I am looking for good solar USB charger up to 40$ from GB, Bangood, Fasttech and Aliexpress.
Without internal battery, just solar panel.
Ih someone has such device and is happy with, please let’s share information.
Thanks.
Blitzwolf and archeer seem to be the brands to look for.
40$ might be enough for a two-panel solar charger.
I have a three-panel Archeer (got it for reviewing purpose) and was able to charge at 2,4A in full sunlight
Where can I find discount code for BlitzWolf® charger?
On the photo of the usb output controller it says the maximum output is 2amp at 5volts that works out to only 10watts maximum.
I bought an 24watt myself before i learned how to check the real wattage, mine is only 15watts. :(
John.
Never trust the manufacturer’s data :smiling_imp:
I picked on prepper criteria and got more than enough performance. With this I can charge two phones at one time, either the phone and the power bank, or two power banks. You will never raise the price, but if you do not have power networks, this is your last chance. :+1:
In the future, I plan to purchase a smaller panel that I can take with hiking trips. If this is so good, a 14W (fake data entered) is sufficient for general use.
I own the Blitzwolf and it’s amazing. This is my third solar charger and by far the best one. The key features for me:
–2 USB output
-each USB output adjust to device maximum amp and can deliver up to 2.1
-can be used (not at full power) even partially cloudy
-charger can reset itself if a cloud block the sun. A lot of cheaper solar chargers will turn off and will not restart when the sun comes back
