Which drop-in is more efficent?
35 posts / 0 new
garrybunk
garrybunk's picture
Last seen: 1 day 2 hours ago
Ok, confused here.  Talking strictly efficiency - most output with most runtime off identical cells.  I'm not looking for which one has more throw or more flood.  Not really looking for which one would run cooler, although input on that aspect would be appreciated as well.
Looking at this  Dealextreme single XM-L dropin: http://www.dealextreme.com/p/cree-xml-t6-5-mode-6700k-900-lumen-smooth-aluminum-drop-in-module-with-textured-reflector-58481 versus this 6x Q5 drop-in: http://www.dealextreme.com/p/6-cree-q5-wb-5-mode-1200-lumen-white-light-drop-in-led-module-52-7mm-42mm-8-4v-max-65153
versus this 5x R2 drop-in: http://www.dealextreme.com/p/5-cree-r2-5-mode-1200-lumen-white-light-drop-in-led-module-52-7mm-42mm-8-4v-max-35242
The way I read it (assuming specs are accurate, and we all know what happens when you "assume") the 6x Q5 drop-in is rated for the most output at the lowest current draw (1200 Lumens at only 800mA).  Is this correct?
It also seems more people online are using the 5x R2 drop-in.  Why would people choose it over the 6x Q5 drop-in?
Thanks,
Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
harry25175
harry25175's picture
Last seen: 6 years 5 months ago
T6
garrybunk
garrybunk's picture
Ok, why the XM-L T6?  That one says 3 amps on high?  That's substantially higher than 800mA on high, unless I'm missing something.
Garry
harry25175
XML is the most efficient led currently.
Leelou
Garry
A T6 driven at 800mA will produce more light.
I like: walks on the beach, sushi and things that are paisley.
CheapThrills
CheapThrills's picture
Last seen: 3 days 22 hours ago
Low driven XM-L.
garrybunk
garrybunk's picture
It's my understanding that an XM-L T6 at 800mA should produce around 350 lumens (referring to this testing: http://budgetlightforum.com/node/2603).  The 6x Q5 says 1200 lumens at 800mA.  Is the 6X Q5 pulling 800mA PER LED?  Is this where I am misunderstanding the specs?  That's not the way I read it though.
Thanks,
Garry
Hikelite
Last seen: 1 week 1 hour ago
The R2 needs 1000ma to produce 250lumens
Now you are comparing 1 LED vs 5 LEDs or 6 LEDs
harry25175
u cant compare single led with multiple leds
garrybunk
garrybunk's picture
So are the specs false?  Would the 6x Q5 drop-in be pulling a LOT more current than the "800mA @ 1200 Lumens" as stated?  I'm trying to look at the current draw of the drop-in as a whole here.  Same thing for the 5x R2 - drop-in, pulling a lot more than "1A @ 1200Lumens"?
Thanks,
Garry
garrybunk
garrybunk's picture
Why can't I compare single vs. multiple?  Why is it so hard?
Garry
Hikelite
They are in series. The current draw should be 4A for the 5xR2.  Seems be be close to it.
By langedaenen
"Some data:
Current drown ( 2 fully charged 18650 )
Full brightness: 1.85A
Med brightness: 0.75A
Low brightness: 0.25A --> very long runtime :)"
garrybunk
garrybunk's picture
Hikelite, which module are your specs for?  Is that a post somewhere?  Can you provide a link?
Thanks,
Garry
Hikelite
ChibiM
ChibiM's picture
Last seen: 14 min 10 sec ago
Thanks,
Garry
Gary, thanks for this link.. I havent seen that before! very useful!!!
Hikelite
By langedaenen
"Some data:
I presumed that they stated 800ma for the 5xR2 drop-in, thats why I said 4A.
E1320
E1320's picture
Last seen: 2 years 4 months ago
Here is the link to the efficiency of each emitter the T6 wins.
http://flashlight-wiki.com/Brightness_Bins
I am already visualizing the duct tape over your mouth.
garrybunk
garrybunk's picture
Some useful info at this link as well (1st post): http://club.dealextreme.com/forums/Forums.dx/threadid.747581.  Guess I wasn't understanding where the current draw is being  measured.  So it really is "per LED" I take it.
