Help finding a host
Hey guys,
I need help finding a host that will accept the 17mm brass pillar from fast tech SKU:1208600.
I ordered them for a gift build to go in an Ultrafire C8. Either their info is wrong and they don’t fit or I’ve had a fake. The SKU for the host they say is compatible is out of stock.
For some reason I can’t copy and past the link to the pill.(on iPhone)
Any help is greatly appreciated as everything I have purchased is based around this pill as I want to give the light interchangeability but with a larger reflector than a standard P60 drop in.
As a last resort is it possible to get a P60 drop in that accepts a 20mm star as all the LED’s I have for this build are on 20mm stars and I have no 16mm ones to reflow onto.
Thanks
Thom.
Hey mate i bought some of these and they fit my Ultrafire C8 good.
Can you explain how it doesn’t fit?
This is the C8 that i bought i should add i changed the Lens to AR coated and a put a proper reflector in these have a plastic reflector.
http://www.gearbest.com/led-flashlights/pp_176964.html
I would go all the way to a real Convoy C8 which has a shelf instead a pill
accepts 17mm drivers and 20mm stars
The pill is about 1mm too large in diameter and so won’t even mate to the threads. And even if it was the right diameter the thread pitch is completely wrong.
The idea is to give my brother in law a light with 2 pills.
One will be a dedomed 90+CRI 3000k xpg3 with a 4.5A driver for him to use for newt surveying, (needs to be yellow light and have a pencil beam)
The other will be an XP-L HD driven direct drive for walking duty.
I also have SMO and OP reflector to go with it so he has a choice of configurations.
I believe thorfire C8S still uses a pill internally. Not sure if your particular pill is compatible or not though.
Those poor newts won’t know whats hit them!
I’ve always liked newts, we have the smooth type in the garden, but where I grew up we had great crested- hope theyre still there, but not sure they will be as they are a bit rarer than they used to be :frowning:
Sorry I cant help with your pill dilema!
