Where it is best to buy some spare parts
7 posts / 0 new
gorann
Last seen: 7 years 9 months ago
I have seen info about those things here on the foru,m, before a week or two, but I cannot find it anymore.
Now I cannot even remeber proper English names for these parts.
First of all I need thos insulator plates which go around the LED, below the reflector. I need them for C8 type of flashlights .
Secondly, rubber rings for C8 sized flashlights (and mabe for HS801/802) .
SO, 10 pcs of each, something like that.
Which webshop has lowest prices for these...?
Thanx
gcbryan
Someplace in China however I'm not sure you'd be able to deal with them due to Chinese human rights violations. If that's not a problem try DX. You're looking for o-rings and I don't know what you call the insulator plates or if they carry that.
There is MacMaster Carr in the U.S. for many parts but not specifically for flashlights. However, you might not like dealing with an American company due to all the people killed in the name of U.S. supremacy.
You might try a Swiss company or maybe you'd feel more comfortable with a Croatian company. No names come off the top of my head at the moment however.
Good luck.
SPAMBOT
SPAMBOT's picture
Last seen: 2 years 1 month ago
Good luck.
Inflammatory and unnecessary, let it rest.
What size is the o-rings you seek? Knowing their diameter would be a good start. As for LED insulators, try Kaidomain.
Now with 100% all natural asbestos!
gcbryan
The easiest thing (I've found) regarding o-rings and DX is just to order all of them. They are cheap. Or at least any that they carry that you could possibly use.
If you need one in a hurry you might be able to find some in a local hardware store. I don't know what's available in Croatia but there is a chain of hardware stores in the U.S. called ACE Hardware and they have a flat file type of cabinet in most stores with a pretty good selection of both imperial and metric o-rings.
Vectrex
Vectrex's picture
Last seen: 10 months 1 week ago
Regarding isolators:
http://old.kaidomain.com/SearchResult.aspx?SearchKey=Isolator&CategoryId...
I ordered the 16mm ones and they fit perfectly in P60 dropins.
gcbryan
The interesting thing is that ACE Hardware stores are the smaller (local neighborhood) stores. I can't find o-rings in Home Depot or Lowes (the largest stores).
Buwuve
Buwuve's picture
Last seen: 2 years 8 months ago
You buy such isolators? Why don't you build them by yourself. I cut them out of a thicker piece of paper. It isn't important for me, that it has no glue. If I need glue, I use 3M Spray Mount (this is a special glue for things which should be removed).
Light up the darkness.
