My Convoy L6, lighted switch, TA FET driver plus mods
127 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 3 hours 58 min ago
Funtastic wrote:
Why does Simon rate his L6 so high at 3800 lumens? Is he just basing that on what the emitter can achieve?
My stock neutral white L6 is only pushing 2800 lumens with Keeppower’s.
Advanced Knife Guy on youtube rated his at 3278. Didn’t think my calibrated TA lumen tube would result in so much difference. Glad I’ve got something near accurate though
Maybe Simon paid someone to measure it and that’s what he was told. Or maybe he measured it on a device that read a bit high. It’s hard to say.
I think the stock CW version is around 3100 to 3200 lumen. NW versions might measure a bit less. They may not actually be less, but they will probably measure less.
I’m surprised AKG, mhanlen on this forum, got close to accurate numbers. The last I checked he was using a home built lumen tube type device without a calibrated light source.
Click this to go to signature links.
YogibearAl
Last seen: 10 hours 40 min ago
Jason,
Thanks to this post as well as Matt Smith’s I was able to boost my Convoy L6 and add LED’s to the side button. My Convoy side button has a slightly modified PCB, so not only did I need to jump the positive connection for the LED’s, I also needed to jump the negative circuit as well. I took a quick look at the traces and by default the negative blue cable no longer connects to the LED’s “-” circuit. Creating a jump from the blue cable to another spot on the board right next to it creates the common ground needed. Just FYI if anyone else is looking at the photos and wondering why it doesn’t work. It took a little testing to make sure I was indeed getting the positive signal to the LED circuit. I’ll post a photo later.
JasonWW
JasonWW's picture
YogibearAl wrote:
Jason,
Thumbs Up
My mod is a few years old, Convoy might have switched to a slightly different switch pcb.
YogibearAl
As promised here is an image of my latest Convoy L6 switch PCB. Apologies for the poor image. But basically the red line still follows the original post, the second blue line is the one needed to jump the ground to the negative poles of the LED location. If you have the new PCB, it won’t work without jumping this. The 2 larger contact points are also negative terminals, so you must be careful the red wire doesn’t touch it and short out the LED.
Final product,
JasonWW
JasonWW's picture
YogibearAl wrote:
It looks like they added a spot for a resistor. How convenient.
YogibearAl
Yeah I didn’t have a small resistor available so went with the in line method, but using a resistor here would be cleaner for sure.
