Flashlight User Interface Cheatsheets
120 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 1 min 23 sec ago
mrheosuper wrote:
JasonWW wrote:
mrheosuper wrote:
JasonWW wrote:
mrheosuper wrote:
A little OT, im sorry, but what is the Firmware for driver with 2 channel output, 1 for main led, and 1 for aux led, clicky switch, thank you very much
There could be many. What light is it or what driver specifically?
it’s convoy s2+ with biscotti driver, triple leds, and i’m planning but an AUX led under TIR lens
since the driver is 1 channel , i can hook a wire from MCU to aux led
I’m not really understanding you. Are you saying you have Biscotti now, but want to flash a different UI, but you don’t know the name of the new UI?
Yup, my s2+ has Biscotti driver, now i want to mod it with AUX leds, but i am not sure what firmware support aux led?, anduril supports AUX led, but it’s only for e-switch
You already know how to get power to the driver when the rear switch is off?
mrheosuper
Last seen: 1 month 1 week ago
Well, my plan is not turning it off at all.
Forgot my pen
JasonWW
JasonWW's picture
You want to have the main LED on all the time? Battery will run down fast. I’m not understanding your logic.
mrheosuper
you misunderstood me, i’m sorry since English is not my native language, so it’s maybe hard for you to understand me
i have stock convoy s2+, it has 8*amc7135 driver, now i want to have an AUX leds under the TIR len( the tir len is install by me), the problem is the stock driver doesn’t support AUX leds, so right now i’m looking for firmware that support AUX leds. Something like Anduril Firmware, but changing mode through tail switch, not e-switch
the driver will be powered all the time, like E-switch driver. MCU will be in low power state so it won’t consume much energy
Forgot my pen
mikelight
mikelight's picture
Last seen: 1 week 11 hours ago
So useful, thank you.
A flat earth conference was packed with people from around the globe wink
JasonWW
JasonWW's picture
Rear clicky drivers like the one in the S2 are designed to be controlled by removing power from the driver since there is no other input. The rear switch connects the battery to the driver.
The way the driver knows if the power has been removed for a second or a day is through an OTF or Off Time Capacitor. This keeps the driver MCU powered up very briefly (a few seconds). This allows it to measure the amount of time it was off.
Since the usual point of Aux Leds is to be On when the main Leds are Off, you would need to keep the rear switch in the On position while the main Leds are somehow turned Off.
This fundamental problem is why you never see Aux Leds on rear clicky lights. I certainly have never seen it.
This is why I asked you if you somehow found a way around this basic problem.
The only solution I can think of is a special UI that includes an “Main Led Off” as part of the brightness cycle. So you would blink the rear switch quickly to cycle through the modes such as: low, med, high, off/standby, low, med, etc…
I don’t know if such a UI exists. I would suggest you ask Toykeeper or Tom E if they have ever heard of such a thing. Also, would you even want a UI like this?
sween1911
Last seen: 5 months 5 days ago
Hey, this is a great guide!
I have a Surefire 6P running a Dr. Jones H17F behind an XP-L2 on a Keeppower 16650 that’s one of my frontline lights. I’m also testing my newest concoction, a 17mm FET driver zener-modded running Guppydrv rev2 powering an XHP50 on two 17500’s in a Surefire M3. I’ve already referred to this page a dozen times. Thanks for putting this up.
HKSJOSHUA_
HKSJOSHUA_'s picture
Anyone know how to reset a d4v2?
I read somewhere that this will delete muggle mode and is what I would like to accomplish, I have some harbor freight flashlights to lend to muggles during camping trips, etc
Appreciate all the little things in life!
JasonWW
JasonWW's picture
I don’t have that light, but you can try disconnecting the tailcap (battery power), hold down the button and then retighten the tail cap. If you keep that button held down more than 3 seconds that should do a factory reset.
amishbill
amishbill's picture
Last seen: 3 months 6 days ago
I wish I knew how to subscribe to a thread here without replying… but, THANKS FOR COLLECTING THIS!!
Time to go back to page one – I didn’t notice an SP36 / Narsil cheatsheet on my first pass.
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
JasonWW
JasonWW's picture
The subscribe button is at the bottom of post #1.
d_t_a
Last seen: 19 hours 13 min ago
HKSJOSHUA_ wrote:
Anyone know how to reset a d4v2? I read somewhere that this will delete muggle mode and is what I would like to accomplish, I have some harbor freight flashlights to lend to muggles during camping trips, etc
(note: must be D4v2 with updated Anduril with factory reset with the unscrew tailcap, hold-down button, screw tailcap until it shows a flashing sequence;
I can't seem to do a factory reset with the "13H" method though (13 clicks, but hold down the last press) technique, probably it doesn't apply to the D4v2)
HKSJOSHUA_
Wow thanks this is exactly what I wanted to find out
Lightbringer
Lightbringer's picture
Last seen: 2 hours 5 min ago
Anyone happen to have a cheet-sheet for Narsim 1.0 by any chance?
Been playing around with my ‘micro, wanted to see if my old/original Q8 had momentary mode, and nope.
