Interesting find from Dx neutral white drop-in
26 posts / 0 new
agenthex
agenthex's picture
Last seen: 6 years 11 months ago
I bought and got this:
http://www.dealextreme.com/details.dx/sku.12501
And it turned out to be 2 mode hi-lo. Nice low mode (maybe 25%?), too.
It took a lot of poking to get them to ship it (was in "waiting for supplier" forever, kept changing back and forth, and I pinged them several times) so I've ordered another one just to be sure it's not a fluke (that they somehow obtain one not from normal stocks just to placate me).
Reading this makes you smarter: http://lesswrong.com/
Edited by: agenthex on 09/01/2010 - 01:49
FlashPilot
FlashPilot's picture
Last seen: 6 hours 11 min ago
That does look like a nice find. Reading one users review comments at DX, he mentioned that this drop-in doesn't perform as well using 1 li-ion as it does on 2. Have you found this to be the case? Can you get a tailcap reading on high mode for me? I'm interested in how much current it draws at 4.20v. I also wonder if you got lucky with the 2-mode... I want one too!  Thanks.
"Posted by sparktastic -  This drop-in will work from a single 3.7v cell but the output is reduced slightly.
I have noticed minor flickering for a short time after switch-on, occasionally when running on a single 3.7v cell. Maximum brightness is acheived with a supply voltage of at least 4.5V. Works fine on 12-14V as well (for anyone thinking of running these from a vehicle supply. Current draw at 12v is around 330Ma. I like to turn these into compact throwers by replacing the stock OP reflector with a smooth one from an sku.5937. This setup works very well in one of my favourite hosts the WF-502B."
agenthex
agenthex's picture
I don't have a 2 cell p60 host and my 2x 16340 are just ordered from dx, so not yet. Hard to read a warmer light as I don't have a point of comparison, but if I'd had to guess, close to 200lum on high (at least 150) and maybe 50 on low (just right, not like those shiningbeam "lows"). Frankly, if you can reproduce my order (I hope I can, too), I think you'll be happy.
I'll do a tailcap reading later, I just left for a conference.
FlashPilot
Alright Agenthex,
You twisted my arm. Im in for one. Who knows what driver they will give me with that. I can always mod it if I dont like it. Does yours flicker on 1 x 18650?
agenthex
agenthex's picture
I can't tell any flicker. The driver does have a very slight medium pitch buzz sometimes, though, which would imply a decent freq PWM. I was really pleasantly surprised at this item, I've never seen a low-price two mode, nevermind one that's actual well designed from a chinese maker Tongue out, which is why I'm cautious.
agenthex
agenthex's picture
Hmmm... I might've overestimated the 200lum, prolly closer to the 150. It only measures .6A with 1 cell, or about 2.4W to the circuit. The very good/clean throw prolly threw me off. Still, very happy w/ it.
FlashPilot
Thanks for checking for me. If you're happy @ .6A draw, then I cant wait to get this into my 504B. It should last forever at that current. If I dont like it, I'll simply swap the driver.
FlashPilot
It just shipped. That was fast! I should see it in about 3 weeks and will report back on how the driver performs. Thanks again!
agenthex
agenthex's picture
Damn DX, I'm pretty sure I ordered my second one before you and it's still pending. Yell
FlashPilot
I ordered mine on 9/5.
agenthex
agenthex's picture
8/31, still "awaiting stock". They figured I already had one.... why rush.
Nautic
Nautic's picture
Last seen: 1 year 4 months ago
Same here! Grrrr.
Cheap quality is good - Expensive crap isn´t
FlashPilot
Now I wonder if they sent my the right dropin.
FlashPilot
Im looking forward to the 5A tint. Check out a tint comparison I found on CPF:
agenthex
agenthex's picture
My second still hasn't shipped, but FlashPilot, I did measure brightness on 2 lithiums.
About 2.2 times brighter (center spot) on the lightmeter I just recieved.
FlashPilot
Thanks but Im not sure that I understand you.
Are you saying that it is 2.2 times as bright on 2 x lithium cells than one 1 x lithium cell? Please explain.
agenthex
agenthex's picture
Yes. Looks to be about linear (or slightly more) with voltage, implying the current is held flat from at least ~4v to 8v. I actually have a bench supply to find the whole curve, but I haven't pulled it out in ages.
