Buck and Boost Drivers, Testing, Modding, and Discussion (Pic Heavy)
301 posts / 0 new
Windforce
JasonWW wrote:
Nightsword wrote:
Wow that MP3431 datasheet shows 97% efficiency @1A which is around the current I need. Just need a driver with more evenly-spaced or configurable modes, and a ~3V cutoff voltage.
EDIT: Appears to be PWM not constant current Facepalm
I thought that driver was 12v out only, not 6v.
Have you seen Loneoceans boost driver? He does not sell them, he just designed it and shows others how to assemble the parts.
What would prevent me of using ‘12V’ constant-current mode driver with 6V LED? Question
Tom E
Tom E's picture
Last seen: 6 hours 52 min ago
Barkuti wrote:
JasonWW wrote:
We are still a ways off from having universal boost drivers that can run NarsilM or Anduril …
… I am still waiting for better drivers.
Universal? What do you mean by universal? For universal things to exist as a rule most people would need to develop its consciousness and themselves a good deal more.
NarsilM? Anduril? What gives? I Hi-Lo-Strobe Big Smile LoL.
In all honesty, using fantasy names for microcontroller software may sound compelling for the freaks. For people outside of these circles, definitively not. I've been around here for some time already and I've never used a torch with software of that class, for example.
I would choose a descriptive term. For example, Advanced Multifunction Flashlight Firmware vX.Y.
Of course I have to admit NarsilM or Anduril are terms which completely fail to inspire me. I prefer DynamiteBundle or BonnyC4Piece instead.
NarsilM - Neolithic Advanced Research Superior Intelligent Light Module
Yea, right.... cool
From the source code:     "the sword wielded by Isildur that cut the One Ring from Sauron's hand"
 Let me see, I started working as a programmer in 1979, also bought the very first IBM PC for my own home use about in '82 or so. Also in 1981, started doing my first consulting gig at $17/hour - hit the big time!
I should add that over these 40 years or so, I've done a ton of firmware projects, most or all where the firmware had no name, least that I can recall, because basically, hardware such as fault tolerant server, graphics controller, terminal, typesetting system, treadmill, or any other device I've written firmware for gets only one functional version of firmware and is an inherent part of the product. So for example I might have built in a feature in the treadmill firmware to pause/resume, but that's a feature of the mill and listed as so.
In this BLF/flashlight kind of environment though, a name or way of identifying it is more important since there are many choices. We could have gone by the author but that has it's problems and is not conducive to the open source, open nature of the forum here. Also could have used some acronym that stands for something clever, but no one will really remember or care anyway, so Narsil or NarsilM is about as good as anything. I followed TK's lead here for using names like this, and Anduril, of course, is the natural successor to Narsil. In fact as I recall, TK asked me privately if it was ok to use that name, and assured her it's no problem at all.
Just a little history here....
Nightsword
Last seen: 1 week 8 hours ago
Yes JasonWW, Loneocean’s driver is a tease but I don’t have that kind of time. I’ll just stick with the H1-A mod until MTN has their BST series back in stock.
Nightsword
e1000 wrote:
FYI, just ordered a few recently and seems like small revisions. Old on the left (few months ago), new on the right.
!{width:100%}https://i.imgur.com/3bIgqfz.jpg!
I accidentally broke my old one marked 2R2 and now I’m getting a 3% efficiency drop (92% to 89%) @1.25A with the new one marked 1R5. Well that kinda sucks.
Barkuti
Barkuti's picture
Last seen: 3 hours 50 min ago
Nightsword wrote:
I accidentally broke my old one marked 2R2 and now I'm getting a 3% efficiency drop (92% to 89%) @1.25A with the new one marked 1R5. Well that kinda sucks.
As predicted.
It does not bode well, I wonder what would happen on high when sense resistor modified at 4+A.
Can you try replacing the inductor, to see if it restores the efficiency Nightsword?
Stuff like this sort of takes away my appetite for, honestly.
Nightsword
I still have the old driver with 2R2 inductor, but I absolutely won’t do anything that might damage the newly modified driver, because changing the resistor is a PITA. Let me know if there’s a sure way to replace the inductor. While at it, may as well go bigger than the 2R2.
Barkuti
Barkuti's picture
Nightsword wrote:
… Let me know if there's a sure way to replace the inductor. While at it, may as well go bigger than the 2R2.
Unsolder the current, solder the new/replacement one. This is easy. If you have some parts lying around, that is. I do, but guess I may be too far away. Innocent
Nightsword
The solder joint near the resistors is risky for me. I’m going to skip this mod, use this H1-A as is for now, and then get a MTN BST driver when they’re in stock.
e1000
Last seen: 2 hours 47 min ago
Barkuti wrote:
As predicted.
