Tear Down: Sofirn K03 (less nice now)
32 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 2 days 3 hours ago
Update:
http://budgetlightforum.com/comment/1187313#comment-1187313
Hi folks,
Just got a tiny light in, it was too cheap to not buy… Facepalm Party
https://www.aliexpress.com/item/K03-Mini-LED-Flashlight-EDC-Compact-Pocket-Light-3-Modes-Penlight-300LM-LED-Torcia-Light-with/32801331611.html
Looks nice, doesn’t it?
Okay, the picture is edited a little, which is basically misleading, but none the less, it’s a reasonable representation of the actual item.
So it has 3 modes, the obvious high – low – strobe with visible PWM on low.
Mine has NO next mode memory though.
A somewhat greenish tinted fake XP-E, but not too cold.
It came in a cardboard box with padding, 2 spare O-rings and a tiny keychain clasp thingy.
Anyway, it’s a tear down, so here are the parts:
Parts list, from top left to bottom right:
- aluminum switch retaining ring Thumbs Up (no pressed in plastic nightmare)
- decent rubber switch boot
- switch (reverse clicky) it’s crap..[/EDIT]
- decent tail spring
- plastic switch and spring holder
- the battery tube (CR123A or 16340)
- silicone wires (they’re quite thin, but they’re silicone. Silly )
- aluminum driver retaining ring Thumbs Up
- 17 mm driver board (but it’s a crappy driver, should be replaced)
- head
- aluminum LED shelf (1mm thick but it’s obviously better than nothing)
- LED on thin (1 mm) 16 mm diameter aluminum board (crappy LED, should be replaced)
- LED / reflector gasket.
- Aluminum OP reflector Thumbs Up
- O-ring
- Glass lens Thumbs Up (not coated)
- Stainless steel bezel [EDIT] Newer version have an anodized aluminum bezel… Sad [/EDIT]
So basically it’s all quite good.
The anodizing looks good too, so does the machining.
I was surprized by the SS bezel and the switch assembly with the black anodized alu retaining ring.
There’s a little too much room between switch boot and switch button so it’s a bit mushy feeling, but nothing that can’t be solved.
I paid less than $ 4 for this little light.
Yes, it has to be modified with a better LED and driver, but that’s the hobby i.m.o.
So i thought i’d share this with you.
(I’ll probably put in a 3× 7135 driver and 4000K 219C with a diffuser behind the lens.)
Thanks for reading. Smile
Edited by: Jerommel on 09/17/2017 - 11:58
JasonJ
Nice teardown …. looks like it’s put together fairly decently. A couple upgrades and away you go.
vulpes
vulpes's picture
Last seen: 1 day 6 hours ago
Thanks for the review! The anodizing looks way above its price; is it like that in reality, not just in the pictures?
Jerommel
Jerommel's picture
The top picture is from the seller.
It’s edited to look better / smoother than in real life.
But the real thing has proper anodizing too.
Time will tell if it wears down easily or not.
desmondkun
desmondkun's picture
Last seen: 10 hours 27 min ago
Like it! A cheap, small light with tail switch.
Thanks.
Take care of your flashlight and your flashlight will take care of you.
MRsDNF
MRsDNF's picture
Last seen: 2 days 10 hours ago
Thanks for the review. For four dollars you usually regret spending that much. Beer
Jerommel
Jerommel's picture
Yeah, i was looking for one of those twisty 123A lights, which are even cheaper, but they all look very cheaply made.
This K03 is quite a nice host for the money i.m.o.
Slayer1
Slayer1's picture
Last seen: 1 day 51 min ago
Thanks for the sharing of this light. Thumbs Up
wle
wle's picture
Last seen: 6 hours 15 min ago
pardon if this was covered, but – simple question:
does it cutoff when the cell voltage gets too low?
does it also let non-rechargeables go all the way to 0V?
(the old XTAR WK42 did this, when you put in a new cell, it looks at voltage and decides if this is rechargeable or not. if it is, then it cuts off at at 2V or so. otherwise it lets non-rechargeable go all the way to 0V)
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Jerommel
Jerommel's picture
I don’t know, wle.