Blinked out the version, and it’s apparently 1.0, written by dinosaurs before The Cataclysm wiped ‘em out (and their handwriting sucked anyway), so there seems to be no written record of 1.0 out there at all.
Plenty for 1.2 and even 1.3, but nothing that I found for the humble version 1.0.
Lightbringer
Talk about going down the rabbit-hole…
Found this
http://budgetlightforum.com/comment/922763#comment-922763
which might be what I’m looking for. Anyone wants to add it to the list officially, have at it. Don’t wanna step on any toes. LOL
CRX
CRX's picture
Last seen: 1 day 19 hours ago
Hard not to with your feet! LOL Thumbs Up
Lightbringer
I never really played with all the little nuances of the UIs all that much, and having the ‘micro made it kinda easy to do so… with a cheet-sheet in front of me. (Dunno how it’s “cheating”. but hey…)
Eg, I’m given to understand that there’s a difference between “floor” and “ceiling” as far as ramping, vs “moonlight” and “turbo”, respectively. Ceiling being 50%, and turbo 100%, at least in theory (can’t really tell on my ‘micro; saw only green blobs in front of me with the Q8 after getting a bit too close).
But when setting moonlight to 1, the lowest, at first I wasn’t seeing any difference at all, whether set to 1 or to 7. But there’s a distinct fractional-second jump from lowlowlowlowlow to floor.
Hold the button just a bit too long and you go to floor (and keep holding and it starts ramping up, obviously); not long enough (registers as just a click, not click’n‘hold) you go to last-memorised level. There’s a very short time window of holding/releasing the button to get to moonlight.
I was kinda hoping that setting moonlight would also lower floor to that level, but I guess not. Still, having it set to 1 and still turning on super-duper low is a nicety.
It would’ve been awesome to have momentary-mode on my Q8, but I’ll survive.
Tom E
Tom E's picture
Last seen: 2 hours 52 min ago
Lightbringer wrote:
Anyone happen to have a cheet-sheet for Narsim *1.0* by any chance? Been playing around with my 'micro, wanted to see if my old/original Q8 had momentary mode, and nope. Blinked out the version, and it's apparently 1.0, written by dinosaurs before The Cataclysm wiped 'em out (and their handwriting sucked anyway), so there seems to be no written record of 1.0 out there at all. Plenty for 1.2 and even 1.3, but nothing that I found for the humble version 1.0.
Dinosaurs? Ok, I am pretty old.... laughing
Lightbringer
LOL
JasonWW
JasonWW's picture
Q8 is only 3 years old! Man, the flashlight world moves fast. Lol
dorpmuller
dorpmuller's picture
Last seen: 2 days 17 hours ago
Oh, man... just what I was looking for. Many thanks!
"I am the flashlight king! I can light anything!"
LEDicrous
Last seen: 2 weeks 9 hours ago
Does that mean Biscotti exhibits the “Next Mode Memory” problem? It doesn’t restore the last mode used when the light was turned off.
raccoon city
raccoon city's picture
Last seen: 14 min 49 sec ago
LEDicrous wrote:
Does that mean Biscotti exhibits the "Next Mode Memory" problem? It doesn't restore the last mode used when the light was turned off.
I'm no expert, but I think something is wrong with that diagram because if mode memory is on, then the flashlight should not enter into the next mode when turned on.
CRX
CRX's picture
Yeah it should be worded more like this.
Lightbringer
Toldja.
LEDicrous
I am about to order Convoy S2+ with nichia 219C which, unfortunately, has the Next Mode memory among its features, as per the description page. I asked Simon through Ali messaging, but he is too busy for the moment.
In the screenshot you have modified above, (change “Enter into last mode” instead of “Enter into next mode”), is it what you wish or is it the reality?
Do you have any flashlight using the Biscotti firmware to verify? Thanks
(I have edited my original question, 4 posts above this one, to highlight in red in the diagram the confusing area)
CRX
CRX's picture
I do believe Biscotti firmware was made by toykeeper and doubt they would incorporate NMM so admit to changing the sheet without checking.
The diagram was probably made in China.
I should have a Biscotti firmware driver from Convoy to check on later.
Flashlights with BLF User Interfaces
d_t_a
I think you can rest be assured that Convoy S2+ with Biscotti firmware, does not have “next mode memory”. The S2+ with SST20/Nichia 219C with Biscotti operates similar to the Convoy C8+ with Biscotti — when mode memory is enabled, it will have “last mode memory” instead of “next mode memory”.
srvctec
srvctec's picture
I don't see any mention of the F/W check mode in the Anduril guide.  Isn't it 15 clicks from off?
Also, I wish there was a date right in the image of each guide at the bottom or top that would indicate the date it was last updated so I could just check the one I have with any possible new versions to verify if I need to update mine.
Thanks for all the hard work on these!
forsh
forsh's picture
srvctec wrote:
I don’t see any mention of the F/W check mode in the Anduril guide.  Isn’t it 15 clicks from off?
12 click and on the 13th keep it pressed , it will flash and twinkle and then after the brightest flash it’s made a factory reset
https://www.facebook.com/groups/163189738353433/?ref=share
Join my Facebook FW3/4/1 selling and buying group guys
