Luminus SST-40, a N4 BA bin tested
336 posts / 0 new
Blazer296
Last seen: 1 day 3 hours ago
With the low forward voltage, it would seem this should be a great led for regulated multi emitter lights. Its not a lot less watts, but over several emitters it adds up. Less heat, slightly more run time. Sounds good to me.
Hmm, if somebody made a mcpcb for these in a 20mm triple……… With a fet driver could be interesting as well if they push that much easier than xp-g3’s do.
zeremefico
zeremefico's picture
Last seen: 54 min 2 sec ago
After checking my Ali sst-40s I realized they are b grade, half have bubles in dome and some are not square but wider and centering dics not fit them.
KD is better place to buy, better bin, higher price though.
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Dusty
Last seen: 56 min 39 sec ago
zeremefico wrote:
After checking my Ali sst-40s I realized they are b grade, half have bubles in dome and some are not square but wider and centering dics not fit them. KD is better place to buy, better bin, higher price though.
Were your LED’s mounted on mpcb’s? or were they bare. I’m still contemplating getting a few of these.
Brianbug
Sirius9
Sirius9's picture
Last seen: 1 min 7 sec ago
I think those shops on aliexpress did not sale bare leds only with mcpcb at least there were no bare leds where I bought them (SST-40).
Jerommel
Jerommel's picture
Last seen: 2 weeks 6 days ago
Well, i bought 2 SST-40 form AliExpress, and i put them in pure toluene..
The first one got the chip detached from the 5050 base, it seems it wasn’t soldered on there properly…
So it died in the toluene, but i almost managed to reflow the chip back on the 5050 base, but something went wrong, it didn’t work anymore..
Interesting discovery though, because i think you could reflow the chip directly on to copper, and find a way to connect the bond wires to ‘something near by’, improving the thermal path from chip to whatever copper you want.
But i’m not buying them from AliExpress anymore.
It seems they are factory rejects.
The second survived the ordeal, it is dedomed now.
I will try warm or hot toluene, because there are still some bits of silicone on the phosphor, even after leaving it in toluene for some 36 hours…
But i was afraid the bonding between chip and phosphor would dissolve, like someone described happening earlier in this (or another) thread.
So i will try solving at higher temperatures with the 2nd SST-40, see if i can get it totally clean.
Meanwhile i have one from KD too.
I’m sure the chip will not fall of off that one… Facepalm
2Q19
KawiBoy1428
KawiBoy1428's picture
Last seen: 47 min 31 sec ago
I got 1 half way decent one out of like 30, decent that the bond wires didn’t break, but still, silicone remains are hanging off the bond wires. All of the SST-40’s I got came from Kaidomian. I have 20 SST-40 N4 AD’s coming 12 of which are going to replace the XML’s in my TR-J20, the rest, I’ll try a different approach.
KB1428 “Live Life WOT”
EagleShield
I think I have read that having little silicon left on the bond wires is just good because it protects them.
KawiBoy1428
Not if you can see it in the beam. Big Smile I think 18sixfifty has had some success, from what I gather, he slices and dices before chemical de-dome bath/soak.
The silicone dome has a heck of a hold on them bond wires. Angry I have also had the chip coming off the pad on a few of them too! Facepalm
texas shooter
Last seen: 11 hours 24 min ago
Do post your build, I’ve got 2 of them and thought they needed a boost.
KawiBoy1428
Boost it’s pulling 8 amps on a VTC5A, I thought I had something wrong at first, cause it would only pull 6+ amps, until i put a fully charged VTC5 and then a tried a VTC5A . I just swapped out the emitter/board in my M25C2 Turbo that had a FETDDdrv. in it. It’s a pretty intense BLUE-ISH spot, just kinda fuzzy and dark to one side, like casting a shadow from the silicone clinging on. Meh, I live with it, because I know what will happen! Facepalm
Dales shaves them down to just above the phophorus and he’s getting like 9.4amps or more 2400-2600 lumens, something like that.
Maybe or could be, if they are weak, they might be damaged, I had a few that would light, go thru the levels a couple times and then burn out, some instantly and they still had the dome on, it was released from the base just not completely off, so I’m left wondering, was it the bond wires or was it the chip to the pad problem? Dunno?
Lexel
Lexel's picture
Last seen: 2 hours 40 min ago
you can see blown bond wires with magnification glass or macro function od a compact camera
Jerommel
Jerommel's picture
Wow, even some of those from KD have badly solder flowed chips??
