Deal Extreme XM-L drop-in Use
4 posts / 0 new
garrybunk
garrybunk's picture
Last seen: 3 days 12 hours ago
Trying to build a real budget XM-L Maglite.  (I know, I'm determined!)
I'm thinking about using the Deal Extreme XM-L drop-in sku 58481 here: http://www.dealextreme.com/p/cree-xml-t6-5-mode-6700k-900-lumen-smooth-aluminum-drop-in-module-with-textured-reflector-58481 in a 2 D cell Maglite powered by 2 protected 25500 lithium ions also from DX, sku 26799 here: http://www.dealextreme.com/p/protected-25500-3-7v-5500mah-rechargeable-lithium-battery-26799 .  I understand the cells are closer to 3,500mAh and that is still higher than using 18650 cells.  I also understand the maglite / drop-in will require some modding and I'll have to use a piece of PVC (and spacer?) for the cells to fit.
I just want to hear any input people have on this combo.  I think these batteries are the best bang for the buck I can find.  Any input on the batteries?
This drop-in seems the cheapest way to get an XM-L in a Maglite, but I am concerned about heat.  Can someone who has used this drop-in in a Mag comment?  Is there any more I can do for heat besides coat the drop-in with thermal compound where it contacts the Mag's body?  Any ideas how long it could run on high this way?  I expect most use would come using the "medium" setting and I am guessing the heat output on "medium" to be handled just fine during continuous use.  Comments?
Oh, and I was going to order a pack of glass lens from DX (here: http://www.dealextreme.com/p/52-8mm-replacement-glass-lens-for-flashlights-5-pack-25231) while I was at it.
Input, comments, opinions are welcomed.
Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
JohnnyMac
JohnnyMac's picture
Garry, I have the same drop-in installed in a 3D mag with the same glass lenses.  A great combo, if you ask me. Tons of flood and average throw but not for lighting stuff up at a distance. Mine runs off of 3*18650 cells and it's an awesome setup!
I haven't noticed any heat issues as there is a lot of mass in that drop-in compared to a p60. I wouldn't worry about it too much.  I think oldbobk has done a lot of these conversions with no issues.  Hopefully he will chime in with any advice he may have.  Good luck!  You will love it!
garrybunk
garrybunk's picture
Glad to hear!  So maybe I can relax a little more about the heat.  Yes, I've seen some posts with bobk's work and hope he chimes in.
Thanks,
Garry
P.S. - Didn't realize it could run off 3 cells.
cd520
cd520's picture
Last seen: 5 years 9 months ago
I also have the same drop-in in a 3D mag with no issues. Mine runs off of 3 26650's.
