Weapon mount for Convoy C8
A friend of mine is looking for a weapon mount for his C8. He’s using a regular hunting rifle. Any ideas on what to get? He’s not looking to break the bank, so the cheaper the better.
I’m using one like this for a long time and no problems with it.
https://www.aliexpress.com/item/1X-Montura-Soporte-Linterna-Laser-Para-25mm-Acoplar-Caza-Airsoft-Rifle-Escopeta/32713427263.html
This is to mount on the barrel.
Would be helpful to post what mount tipe he needs and what type of rifle it is exactly.
These are super simple to put on, happily accepts by bigger maxtoch 2x so the c8 will be fine
http://s.aliexpress.com/qYv22IzY
Thanks for the suggestions guys! I’ll see what he thinks!
If you research, the very last place you want to hang any amount of weight is on your scope tube (or shared scope mount). Avoid this type of mount at all costs. Almost any other option is far better.
this mount is good
https://de.aliexpress.com/item/Fenix-ALG-00-Flashlight-Ring-compatible-with-TK32-TK15-UE-TK16-PD35-TAC-PD32-flashlight-Diameter/32770250304.html?spm=2114.010108.3.159.qdExR6&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_5010013_10136_10137_10157_10060_10138_10155_10062_10156_437_10154_10056_10055_10054_10059_303_100031_10099_10103_10102_10101_10096_10147_10052_10053_10107_10050_10142_10051_5020013_10084_10083_10080_10082_10081_10177_10110_519_10111_10112_10113_10114_10180_10182_10185_10184_10078_10079_10073_10186_10123_142-10110,searchweb201603_16,ppcSwitch_4&btsid=2e4a7a0b-fa9b-4f06-94b1-4c3c16b321ab&algo_expid=5c5f7854-2ff2-4244-aca5-dd76c8e5d01a-20&algo_pvid=5c5f7854-2ff2-4244-aca5-dd76c8e5d01a
basically you can use any 25.4mm scope mount for a C8
Maxtoch has several styles of mounts , all under $10…………
24 to 46mm side by side
Weaver / Picatinny
Weaver - Quick detach
Barrell Mount
DDG Tactical the hi-tech tactical weapons that can be used by army and security services in the risk-free manner.
You can find a 1” or 25.4mm pica tinny rail mount of several flavor a and styles for less than $6.00 on eBay, Amazon, etc. if you have a problem finding any I have several mounts I’ve sold along with C8 flashlight packages I’ve sold. Let me know if you need a mount. Good luck. Thanks.