There’s no way the solvents cause the chips to fall off i.m.o.
On mine you could see it wasn’t soldered properly.
2Q19
Jerommel
Jerommel's picture
Whoa, that sounds like the KD ones are from a crappy batch too.. Sad
2Q19
Agro
Last seen: 19 min 31 sec ago
Got my SST-40s from Shenzhen Great Technology Co.,Ltd, they appear legit. Thumbs Up
eas
eas's picture
Last seen: 1 month 8 hours ago
Do you have a link?
Newlumen
Newlumen's picture
Last seen: 1 day 12 hours ago
Anyone know if I can use Sony vtc5a on my fenix TK75 quad modded with sst-40?
zeremefico
Sure but If you want the full power, you should mod the carrier.
My YouTube channel
K40M F16
Agro
eas wrote:
Do you have a link?
https://www.aliexpress.com/item/10PCS-100PCS-Luminus-SST-40-10W-LED-1100...
Funny, it appears renamed to “GreatLED Store”.
Newlumen
Newlumen's picture
I forgot to mention the carrier is modded., will post photo tonight.. I just want to know if Sony vct5a are safe with sst40.
Newlumen
Newlumen's picture
Ok here is my fenix tk75 quad sst40 dedome. Is Sony vtc5a safe to use in this light?
1215_CE45-10_D8-4_D27-93_F4-8408126_B2842
EasyB
Last seen: 1 month 3 days ago
It’s possible you will blow the bond wires from too much current (~9.5A) if it’s direct drive and low circuit resistance. What is the voltage configuration and driver? And have you used other cells in the light successfully?
giorgoskok
giorgoskok's picture
Last seen: 3 hours 5 min ago
I think Newlumen’s light is modded by Vinh , with “driver vnx2” which is a fet driver .
I would use VTC6 to be safe…
Agro
Ask Vinh. He usually uses VTC5A…
Newlumen
Newlumen's picture
Yes sir. The tk75vn is modded by Vinh. Probably drawing 4.5 amp from each cell.. the Carrier is 4S.. I like using Sony vtc5a. So far I have no problem using the highest mode with my vtc5a.
Either way, if the light break, he said he will fix it for free.. so I don’t worry much..
giorgoskok
It draws about 8-9 amps per cell .
gamezawy
gamezawy's picture
Last seen: 1 week 1 day ago
Please advice from those who bought SST-40 from Aliexpress store called GreatLED Store, that it was called Shenzhen Great Technology Co.,Ltd.
How was the LED performance ? despite the problem of bubbles in the dome
i want to use this led in general lighting so what i care about is its performance in producing a lot of lumens
AlexGT
AlexGT's picture
Last seen: 3 hours 25 min ago
Anyone knows if there are higher bins available somewhere? Thanks!
djozz
djozz's picture
Last seen: 1 hour 5 min ago
I think I read in Richard’s thread that he asked about other tints/bins but that Luminus thusfar only made a few types at all.
eas
eas's picture
I ordered two from there. I couldn’t make out any flaws in the domes of the ones I received. I put one in a direct-drive light. I haven’t done any rigorous tests, but I can say that it puts out a lot of light and runs relatively cool. I built a similar light in an F13 host, with a 26650 battery, but I used an SST-40 emitter on a DTP copper MCPCB I bought from Kai domain. I’d estimate they have similar performance, but the one from KaiDomain is slightly warmer, as expected.
Jerommel
Jerommel's picture
EagleShield wrote:
What is the best forward voltage bin for this led for flashlights with the A17DD or X5/X6-driver?
Forward voltage bins for sst-40
As giorgoskok wrote, the sst-40 specs from aliexpress store: Shenzhen Great Technology Co.,Ltd.
Flux : N4
Color : BA
Voltage: VK (min: 2.9V max: 3.1V)
You see that there are 2 bins lower then the VK bin and I guess if you use those with DD-FET driver you get more Amps (if I understand this correctly) then the VK bin but that means more heat.
Are those VH and VJ bins better (more Amps = more light) or are they so good they get worse (to much amps = to much heat and the led burns)?
Edit: removed a picture as requested (couldn’t they just go to Kaidomain’s site and copy that picture instead?)
KD has VH Voltage binned SST-40’s now.
Has higher brightness bin too.
http://kaidomain.com/Flashlight-DIY-and-Tools/LED-Emitters-or-LED-Star-o...
2Q19