Doh!!!!!!
Nightsword
Going from 92% to 89% efficiency would be a third more heat off the driver btw
slopegatri70
slopegatri70's picture
Last seen: 4 days 11 hours ago
i’m having strange issue with a buck driver, currently it’s having 3× 0.24 ohm current sense resistors which means output should be 2.5Amps right ? but it outputs more than 2.5A when i try to run 3x osrsm white flat + 1x Xml leds in series.
i’m powering the driver via motorcycle charging system ( driver is designed for it since it’s from motorcycle auxiliary light) , input and output current hovers around 1.3/1.5 amps when motorcycle is idle @ 13.2-13.8v, but as soon as i increase RPM, voltage goes upto 14.2v , and led driver outputs more than 2.5Amps and goes upto 3.2Amps to leds. i get that when input voltage is not sufficient the driver won’t output enough current to the leds, but when the input voltage is enough , it shouldn’t deliver more current than it’s supposed to, right ?
now here comes the strange part, when i remove 1 xml led from above arrangement and run only 3 white flat leds in series, everything behaves normally, output current never goes above 2.51Amps.
any idea why running 4 leds in series instead of 3 , increases driver output current ? btw driver is designed to be used in 9-36v range.
thanks .
slopegatri70
thanks .
A little update, i tried running 4 leds in 2s2p arrangement, and driver output doesn’t go above 2.52Amps. so it works normally. but efficiency goes down. compared to 3 leds in series.
1. when driver is running 3x leds in series – input voltage*input current = 14.2v*2amp. =28.4w. ( output is 24w, so 84% efficiency )
2. when driver is running 4leds in 2s2p – input voltage*input current = 14.2v*2amp. =28.4w. ( output is 16w, so 56% efficiency )
i really want to run 4 leds, but not if efficiency is really that bad. with 4 leds i can use 4× 20mm tir optics, which will give more throw compared to 3 optics. :/
Barkuti
Barkuti's picture
slopegatri70, such driver does not seem to be able to handle 4 emitters in series with so low input voltage. For example, 4 white flat emitters in series require ≈12.5V at 2.5A, plus any cable and connections overhead. The effective input voltage into the driver is just very little above that, if at all, and so it cannot work properly.
If you are adamant in driving 4S emitters with such driver, raising the input voltage may work. For that, get some DC/DC boost converter you can fed with the driver's input and then attach the boost converter's output into the driver's input. Suffice to say, adjust the boost converter's output voltage to a sufficiently high value, 14+V.
slopegatri70
If you are adamant in driving 4S emitters with such driver, raising the input voltage may work. For that, get some DC/DC boost converter you can fed with the driver’s input and then attach the boost converter’s output into the driver’s input. Suffice to say, adjust the boost converter’s output voltage to a sufficiently high value, 14+V.
Actually the input voltage i checked was on driver itself ( 14.2v), charging system gives 14.4v so almost 0.2v drop. i can’t use any dc/dc boost converter because it will stll lower the efficiency. ( motorcycle generates 11.5amps of current, only 4-4.5 amps is left for auxiliary lights after i subtract power requirements of headlight/turn signals/pump/etc.
i really thought 14.2-12.5=1.7v would be enough for this driver. i guess it’s not enough. maybe i should use 3 leds in series with 2× 20mm + 1× 26mm optics. it will have same or maybe a little bit more throw than 4s leds.
or maybe i should change the driver, but i don’t know if there’s any high quality efficient drivers available with low voltage drop.
man this experiment( modding the lights to reduce glare) is costing me alot, and there’s very little progress so far. (
Lexel
Lexel's picture
Last seen: 4 hours 2 min ago
I got also just from one German Guy 2 dead of those with 2R2
both with burned all in one switching chip
and it seems no one checks driver for not properly soldered parts, it is possible to let that do in a good PCB fab automatically
Barkuti
Barkuti's picture
and it seems no one checks driver for not properly soldered parts, it is possible to let that do …
Did you mean…
I just got two of those drivers with 2R2 dead from a german guy, both with TPS61088 boost chip burned.
Without overclocking? Seriously?
Eneen
Last seen: 13 hours 54 min ago
@Nightsword: are rest of parts same or they have changed resistors too?