But it’s a linear driver, so the party is over before you discharge a 16340 too far.
wle
wle's picture
good point, jerommel
this light [i got one] is good enough for the price
i was annoyed at myself though
i thought it had L M H for some reason
instead it is like all super cheap lithium-ion-capable lights – H L BlinkyUseless.**$%#$%#$%%^&%^&
oh well
my bad
not sure why i thought it was H M L
(is it so expensive to do L M H? if i am using a tiny battery, i don;t want to use H or M unless necessary what about HML for AAA lights, they all seem to be one level except lumintop, who annoyingly does M L H)
—this is what i reviewed it, on aliexpress:
it is pretty good for the low price – LED color is cool white, nice whitish tint – no purple or green – always starts on HIGH, i would rather it start on LOW, – i don’t like strobe mode at all but the cheap ones always have it – light is well made, good quality, i think it is probably waterproof just not for diving – it does not produce 300 lumens with a CR123 battery – probably needs 16340 li- ion for that – pattern is ok, has a hot spot in center, with some usable spill – it COULD be shorter with a TIR optic, instead of reflector and glass- overall GOOD FOR THE PRICE….
wle
-Greg Lemond.
Wildcat
Last seen: 2 days 19 hours ago
Good host.
I changed LED to cree xm-l2 u3 1b. Driver from Convoy 4*7135 with new firmware. TIR lens 17 mm 20°.
Small bright thing Smile
wle
wle's picture
TMW [ too much work Smile ]
-Greg Lemond.
Wildcat
5-10 minutes. And someone here is too lazy Wink
bikenber73
bikenber73's picture
Last seen: 7 hours 25 min ago
I wish it didn’t need so much work. Poor driver and a non CREE kinda kills it for me. Although I would pay $10 for an XPG2 and a better driver.
Maybe they will listen.
Wildcat
I changed the second flashlight like this: LED cree xp-g2 r5 4c, driver from convoy.
$2 flashlight, $0.8 led, $1.5 driver. 5 minutes and lot of fun Smile
NikolaS
NikolaS's picture
Last seen: 14 hours 4 min ago
Nice looking, very cheap, and if you look closely
That is a geniue cree xpg, not a lattice bright !
Jerommel
Jerommel's picture
It’s not a Cree. (at least, mine wasn’t).
Jerommel
Jerommel's picture
Just wanted to say that the switch in this thing totally sucks.
It has to be replaced.
(ymmv)
Jerommel
Jerommel's picture
Wildcat wrote:
Good host.
Thumbs Up
I put a 4000K Nichia E21AT sm403-D200-M1-R9080 in it with a 30° (i think) pebbled TIR on a single mode boost driver (for CR123A) at around 2.5 Watts (estimate) and it’s just lovely.
I replaced the switch though, because it was horrible…
Slayer1
Slayer1's picture
Where do you guys get the TIR lens?
Jerommel
Jerommel's picture
I used a Ledlink TIR from member kiriba-ru. (i had to reduce the diameter though)
But i have a growing collection of TIRs because i just buy some here and there sometimes so that i usually have something useful in stock.
Slayer1
Slayer1's picture
Jerommel wrote:
I used a Ledlink TIR from member kiriba-ru. (i had to reduce the diameter though) But i have a growing collection of TIRs because i just buy some here and there sometimes so that i usually have something useful in stock.
Thanks, Jerommel. Thumbs Up
wle
wle's picture
huh – re the switch, i thought mine was fairly good
it maybe takes too much travel and pressure to push, but on the whole i liked it
on the other hand, they may vary due to the low price, some good/some bad, can;t tell
wle
-Greg Lemond.
Jerommel
Jerommel's picture
Could be, wle.
But i had an identical one (form another light) and it was just as bad. I threw both in the trash..
I put one of these in there in stead:
https://www.aliexpress.com/item/Flashlight-reverse-switch/1572591646.html
They’re my favourite reverse clicky switches.
I had to file down the corners a little to make them fit, and then i soldered it on a modified 15mm board with a spring.
I also used a better suited switch boot.
So in all more extra work i didn’t anticipate, but i guess that’s the hobby..
wle
wle's picture
ha ha- switch cost almost as much as the whole light…
wle
-Greg Lemond.
Jerommel
Jerommel's picture
wle
You get 10 pcs for $2.60 (or something around that amount).
Jerommel
Jerommel's picture
So, i ordered another one and i got it in the mail today.
There’s no more stainless steel bezel, it’s anodized aluminium now…
Bummer huh? Tired
The glass lens seems to be thicker, it’s very thick, because the alu bezel is less deep…
It did come in a color printed cardboard box this time, matte finish with glossy brand name embossed, but i would have preferred a simple bubble wrap and a SS bezel and no expensive box…
For the rest it’s the same.
The Miller
The Miller's picture
Interesting update, thanks and I agree with you.
hank
hank's picture
Last seen: 1 hour 16 min ago
bait, and switch (sigh)
Jerommel
Jerommel's picture
Hmm… The switch is different from the one i had before.
It seems to be better than the previous one.
That’s an important improvement.
Alas… Still crap…
