using 1206 SMD LED, now all i need to do is to wait for transparent side button.
I am using 8.7K resistor with parasitic draw at the tail of about 0.8mA, with 4200mah battery this should last for about 7 months and still plenty bright at night.
thanks for all the help .
Nicolicous
Nicolicous's picture
Last seen: 11 min 48 sec ago
nice work guys.
going to do my switch this weekend
Nico -.-
Texas_Ace
Texas_Ace's picture
Last seen: 14 hours 51 min ago
Where did you get the lighted switch pcb?
Looking for options to do this with the GT.
Nicolicous
stock light PCB already have the slots for 1206 SMD LED Big Smile
Nico -.-
ZozzV6
ZozzV6's picture
Last seen: 3 days 3 hours ago
I also build a clear L6 with XHP70.2 and TA driver, SMO reflector and lighted side switch. Insanely bright! Aaaand Hot!
Newlumen
Newlumen's picture
Last seen: 1 week 6 days ago
Do you happen to have the lumen and lux ? Thanks
rizky_p
rizky_p's picture
i thing i’ll get an SMO reflector but does 70.2 worth it?
ZozzV6
ZozzV6's picture
7740 lumens and 145700 Cd at 17,2A
JasonWW
JasonWW's picture
I’m not sure what you’re asking here but the Smo reflector basically just focuses it a little better to give you a smaller hotspot and more throw. You practicaly can’t see any dark center with the Smo and 70.2. You only see it in photos if you reduce the exposure.
rizky_p
rizky_p's picture
What i meant was, the SMO is cheap and will increase throw, and the 70.2 is around $13 but will it increase lumens with the same current draw? At the end both will increase candela. I know that 70.2 have better high current handling and less prominent cross.
JasonWW
JasonWW's picture
Okay, so you currently have the OP and xhp70. I thought you already had the 70.2.
I’m kinda iffy on the 70.2. You don’t get more output at the same current, but you do get that extra turbo output (from 12 amps up to 17 amps) at the expense of more heat and quicker battery drain. I definitely prefer the color of the cool white xhp70 to the cool white of the 70.2.
I bought these parts to try and build a thrower out of the L6. Why are you asking about them, are you also trying to get more distance?
rizky_p
rizky_p's picture
JasonWW wrote:
I’m kinda iffy on the 70.2. You don’t get more output at the same current, but you do get that extra turbo output (from 12 amps up to 17 amps) at the expense of more heat and quicker battery drain. I definitely prefer the color of the cool white xhp70 to the cool white of the 70.2. I bought these parts to try and build a thrower out of the L6. Why are you asking about them, are you also trying to get more distance?
yeah that is what i meant. With current setup (TA driver, OP reflector, XHP70 and 10.5A draws) i only got 99kcd so i was wondering if 70.2 would make much different.
oh btw does 70.2 have lower forward voltage? was the 17A draw possible because of that? hmm that is interesting.
JasonWW
JasonWW's picture
Yes, it has lower forward voltage which is why you get higher amps when used with a fet driver.
rizky_p
rizky_p's picture
Nice. i might be getting XHP70.2 and give it a try and put my old XHP70 in a different light.
vwpieces
vwpieces's picture
Last seen: 1 day 1 hour ago
Hi Jason,
thanks for the lighted side SW tutorial.
Ordered the L6 Fet driver from MtnE a couple weeks ago with the D4 firmware. I got 10.1A after 30sec in my DMM.
Only had some 3.3K ohm resistors so I made a series cluster of 4 and shrink wrapped it. Think it was 12.8K ohm. Side SW Purple (kinda blue) LEDs are pulling about 0.5mA. Perfect at night and still see a glow indoors.
JasonWW
JasonWW's picture
vwpieces wrote:
Hi Jason,
Cool. I didn’t know Richard started offering the D4 firmware for that driver.
Does it have the memory feature?
Does it have dedicated pads for a switch light or did you just run it to driver positive and negative?
