USB cable question
51 posts / 0 new
Yokiamy
Yokiamy's picture
Last seen: 47 min 55 sec ago
hIKARInoob wrote:
Yes. The “U” of USB stands for “Universal”. Some companies like Apple have their own standard indeed (not compatible). The only minor exception perhaps is the latest USB C type plug. But very few devices use this new format that require a different new cable. For example Samsung Galaxy S8, and Wuben T102 (only flashlight that I know of) use USB C.
Google pixel, as well as the Nexus 5x and my Nexus 6P Smile
Thijsco19 wrote:
a regular symptom of flasholism Big Smile
“Flasholism is the most severe form of flashlight use and involves the inability to manage your flashlight use habits. It is also commonly referred to as flashlight use disorder. Flashlight use disorder is organized into three categories: mild, moderate and severe. Each category has various symptoms and can cause harmful side effects. If left untreated, any type of flashlight use can spiral out of control.”
dodge_911
dodge_911's picture
Last seen: 5 hours 8 min ago
HKJ wrote:
The cable do not change the current, but many phones and other devices will reduce the charge current when the voltage drops due to a crappy cable.
I thought I said that in the next paragraph. I always laugh when they advertise a 3A cable Smile
:: youtube ::
http://bit.ly/dodgereviewsyt
:: blog ::
http://bit.ly/dodgereviewstmb
  :: powerbank capacity tests ::
http://bit.ly/drpbcc
:: μusb cable resistance tests ::
http://bit.ly/drmicrousb
:: lightning cable resistance tests ::
http://bit.ly/drlightning
 :: type-C cable resistance tests ::
http://bit.ly/drtypec
RollerBoySE
RollerBoySE's picture
Last seen: 2 days 23 hours ago
HKJ wrote:
dodge_911 wrote:
I beg to differ. Have tested a lot of cables, and none of them show a drop in amps, even really really crappy ones.
Exactly, and thus the charging time is affected considerably. Especially Apple drops the current quite a bit.
Barkuti
Barkuti's picture
Last seen: 2 hours 17 min ago
My custom cable uses 3 pairs of AWG24 (3 × AWG24 = AWG19.2623) wires for power transmission; this is 86.56mΩ of total wire resistance, or close to 260mV of drop when 3A of current flows through it. Bear in mind this is just for the cable! There are additional losses because of plug contact resistances (bottlenecks), which get worse with usage wear and tear. So even with my low drop custom cable such high rate would be problematic, I believe.
Honestly, lots of consumers are half-wits. Don't get me wrong, I may still be half-witted under certain circumstances. Problem is you really can't/shouldn't trust advertising (as a rule), but half-wits tend to. You know, when people buys UltraTurd 18650 9800mAh cells in bulk… Facepalm
Cheers Party
Venom
Venom's picture
Last seen: 8 hours 22 min ago
Thanks for all the replies!
Venom
Venom's picture
Just to update this thread. I went with the Anker Powerline Plus cable.
NeutralFan
NeutralFan's picture
Last seen: 2 days 20 hours ago
Anker seems to be a quality company. We have many of their products, all bought on Amazon. My son has an Anker bluetooth portable speaker that stopped working after close to a year after we bought it. They replaced it without an issue and the new one has been working great despite the abuse he puts on it.
I’d rather use my flashlight around the house than turn on the lights.
Venom
Venom's picture
I got my Anker cable from amazon and hopefully I will have no issue with them. By the reviews on Amazon any issue was taken care of by Anker without a hassle.
jerm03
Last seen: 4 days 3 hours ago
I do a lot of charging of my tablets. Currently the cables I have and the wall plugs are as “Slow as Christmas.” The Paracables are rather expensive. Are the Anker cables better in terms of speed of charging?
Jerry
RollerBoySE
jerm03 wrote:
I do a lot of charging of my tablets. Currently the cables I have and the wall plugs are as “Slow as Christmas.” The Paracables are rather expensive. Are the Anker cables better in terms of speed of charging? Jerry
I would say that Anker cables and Paracables are about equal when it comes to charging speed, and faster than cheap stuff.
jerm03
Thanks, I’ll get some.
Added: I found them on the WalMart website for $6.99 regular list price $29.00. They are 6 ft. I ordered 2 with no postage. $13.98.
Jerry
XXX-Man
XXX-Man's picture
Last seen: 1 hour 7 min ago
I ordered this Aukey set and they work perfect up to 2.4A (don’t have a device that can use more)
https://www.aliexpress.com/item/Aukey-5-Pack-Micro-USB-Cable-Fast-Chargi...
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F
blinker
Last seen: 2 days 6 hours ago
Good, inexpensive cables at monoprice.com,
Not a flashlight guru, but like them just the same.
Misspellers of the world UNTIE!!!
alpg88
Last seen: 2 months 23 hours ago
hIKARInoob wrote:
Hey Venom, At the same time this means that as an Apple consumer you are forced to buy their cable with a nice profit margin for Apple.
there are tons of third party apple comparable cables on the market, you do not need to spend $30 for apple cable, you can buy same cable in pretty much any store, for 5-10 bucks, here in nyc most stores have them by registers. some of them feel more solid than real apple cable, and they come in different colors.
RollerBoySE
The cheap cables works (most of them anyway).
But they typically charge slowly (especially iPads) and they don’t last very long.
I guess you get what you pay for.
No need to buy (expensive) Apple original though, just look for Anker and other MFI-certified ones.
alpg88
original apple ac to usb adapter outputs only 1A. that is not much current. you do not need thick wire for 1A.
also to be honest i do not think oem apple cable are such a great quality item to begin with, i had 2 fail. they are no better than most third party cables. but defiantly overpriced.
Venom
Venom's picture
I did notice a difference in charging speed with the Anker powerline + cable compare to the factory Apple cable. Its not a huge difference but a noticable difference.
RollerBoySE
It’s a bit more complicated than that.
iPhone 6 & 7 can be faster charged with the iPad charger (and third party chargers that supports the standard), which delivers 2.1A (the standard allows for up to 2.4A). But this only happens if the charger (and phone) determines that the cable (and everything else) can handle the higher current; otherwise the charging current is stepped down.
So there is a good reason to use a bit better cables.
MFI-certified ( https://en.wikipedia.org/wiki/MFi_Program ) doesn’t mean Apple OEM by the way, just that the cable fulfills some basic requirements.
My personal favorites are Anker and especially Paracable, this since I like sturdy cables that don’t break.
Pete7874
Pete7874's picture
Last seen: 2 min 38 sec ago
Difference for better or for worse?
Venom
Venom's picture
I got the 6ft. powerline + cable, it was better. Next I’m going to get the 1ft. or the 3ft. to see if that makes a difference. Plus I got the Apple 12w usb charger to, so that could be the different in speed to