Now I know I said throw vs. spill didn't matter, but any ideas? Would the 6x Q5 or 5x R2 or single XM-L module produce more flood (spill)?  Do people generally go with multiple LED's to get flood?  I know reflector plays into this a lot, but just go with these particular modules.
Thanks,
Garry
harry25175
are u trying to compare multiple leds with single??
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 2 months ago
Garry, the most efficient drop-in you can probably make would be a true voltage regulated driver at 1.4A feeding an T6 XM-L.  Use a driver like the Nanjg 101 AK with 4*AMC7135 chips. You will have plenty of output (500-600 lumen) and the best battery life.
harry25175
the best is to buy both.. and you will find the answer Cool
CheapThrills
I would recommend this also...
Wondering, has anyone made only 1000mA dropin with XM-L?
garrybunk
garrybunk's picture
So, is it possible that I could replace the driver with a 1.4amp or less (ie. 1.0amp) and drive this XM-L drop-in from 2 D sized Alkalines?  This would be ideal for me.  Common size battery, yet large D size for runtime.  +/- 400 Lumens sounds like plenty of light.
Thoughts?
Garry
garrybunk
garrybunk's picture
How about this driver? http://www.kaidomain.com/product/details.S009113 .  Says 0.9v - 4.2v 1000mA boost and buck current regulated 17mm diameter.  Would this be compatible with the Dealextreme XM-L drop-in and 2 alkalines?  Would the voltage cutoff of 2.75v cut off the alkalines too early?
New to the driver scene.
Garry
DrJones
DrJones's picture
Last seen: 3 years 8 months ago
Might not be of interest any more, but here are some data on the 5*XR-E R2  and  6*XR-E Q5 drop-ins running on 2*18650:
5*R2:  light output: 820 - throw: 330m - unfortunately I didn't measure the current.
6*Q5:  light output: 850 - throw: 300m - 1.85A
Light output in arbitrary units   (roughly mimicking lumens)  measured via ceiling bounce.
garrybunk
garrybunk's picture
How about the above mentioned driver running 3 alkalines?  It says max 4.2v input and the alkalines would be 4.5 though.  Seems with alkaline C's or D's I should stay at about 1amp max.  Not sure what kind of runtime this would provide.  Any ideas?
Garry
Hikelite
Garry
It's sold out for a very very long time now.
watkins
watkins's picture
Last seen: 4 months 1 week ago
Garry
alkalines, seriously? that makes turning the light on cost alot....atleast look at rechargables.
Personally I'd love a light running on 2 or 3 d cell rechargeables, capable of 500 lumens for a couple of hours.
The extra width of the battery tube would mean a larger head wouldn't look quite as odd.
garrybunk
garrybunk's picture
Ok, missed it being out-of-stock.  How about a driver from elsewhere?  DX, since that's where the drop-in is coming from?  Which way would be more efficient - 2 D cell Alkalines?  or 3 C cell alkalines?
What I am getting at is a "simple" 2D Maglite XM-L with good runtime.  I don't need the "WOW" factor out of this light.  Allowing it to be run on simple everyday alkalines is a plus.  Would consider rechargables (NiMh), however that is additional cost (both cells & a charger).  At least I could start on alkalines and move on to NiMh cells later.
Garry
Garry
Vectrex
Vectrex's picture
Last seen: 10 months 1 week ago
Good efficient boost drivers (under 3.7 V) are hard to find nowadays, especially multi-mode ones.
Maybe you want to take a look at the good driver list.
SPAMBOT
SPAMBOT's picture
Last seen: 2 years 1 month ago
Just looked at the original list and its got 40k views! Not half bad, IMO xD
Great work on Brteds end of keeping it updated and expanded : )
Now with 100% all natural asbestos!
