UV LED help please.
7 posts / 0 new
vestureofblood
vestureofblood's picture
Last seen: 2 days 12 hours ago
UV LED help please.
Hi all,
This is a project I am working on for someone. They would like to cure this UV paint with a flashlight.
https://mail.google.com/mail/u/0/#search/365nm/15bca5d7acae99a3?projector=1
The emitters we will be using are 365mn, 395nm and eventually a 400nm.
I have some basic questions about working with these LEDs.
Safety
1. Exactly what eye protection do I need to be using?
2. What other safety concerns are there with this type of led?
Construction
1. Can I use traditional plastic optics like the 3x and 4x we use with common LEDs? I put a UV dropin of some kind in my old surefire 6p and it melted the acrylic lens.
2. Based on the above data sheet is it at all reasonable to think I can make a UV light strong enough to cure that paint using a battery pack of 3× 18650s? I don’t know how efficient regular UV bulbs are vs LED so what would be a 400 watt equivalent?
3. Do I need to spend hundreds of dollars getting a nichia or some expensive UV LED or are the budget ones from mouser and digikey just as good?
Thank you all in advance!
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
djozz
djozz's picture
Last seen: 23 min 11 sec ago
A 400W equivalent? Shocked
I don’t know about that. Current single die uv leds are 0.5 to 1W output power typically. But there are sime high output uv-COB leds out there with much more output. I do not know much about them and thus can not recommend one.
To answer some of the other questions:
-You do not need Nichia leds for maximum output, some cheaper leds have just as good output, but do not have such a clean spectrum, but that is irrelevant for use as a curing light. Search Digikey for LiteOn leds, they fit a standard XP-G pad.
-For 365nm, standard safety goggles made of polycarbonate block it almost completely. For 400nm leds you need the yellow glasses. You can always check glasses by shining the uv-light through the glasses onto a piece of copier paper, if it does not give the blue fluorescence, the glasses are ok.
-The efficiency of 365nm-400nm uv leds have improved drastically in recent years, in output power it is not far under the blue leds used in white leds.
-Carclo optics work well for 400nm, but block 365nm almost completely. Again check with the copier paper test.
djburkes
djburkes's picture
Last seen: 4 months 6 days ago
I purchased these for curing NOA61 using 365nm uv.
vestureofblood
Very helpful. Especially the bit about the LEDs that have an XPG foot print.
Thank you.
alpg88
Last seen: 2 months 4 weeks ago
would tanning goggles work?
vestureofblood
djozz
I found the Lite-On emitter in the 365nm but digikey doesn’t stock the 395nm. Are there any others your aware of that have a cree foot print?
alpg88
look for 3535 leds. many on ebay, xp footprint, thou they are hit and miss quality wise. i have few 395, as well as 400-405 iirc, i can send you 1 of each for testing, they worked fine for my purposes, they are on stars, but i unsolder them and use with triples. pm me if interested,
