Tear Down: Manker E02 / E02H (same as E03H)
69 posts / 0 new
ch1ir
Last seen: 4 hours 14 min ago
Hello, I’m enjoying my e02 I wanted to pop some DC fix in, how can I safely remove the bezel, thanks everyone
Michael
Emisar D⁴, Astrolux C8, BLF A6, Sofirn sp36aV2, Reylight Mini Pineapple, BLF 348 KillZone, Lumintop IYP07, Emisar D18, Boruit D10, Manker e01, Ultrafire z1, Massdrop titanium AAA, Astrolux HL01, Armytek Wizard Pro Nichia, Tacklife LFL3A, Astrolux FT03, Zanflair T1
Lacerta
Last seen: 2 weeks 5 days ago
ch1ir wrote:
Hello, I’m enjoying my e02 I wanted to pop some DC fix in, how can I safely remove the bezel, thanks everyone Michael
Read back. Wink
Goread Y-20 ( XHP50.2 mod ), UF-2220 ( XP-L2 -> SST40 mod ), Thorfire PF01S, Sofirn SP-10B, Manker E02H X 2, Manker E03H, Imalent HR20 ( XP-L2 & TIR mod ), Rofis R3 ( SST40 mod ), Skilhunt S3 Pro HD, Utorch UT01 ( XP-L2 -> Osram Osconiq P8 mod ), Lumintop tool AAA ( XP-G3 -> SST20 mod ), Skilhunt H04R RC ( SST40 & TIRs selection mod )
Lacerta
Jerommel wrote:
So, i was messing around with a small TIR optic, and then i destroyed the XP-G3… This was a while back actually. Today i decided to remove the XP-G3 remnants. I can confirm the copper heat sink protrudes through the PCB, giving the LED a direct thermal path. Thumbs Up The XP-G3 was badly soldered to the heat sink though, but probably good enough for the (less than) 2 Watts power consumption. I just finished reflowing a 219C 4000K CRI90 onto it. First the centre pad to the heat sink, and then the + and – traces from the sides. (had to scrape some masking paint off the PCB first) …it could still do with a diffuser though…
…Is the copper cooler block in galvanic contact with any potential or with the lamp grounding? As I see on the pictures maybe not. Assuming that the head inner surface is anodised. Is it?
mitsuki08
Last seen: 8 hours 14 min ago
So a few weeks back I dropped my E02 while it was still hot from a LED swap and a lot of components fell out. I’m not so technical/skilled that I can fix it but thought might as well contribute to the community with my misfortune so I decided to pry the driver board from the copper heatsink to give you guys a better view. Not sure if it was glued really since there are dots of what I assume is thermal glue but again I’m really a noob at this. It was more like press fit onto the heatsink.
Lacerta
Thanks for the pictures! The right one ( with Your fingers ) is out of focus. Could You take an other one?
I am sorry for Your flashlight.
For me it seems to be still repairable but needs some soldering experience.
mitsuki08
Lacerta wrote:
Thanks for the pictures! The right one ( with Your fingers ) is out of focus. Could You take an other one? I am sorry for Your flashlight. For me it seems to be still repairable but needs some soldering experience.
I updated the post with a more up close shot. Yeah it will take up more effort for me since I don’t have the skill. Maybe in the future.
Ilumenati
Ilumenati's picture
Last seen: 1 week 1 day ago
I heard back from “Steven” at Manker regarding the flicker on my E02 XPG3 in moonlight mode.
He said it was a known issue and that some levels flicker when selected in moonlight mode and to enter engineering mode and select a different level. It does not explain why but answered my question if my light had a unique problem.
I applied DC fix to both my Nichia 219c and XPG3, used a template, cut a circle and laid it directly over the lens. Worked perfect and defiantly smoothed out the XPG3 and made late night reading with the 219c better in moonlight mode spreading the light just enough to cover the pages evenly.
After following this post just purchased an extra E02 XPG3 to reflow, probably SST-20 4000K or 5000K.
Thanks for the tear down and advice,
Lacerta
Thank You!
[ Skill comes from practicing! Big Smile ]
