Did you know this Host?
I am searching for a Host to build a flashlight with an MC-E Led. I want to use dual switches for better usability of the MELD-X RGBW driver.
I found this Flashlight on BG (USB Wiederaufladbare LED Taschenlampe 18650 Tactical XM-L2 LED 1198Lumens Sale - Banggood Deutschland sold out-arrival notice-arrival notice).
I think this could be a good mod host to build in two more Tactile switches and the MC-E led but i can not find pictures how it looks disassembled. Maybe someone here owns this light or know how its build inside. If not i will order it and try my luck.
Bump
Hey mate i am not sure of the name but it looks like it is made by Solarstorm/Blackshadow it has the same switch arrangement as other lights they make.
Lol i just google searched pictures (Solarstorm USB flashlight) and this came up. Maybe Banggood has it tagged as a Solarstorm?
Why this light?
the nice things about it are the powrbank functions ( have had this in my wishlist so long)
How about this one:
https://www.aliexpress.com/item/Dual-Cree-T6-X5-LED-Flashlight-Bright-20W-2400LM-Torch-5-mode-Portable-Light-Aluminum-Alloy/32797901933.html
Got one, build is nice, dual switch and dual led so you can play with MELD even better
@Miller
Nice host and i found it for ~17€! It is a hard decision. I would buy both. But i will get the red card if i buy this two lights and the Q8 ’( +parts) in one month.
The Dual host is an easy mod. The other one would be much more work (but thats what i like) but only RGBW.
I have to roll the dice.
@Miller
Do you know the MCPCB size that they use in this light https://www.aliexpress.com/item/Dual-Cree-T6-X5-LED-Flashlight-Bright-20W-2400LM-Torch-5-mode-Portable-Light-Aluminum-Alloy/32797901933.html?
The original flash light was " SingFire SF-349 " , I have one for few years ago. Used it a lot ,no problems at all , what Miller said is true , you can charge the battery from any 5V /1A power supply with micro USB , and you can use it as power bank .Sturdy construction but , unfortunately ,there is no shelf for the led , only a ring , so the heat management is not so great ...,anyway , I was unable to fry the led , even after extended period on high . Is true that after a led swap (a XM-L2 , dedomed) , I couldn't open the retaining ring from the driver , in order to resistor mod it so, it is working in stock form , at about 2.5A at the tail. I tried everything , from brute force to heat , chemical and freezing but no budging... The reflector is good quality , SMO , and the throw is great with dedomed led . The voltage indicator ,is somehow accurate , both for charging and left capacity .
For a budget , is O.K. !
Have it in a drawer so will measure the led boards and driver (I hope tonight maybe tomorrow.
I call it Wall-E light, and really like the feel
Ledboards are 20mm
Driver seems 26mm BUT the e switch is located so that there is a part of the driver straight, so it is not a full circle.
Thanks!
20mm Ledboard is perfect! The only PCBs i could get for the MC-E LED is 20mm. And i have 20mm Tripple XP MCPCBs here for the UV LEDs.
Only the high VF is not perfect but it should be enough for real ~3w of 385nm UV light.
I have to order 10 UV LEDs on aliexpress (1 lot). But i do not need all of them only 6. So 4 leds are left. If someone is interested ( ~1,20-1,40€/led +shipping). I got the info that i can buy the leds without the aluminium pcb. So it is the bare led (so no need to unsolder it to use a copper dtp board). If there are enough people that want one i will order more max 20 (to avoide paying tax).
And i have to talk to tterev3 or someone that have expiriance with PCB layout. The leds i want to use have different current requirements than the normal MELD-X driver. And because there is enough space on a 26mm driver maybe it would be possible to implement the fet. . . . in the design.
If not i will make it work with a fet on a seperate pcb and with stacking 7135 chips.
Miller i forgot to ask for the reflector measurements. It would be nice if you could check it. So i can try to get a fitting tripple reflector for the UV led´s.
Haha they are small
Measure them later
Bezel OD thread ~40mm
Bezel opening for light to go through ~33.5mm
lens ~1.1mm thick
~39mm OD
reflector
height ~19.1mm
OD ~26.2mm
ID ~23mm
emitter opening ID ~6.9
Nice so there is enough space to fit in the reflector of this light (https://de.aliexpress.com/item/Portable-CREE-Q5-White-Light-LED-Flashlight-Torch-Yellow-Light-Jewelry-Jade-Gems-Detector-Urine-365/32691728589.html?spm=2114.13010208.99999999.272.YUaCkr).
Its the only tripple reflector i can find that is small enough to fit in. To bad that a TIR will not work nice with the UV Light. A quad UV on a dtp board would be :smiling_imp: .
But without any optic or reflector its not a real option. If someone knows a tripple or quad reflector that fits the Wall-E light (https://de.aliexpress.com/item/Dual-Cree-XM-l-U2-Led-Torch-2-x-Cree-XM-L-U2-2-U2-5/1987840494.html?spm=2114.13010208.99999999.276.DMVlFg) please let me know! ! !
The new modhost arrived. I am not impressed! There is a lot to do to make it work. Whats really concerning me is how to hold the driver. I do not like the spring solution. It is a loose fit.
A closer look at the switch assemble. To convert this to a lighted tail switch i have to make a new PCB.
Never looked below the driver.
Cool to see
This is one of the nicest lights to hold I have IMHO.
Thinking about putting 2 Nichia 219b LEDs in it for I can very much live with how the driver works.
The light feels really good in my hand too. But i instantly ordered new Glass lenses (to remove the plastic lenses) and i will change the switch part. I want to use pilotdog68 lighted switch design and make a new PCB that fits into this light. But i have to wait until i know if i have to use a reverse or if i can use a forward clicky. And going with 2 Nichia 219 should be no problem. But if i where you i also would work on the shelf underneath the ledboard. The contact area with the ledboard is tiny. I started to remove the ano. and try to make it as clean as possible. My plan is to mix 15micron fine copper dust with JB weld and fill up the 3-3,5mm deep cavity. And then make it as flat as possible. This should transfere heat much better than a huge blob of thermalpaste.
@TheMiller
Are you maybe interested to convert your tailcap too if i order new PCBs from oshpark to convert the tailcap switch construction into a lighted tailcap (As a secondary effect the internal resistance should improve dramatically)!
For me this would just be two 219B (these don’t get too hot) as only adaptation.
I can live with the driver :wink:
If you look under the ledboard you will see why it is not getting too hot. The leds are not able to get rid of the heat. And the resistance in the tailcap (the nice switch construction ) will not allow more amps.
And i did not ask if you where interested in a new driver. I asked if you are interested in a lighted tailcap (pilotdog68s design). Because he has no PCB design ready for this light i would make one (with a little help) and order from oshpark. But i have to order 3. So i will have 2 left over.
