#GB38 NITEC0R SRT-NINE XHP50 2150lm UV+RGB - ACTIVE
82 posts / 0 new
freeme
freeme's picture
Last seen: 53 min 10 sec ago
Drop me a PM if you are interested.
©freedailydeals.org
©freedailydeals.org
Features
•     Designed for use in law enforcement, hunting and tactical applications
•     Die-cast unibody compact body
•     The world’s first line of flashlights to feature third generation SSR (smart selector ring) technology
•     Smoothly and rapidly select brightness levels and function by rotating the smart selector ring
•     Utilizes a CREE XHP50 LED for a maximum output of up to 2150 lumens
•     A micro-textured reflector offers wide angle lighting
•     Boasts a peak beam intensity of 15100cd and a throw distance of up to 246 meters
•     High efficiency circuit board provides up to 250 hours runtime on the lowest output level
•     Equipped with unique multi-colored LEDs (red, green,blue and ultraviolet), red-blue police warning signal, Strobe and Location Beacon modes
•     7 rapidly switchable functions to select from
•     Versatile 500mW ultraviolet light at 365nm wavelength
•     Infinite brightness adjustment from 0 to 2150 lumens
•     Multi-functional power indicator light displays low battery status
•     High-efficiency regulation circuit provides unwavering output
•     Stainless steel titanium-plated clip
•     Stainless steel retaining ring protects core components from damage
•     Toughened ultra-clear mineral glass with anti-reflective coating
•     Constructed from aero grade aluminum alloy
•     Waterproof in accordance with IPX8 (two meters submersible)
•     Impact resistant to 1.5 meters
On/Off
To switch ON: Press the tail switch until a “click” is heard.
To switch OFF: Press the tail switch again until a “click” is heard.
Momentary Illumination
When the light is turned off, half pressing and holding the tail switch.
Release the switch to turn the light off.
Adjusting Output
With the light turned on, slowly rotate the Smart Selector Ring (adjacent to the head of the torch) in a counter-clockwise direction to cycle through the following brightness levels: Beacon -> Police warning signal -> Blue
mode -> Green mode -> Red mode ->Ultraviolet light-> Standby mode -> Infinite brightness modes -> Turbo mode -> Strobe mode. These modes may be cycled through in reverse by rotating the Smart Selector Ring in a clockwise direction.
Note:
When in standby mode, the SRT9 will draw a small amount of current from the battery to maintain the operation of its micro-processor. The blue power indicator located on the side of the body will blink once every 2 seconds to serve as a positioning light when the torch is in standby mode.
ATR
The SRT9 comes with an Advanced Temperature Regulation module which allows the SRT9 to regulate its output and adapt to the ambient environment for optimal performance.
Power Tips
1.    With the light turned on, the power indicator will blink once every two seconds when power levels are around 50%.
2.    With the light turned on, the power indicator will blink rapidly when power levels are below 10%.
Edited by: freeme on 07/05/2017 - 22:14
freeme
freeme's picture
Reserved....
RollerBoySE
RollerBoySE's picture
Last seen: 2 months 1 day ago
Any specs. known?
freeme
freeme's picture
XHP50
RollerBoySE wrote:
Any specs. known?
Lazy-R-us
Interesting.
Any details on how the UI deals with the RGB? Is color mixing possible or just Red, Green, Blue?
Specs say (2) 18650, picture looks like they might be side by side cells rather than end to end.
Lazy-R-us
freeme
freeme's picture
  • Changes color with rotating selector ring.
  • Police mode will be alternating blue and red.
  • It is in EC4S uni-body layout.
Lazy-R-us wrote:
Interesting. Any details on how the UI deals with the RGB? Is color mixing possible or just Red, Green, Blue? Specs say (2) 18650, picture looks like they might be side by side cells rather than end to end.
travis
Last seen: 1 day 15 hours ago
As always depends on cost, but YA I’m interested!
A well regulated Militia, being necessary to the security of a free State, the
right of the people to keep and bear Arms, shall not be infringed.
FlashPilot
FlashPilot's picture
Last seen: 5 hours 50 min ago
Im interested. Thanks.
Pulsar
Pulsar's picture
Last seen: 1 week 6 days ago
Interested. Neat light
freeme
freeme's picture
GB has been secured. innocent
Do fill up the form if you are keen.
leaftye
Last seen: 2 weeks 4 days ago
Interested depending on price.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
Mstevens113
Mstevens113's picture
Last seen: 20 hours 41 min ago
Interested
blueb8llz
Last seen: 5 hours 28 min ago
I’m in for at least one piece.
scdaf
Last seen: 7 hours 56 min ago
Might be interested, price dependent.
weklund
weklund's picture
Last seen: 4 hours 20 min ago
I’m Interested.
... Happy Landings ...
acml
acml's picture
Last seen: 1 year 2 weeks ago
I’m interested. Thanks
AlexGT
AlexGT's picture
Last seen: 3 hours 14 min ago
Interested!
Hardware
Hardware's picture
Last seen: 1 year 5 days ago
Interested, thanks.
joechina
Last seen: 16 hours 27 min ago
Interested, depending on price.
Angel Martínez
Last seen: 2 days 16 hours ago
joechina
I really want to see a tear down review of this.
I reckon it’s a magnetic ring as a switch to keep it watertight.
And they should add a lock out position in this ring
Nguyen
Nguyen's picture
Last seen: 1 week 5 days ago
Thanks
Phantom1
Last seen: 2 months 2 days ago
interested
Thanks
asnidi2
Last seen: 1 week 22 hours ago
Interested depending on Price.
mrheosuper
Last seen: 18 hours 56 min ago
Oh, oh, oh
I want one
Add me, add me, pls
Forgot my pen
wle
wle's picture
Last seen: 13 hours 56 min ago
Interested depending on Price.Interested depending on Price.
zelee
zelee's picture
interested depend on final price
Don’t mistake my kindness for weakness.
I am kind to everyone, but when someone is unkind to me, weak is not what you are going to remember about me.
Pulsar
Pulsar's picture
Guessing it was more than my interested price?
Stereodude
I’d be interested in a neutral white version, but there doesn’t seem to be any plan for one. Sad
delete
Last seen: 1 week 2 days ago
i’m interesting on warm white.wait for price.
stephenk
stephenk's picture
Last seen: 1 week 3 days ago
Unimpressive RGB output again Nitecore. Come on, you can do better!
