Upcoming New--Haikelite HT35 HD Zoomy flashlight (2300Lumens)
76 posts / 0 new
HaikeLite Official
HaikeLite Official's picture
Last seen: 1 week 3 hours ago
hello
HT35 is a zoomy flashlight . It uses XHP35 emitter, 2000 lumens with forward momentary on switch
It will get ready for sale next week.
Below photos agreed by member “the backpack on the road”, who is testing and reviewing this light for us.
Specifications:
Emitter: CREE XHP35 HD 6500K CW / 4800K NW
Material: 6061 aluminum alloy
Battery: 2× 26650 / 2×18650 (not included)
Switch: Momentary Forward Switch
Waterproof: IPX8 level
Max brightness: 2300 Lumens
Focus Beam range: >1000 meters
3 Modes: High 100%>Mid 30%>Low 10% , always start on High
Brightness and Runtime:
— High — 2300Lumens
—Midium—700 Lumens
—Low —-200 Lumens
Twisting the body to adjust the beam
Dimension: 210mm x 72mm x 36mm
Weight: 600 gram
Accessories: O rings , a dedicate belt , removable camera screw, removable tactical ring
HaikeLite Official--all rights reserved
www.haikelite.top
Skype: haikelite@yeah.net
Edited by: HaikeLite Official on 07/17/2017 - 12:58
Mstevens113
Mstevens113's picture
Last seen: 1 min 55 sec ago
Interesting, I like zoomies Big Smile
The Miller
The Miller's picture
This looks quite interesting
IPX8 rating on a zoomie!
casi29061965
Last seen: 1 hour 30 min ago
Interested !
But I miss a LowLow-mode…
Greets
Carsten
stephenk
stephenk's picture
Last seen: 23 hours 49 min ago
Looks very interesting – look forward to seeing a review with beamshots!
jescereal
jescereal's picture
Last seen: 1 week 14 hours ago
Any plans for a MT02 with an XHP35 HI?
Pok
Pok's picture
Last seen: 2 hours 38 min ago
Any plans for a MT07 with an XHP35 HI + SMO ?
cloggy
Last seen: 3 hours 47 min ago
Available in Germany for 79.90 euros- approx $92.
Chinese lights are often released in Germany before the UK or US I’ve always wondered why.
Hopefully there will be a group buy for this interesting light.
cloggy
Mstevens113
Is it a screw twist type zoom or sliding type?
HaikeLite Official
It is a screw type
thanks
www.haikelite.top
HaikeLite Official
MT02 only HD version… MT07 will have a xhp35 Hi version.
www.haikelite.top
Duramarks
I always wanted to try out a zoomie. This may be the one.
HaikeLite Official
cloggy wrote:
Available in Germany for 79.90 euros- approx $92. Chinese lights are often released in Germany before the UK or US I’ve always wondered why. Hopefully there will be a group buy for this interesting light.
we have US dealer now. But have not got an UK dealer yet
This light will be ready for sale next week
www.haikelite.top
freeme
freeme's picture
Last seen: 16 min 2 sec ago
1km+! Nice.
desmondkun
desmondkun's picture
Last seen: 1 hour 27 min ago
The tactical ring, is it aluminium or stainless steel? It’s so thin.
Take care of your flashlight and your flashlight will take care of you.
JLAu
Last seen: 1 day 16 hours ago
i would be perfect if only using single 26650 Thumbs Up
HaikeLite Official
2×26650 has double runtime and good heat handling.
We will release single 18650 zoom light for rifle.
www.haikelite.top
stephenk
stephenk's picture
Very interested in the single 18650 zoom light. There is a lack of good 18650 zoom lights on the market!
Fatlight
Fatlight's picture
Last seen: 1 month 1 week ago
Beneath this unassuming plain design belies one of the world brightest production aspheric throwers in specification. Unfortunately i ‘suspect’ the choice of xhp35 hi instead of xhp35 HD with a higher lumens and a narrower output beam angle incident to the ~66mm aspheric focuser lens means that the throw beam would be less straight and less impressive in throw than the HD option. Tired The price is also pretty steep compared to its production cost.
