4x18650 light question
Hello everyone. In my job i am doing wall repairs and painting (mainly residential).
Often the exsisting lights have been removed, especially in the basement so i would like a lantern style light to keep the room lit up.
So far ive been making use of my single 18650 with ceiling bounce but the light gets hot in a jiffy and battery life is questionable. Do you have a recommendation on a 4x18650 light? Not planning on spending more than i have to (less than $100). A big bonus would be is i can put one of those white dome things on the light to make it less directional but its not a must, also usb charging would be real nice. I would also use this light outdoors for camping and such.
mucho danke in advance!
A soda can light with plastic drinking cup will do fine.
In the 4x18650 department, i suggest you have a look at the Q8 project which will essentially bring us a SRK on steroids (6000 lumen) for $40. But it won’t be available before a few month at least. A simple white plastic cup will make a decent diffuser. No usb charging though.
Did you consider one of those 10/20/50W flood projector that run off the AC? They are rather cheap and quite handy.
The product pictures on those are hilarious. Especially the “stadium lighting” :smiley: And the “explosion proof” part.
They look like nice little lights though. Do you have one? Do they compare well to typical 150W halogen spots?
I don’t have that much experience with them… I only have a 10W one i recently used while i was refurbishing a bedroom - painting mostly. I could work at night. A 30W would have been better, probably comparable to a 150-200W halogen - without the heat.
I quickly tried it outside and it does a nice job at lighting up a tree from below. I just saw some at 10 euro this afternoon. They are getting even cheaper. I can’t tell how long they last though. Time will tell. I’m guessing that swapping/replacing the COB led is rather easy… as for the electronic part…
FWIW :wink:
I have decided on a Haikelite MT07. I’ve been reading its a bit finicky with batteries, do any of you have suggestions what batteries are most suitable for it?
