WTB 2 smooth C8 reflectors
I need 2 smooth C8 reflectors for the 7xC8 high output thrower I’m building. I thought I had enough, but I noticed some of them are a bit different (shorter and smaller emitter opening). I need all 7 reflectors to be the same, so does anyone have a C8 reflector they can sell me?
It needs to look like the one on the left, with a 9mm emitter opening. It is the kind that comes with recent convoy C8s.
I could order from China, but I don’t know if it would be the right version reflector and I don’t want to wait so long, so I would love it if I could get them from someone in the US. Or if anyone knows a US source for them (I bought the last of mtnelectronics’ supply).
Thanks!
If you can’t get it in US, you can always order from Simon (Convoy) on Aliexpress.
That way you can be sure to get what you want.
https://www.aliexpress.com/store/product/XML2-reflector-42-31-5mm-SMO-reflector-for-C8-with-gasket-diameter-9mm-hole-at-the/330416_32280198375.html
Thanks.
Evening bump.
Have you tried seeing what reflector version RMM has? He has op and smo c8 reflectors
Although it looks like Mountain Electronics is currently out of the smooth C8 reflectors.
I’d send RMM a email sometimes they find extra stock that’s wasn’t listed online.
I recently got lucky. I wanted a v6 3d emitter but they were out so had to get 3c. But it turned out they didn’t have anymore 3c the stock was off, but had found 3d. Which I wanted to begin with.
I feel your pain.
I had to replace plastic reflectors in C8 clones, and long story short, ordered 3 different C8ish reflectors from FT just to see which’d fit best.
Differences were 1mm or less in various dimensions.
I figure I actually can get the 2 reflectors I have to work, it will just be more work. I’ll have to put a spacer of some sort on top of the shorter reflectors so the glass presses on all of them equally.
Hang on…. let me look around, I built a few C8 triples, got a box around here somewhere?
Found them!
PM me your address and I’ll send them off today or
tomorrow!
If you want them?
Great! Sending PM.