If U R reading this, U R also a Flashaholic. Pfft <3
Lexel
Lexel's picture
Last seen: 1 day 12 hours ago
The dome also magnifies the die size, the result is less throw even if you got 15% less lumens and slightly wider light cone
XHP35 HI are as well availiable in E2 and E4 bin
Downside is shipping costs below at leat 10 of them
Lexel
Lexel's picture
I got both those LEDs
The die size is the same
Fatlight
Fatlight's picture
For reflectors , the led dome will magnify die size increase spot size and decrease amount of light thrown from a narrow beam angle getting less contact with reflectors surface but For aspheric lens, the dome helps narrow the light beam and increase the amount of light focused thereby reducing side spill wastage which not captured by the lens. From my extensive testings with larger aspherics lens, The beam angle usually gets straighter and higher lumens is captured with domed led equivalent, giving incredible throw distance even thought the die spot is slightly magnified.
But i dont know what lens is used apart from the sneak preview beam shot which shows a narrow pyramid shaped throw aura so i can only suspect the beam is not totally straight and henced have not reached its maximum potential in throw.
Lexel
Lexel's picture
the beam after the dome gets narrower, yes but the LED has a fix number of divergence*emitting area
just look at this picture both LEDs have a 1mm² emitter size, but the one with the higher dome looks like 6mm²
an aspheric lens does magnify the emitting surface to decrease the divergence, the dome is a second lens that already increases the emitting area the aspheric can see, so the hotspot gets bigger while more light is collected
so if you narrow the beam with a dome the emitting area is projected bigger
so your hypothesis of the dome increasing throw is false its simple optics
HD gets more lumens in Throw, but a way bigger area —> less throw
Fatlight
Fatlight's picture
From my decades of extensive led testing experience, im sorry i have to disagree with your opinion. A straight beam of the same lumens will always out throw a divergent beam soon enough.
Lexel
Lexel's picture
proof you are wrong
same LED just shallow dome and high dome
the high dome projects a at least 5 times larger size of the emitting area to the Aspheric lens
of course the high dome will have like 300% more lumens
result 300%/500%=60% throw
just read just one of the good aspheric thrower topics with cd measurements
Fatlight
Fatlight's picture
Well my point is that a straight beam gives the maximum throw in potential than a divergent beam. it is up to one to find a good combination of aspheric lens and led to get the straight beam. The sneak preview for this light shows a divergent beam with a Hi undomed led so i think a domed led will give a straighter beam . You can proof im wrong only after you had tested both but not before my friend. As i say i only suspect its the case but it will ultimately be proven only after one has tested both so its premature to make any absolute judgement yet. Silly
Lexel
Lexel's picture
You can look at the emission graphs, the HI version has higher intensity near 0 degrees and less intensity to wider angles.
hank
hank's picture
Last seen: 2 days 10 hours ago
So it’s for sale where?
Who is “the backpack on the road”?
rizky_p
rizky_p's picture
Last seen: 1 day 17 hours ago
Just got email from Haikelite, there are now available on Gearbest i think m4dmax already got a coupon deal. so it is worth to visit his website.
djozz
djozz's picture
Last seen: 23 min 13 sec ago
So this is another aspheric flashlight that has loads of fins on the slider, which is mass and volume that is not as effective as can be because the heat has to pass the slider/body barrier (in fact a layer of silicon grease in the threads) to get there The heat will get there for sure but the led is left hotter than when the fins can be reached by the heat without passing bottlenecks.
But perhaps in practice there is enough surface area between slider and body that the barrier is not really a bottleneck?
That still leaves the humble and budget sk68 as the only zoomie that has the fins in the correct place.
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
HaikeLite Official
Thanks for the information.
Meanwhile, as our led supplier can not source back 35HI NW on time, HT35 emitter will use 35 HD version. The focus beam turned out to be even nicer.
www.haikelite.top
