CRX Brass Four
19 posts / 0 new
CRX
CRX's picture
Last seen: 55 min 39 sec ago
CRX Brass Four
Another wee brass build, this is built around a filed down Thrunite Ti brass pill and Efest 10440 with the usual hand tools – a hacksaw and a file.
Li-Ion Efest 10440
Max – 420lm
Eneloop NiMH AAA
Max – 70lm
Energizer Lithium
Max – 90lm
Length – 80mm
Width – 12mm
Weight – 31 grams (with cell)
This light has an XP-L HI v2 1A emitter on a 10mm sinkpad viewed through a TIR optic with cyan GITD detail.
Forward tail clicky and being the ti driver can be powered from the main four cell chemistries we use.
How it’s made
Edited by: CRX on 05/20/2017 - 11:07
mattlward
mattlward's picture
Last seen: 11 hours 7 min ago
Once again, amazing work!
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Olight S1A
Olight S1R
Boaz
Boaz's picture
Last seen: 52 sec ago
you make everyone else look bad …..
Jerommel
Jerommel's picture
Last seen: 1 month 17 hours ago
Thumbs UpThumbs UpThumbs Up
Where do you get pipes that fit snugly in eachother?
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
CRX
CRX's picture
It is K&S tubing, comes in brass, steel, aluminium and copper although I have only been able to obtain the brass & alu stuff here.
I think it goes up to around 16mm Metric and Imperial.
Each progressive size fits inside the next, great for these little projects.
Other larger tubing I use is search, mix & match.
Boaz
Boaz's picture
’tis most sweet When in one line two crafts directly meet.
CRX
CRX's picture
I can no other answer make, but, thanks, and thanks.
NeutralFan
NeutralFan's picture
Last seen: 4 hours 48 min ago
Another way cool build CRX! I like the totally encapsulated GITD LED and the brass looks great.
I’d rather use my flashlight around the house than turn on the lights.
MRsDNF
MRsDNF's picture
Last seen: 6 hours 42 min ago
Very nice. Does CRX wear glasses two inches thick to magnify miniaturisation up to a normal size? Silly
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
Boaz
Boaz's picture
It would make a nice giveaway light Smile oft good turns. Are shuffled off with such uncurrent pay
Dave G
Dave G's picture
Nice build, again. Love the polished look, tho the faded/tarnished look as it gets used is also cool.
scrumpypaul
scrumpypaul's picture
Last seen: 45 min 49 sec ago
Wow.
Brilliant again mate.
Will look even better when it’s as sweaty and tarnished as my beloved copper MK2 from your GAW which still hasn’t left my side!!!
Keep it up mate. Fantastic.
Paul
LightRider
LightRider's picture
Last seen: 17 hours 49 min ago
Hey friend! You’ve inspired me again. I’m am about to finish an S41s inspired and all polished up. I messed up the optic and have been waiting for a replacement before I put it up for sale. Well I’ll be waiting a little longer even as I just placed an order for some gitd powder. It’ll be my first experience with the stuff. Smile
CRX
CRX's picture
Thanks for all your comments Beer
That’s nice to know Thumbs Up
Cool, what will you mix it with? I would recommend a low viscosity clear silicone like this from FT as opposed to an epoxy on MCPCB’s.
When using the powders a larger grain size of strontium aluminate is better and don’t put so much on that it touches the optic.
You might also want to order some GITD sticky back plastic tape/ sheet, these are really good.
The tape is what I used in these builds
Cut a thin strip and stick to the inside of the head leaving clearance for the optic
LightRider
Ah, ok. I was going to mix it wth some uv curable glue. The stuff from fastech. Will clear silicone work better?
Suncoaster
Suncoaster's picture
Last seen: 17 hours 35 min ago
Location: Where the girls are green and the grass is pretty.
Beautiful !
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
The Miller
The Miller's picture
Last seen: 1 week 5 days ago
Very nice, as always something that makes my mouth water and my hands itch to touch Big Smile
CRX
CRX's picture
Aw man, you would have had fun with that!
The mix will need to be quite thick and so the particles block the UV light, it won’t set all the way through – leads to a messy disaster LOL
Yeah silicone is best where it will be in contact with a lot of heat I think, unless someone has a better idea.
Do some experimentation before doing your lights Wink
leroycp
Last seen: 1 hour 19 min ago
Beauty in brass. You got skills