I don’t understand why smaller inductor causes eff drop. It can have lower DCR and higher Isat, take a look at specs from cheap inductors from ali:
https://ae01.alicdn.com/kf/HTB1y_YvPVXXXXXsaXXXq6xXFXXXQ.jpg
I mean with inductor of same size and this one looks like it…
Barkuti
Barkuti's picture
Eneen
Same inductor size/series usually means there's an exchange between inductance and current handling among the different series parts, being all parts of the series usually equally priced. But it clearly isn't the same size/series, they downgraded the inductor, no need to be a hawk-eye to notice imho. They stepped down to a smaller inductor with the same current rating but less inductance. They saved on production costs, and made a worse driver.
Eneen
Series is different for sure, but they are pixel-perfect same size. This might looks like different current/sat specs or simply this driver has lower efficiency with smaller inductor. Bourns has good inductors (https://www.bourns.com/docs/Product-Datasheets/SRP1038A.pdf), I may give a try after ordering driver from KD.
BTW, is KD available? I’ve written some emails but no answer since week…
Barkuti
Barkuti's picture
Eneen wrote:
Series is different for sure, but they are pixel-perfect same size. …
The 2R2 is a little bit bigger as far as I can tell. I have one of 'em right here. According to my cheap 1/10mm accuracy Aneng caliper its measurements are ≈10.25 × 10.25 × 3.7mm.
It's a bad choice what CDM has done. I may still go for it, but it is less appealing. And remember it lacks reverse polarity protection, so always stick it right. Wink
Eneen wrote:
BTW, is KD available? I've written some emails but no answer since week...
Try sending some PM to Kaidomain's boss BanL. Or posting something here: KD (kaidomain): Deals and new products thread
WTF
Last seen: 2 hours 43 min ago
They added a lot of vias. Strange that they would rework an existing design unless they were trying to address a problem.
ggf31416
Last seen: 3 hours 7 min ago
Are these courses useful for understanding what are you talking about? Of course I’m not paying, money is reserved for more flashlights, LOL.
https://www.coursera.org/specializations/power-electronics
Eneen
What about this one? Is it ok?
https://aliexpress.com/item/33000130006.html
Barkuti
Barkuti's picture
That is Convoy XHP50 driver Eneen, good of course. Related technical information here: Damian's Testing boost drivers (#3+).
Nailed the best offers for the ∅22mm Manta Ray drivers here and there, btw.
Eneen
Wow this convoy one is super efficient. It will surely go into my next build despite it’s lacking hi 65% mode. Thx!
WTF
There’s a new Convoy 22mm driver, XHP35 at 2.3 amps. Same controller as Loneoceans GXB172 so it should be easily configureable for 6 amp 6V, or just get a 12v mcpcb and resistor mod it.
https://www.aliexpress.com/item/4000046041955.html?spm=2114.12010612.814...
malkoffdevices
malkoffdevices's picture
Last seen: 1 hour 5 min ago
hi is the driver the same in all of Malkoff drop-in’s?.
I think Nichia M61 219B V3 single mode is a Buck driver right? – is this a new or an old buck updated driver or was there something else before this?. any reason for Malkoff not to get with the times, and update? –
I have read about malkoff using old tech electronics which could do with some updating. not sure.
I know the Malkoff is a reliable light, but is the driver reliable in 2019 too?.
kind thanks.
London !
1stein
1stein's picture
Last seen: 2 min 47 sec ago
Eneen wrote:
Series is different for sure, but they are pixel-perfect same size. This might looks like different current/sat specs or simply this driver has lower efficiency with smaller inductor. Bourns has good inductors (https://www.bourns.com/docs/Product-Datasheets/SRP1038A.pdf), I may give a try after ordering driver from KD. BTW, is KD available? I’ve written some emails but no answer since week…
I’ve asked KD recently about the change – they didn’t change the picture so I charged them with not maching product description. They’ve replied this change was necessary to implement thermal management option. They claim it has a temperature step down now.
Can anybody confirm? Deny?
Edit: just to be honest: as I understood KD explanation – the inductor change was necessary to maintain the same price after implementing temperature control. So in my understanding KD traded better inductor for temperature control.
Barkuti
Barkuti's picture
1stein wrote:
I've asked KD recently about the change - they didn't change the picture so I charged them with not maching product description. They've replied this change was necessary to implement thermal management option. …
So, downgrading the inductor was necessary to implement thermal  management?
What a lie.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 13 hours 40 min ago
Barkuti wrote:
1stein wrote:
I’ve asked KD recently about the change – they didn’t change the picture so I charged them with not maching product description. They’ve replied this change was necessary to implement thermal management option. …
What a lie.
The last change was not the inductor, it was the board layout. Perhaps some new resistors, as you can see in the comparison-picture.
The Inductor was an earlyer change.