FlashPilot
So... it sounds like this would do better with 2 x 16340 than on 1 x 18650? If so, the driver seems better optimized for 8.4V. Lets hope I get the same driver as you.
agenthex
agenthex's picture
First of all, I'd like to apologize to anyone who bought this because I said it was a 2 mode light. It is not. Now, the reason behind this:
I recieved this on the same day my solarforce L2 came in. I stuck it in and it is two modes. I liked it so much I never took it back out. But this was not because the drop-in was two modes, and today I found out why. The tailcap on the L2 is two stage??!!!ones???  I found out only because I was testing it with two lithiums for FlashPilot and the "low" mode in that case was not the same proportionate linear drop compare with that of one battery, which is suspicious for a more advanced density regulated driver. I'm going to investigate further when I get time.
I've never had a host with a switch like that, or any stock light for that matter. Are all L2 solarforce tails like that?? My L2r certainly isn't.  I've never heard of it nor can I find any info on the web that states this. I bought this in Sand from ITC.
So that's the bad news. The good news is that you can keep following my misplaced recommendations and get a L2 like mine (what better excuse?). Big Smile
I still like it a lot and it's my go-to light in this config.
agenthex
agenthex's picture
Also, to address the 2 battery issue: I think this is going to be very clos to the limite for the emitter. The tail current is a bit over 0.6A . Assuming fresh batteries ~4V under load that's 4.8 watts, and with typical 3.9v Vf for a XR-E @ 1A that's around 1.2A plus losses.
Is there an easy way to measure current across the emitter?
The light w/ 2 batteries and low stage on my L2 is similar to high stage on 1 battery (numbers from meter).
FlashPilot
We all make mistakes. I have a 2-mode tailcap in one of my lights and I like it. Although the resister isnt that efficient, I almost never run it in low mode. In fact, thats true of almost all of my lights. lol Thanks for the report. Im still looking forward to my warm drop-in..
FlashPilot
I just received my 5A tint drop-in today and must say that I'm quite amazed. The neutral color is so much easier on the eyes and brings out the natural colors in whatever the beam illuminates... just like the photos I linked to in the above posts. No wonder people still use incandescents. They have roughly the same tint characteristics. I'm actually glad its a single mode driver. It does many things well that I wouldn’t have expected - thanks to the neutral tint. For instance, I can look at things close up without destroying my vision and then use it as a mid length thrower to examine more distant objects... all in the same single mode! I have to adjust modes on my other white tinted lights to prevent bringing discomfort to my eyes while adjusting ranges, but not with this one. Also, this drop-in has a fantastic large bright neutral flood with a bright hotspot and an almost perfect beam with no chromatic differences throughout the entire beam width.
I haven't pulled tail currents yet but will say that its obviously not driven hard because it runs cool. I run all my drop-ins wrapped in copper foil to wick away heat from the drop-in to the host. Since this didn’t get nearly as hot as my R2 drop-in, I became suspicious. I left it running for half an hour and immediately pulled it apart to check out the internal temperatures and star to pill interface. All is well. That’s fine by me because this will be used for long night explorations deep in the woods, where runtime will be important. Besides, if it were any brighter Id feel compelled to mod it into a multimode, and then it would lose a lot of its quick aiming abilities while being easy on my eyes and semi-night vision. It will get a real workout this Friday night. I'm flying back into the Frank Church Wilderness for some camping, hiking, exploration and isolation. My 5A sits happily in my damn-good-looking chrome 504B with a thick GITD o-ring in the lens. Surprisingly, the o-ring doesn't block any of the beam output and glows like crazy when the light is off.
Great find Mr Agenthex!
Nautic
Nautic's picture
I ordered it at DX due to the recommendation here. But after 3 weeks I got the message "sold out"
I got a refund and ordered this from KD: http://www.kaidomain.com/ProductDetails.aspx?ProductId=9770
I would have preferred the 1 mode from DX, but will see how it performs when i gets here.
In the meantime I´ll consider this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280534988227&ssPageName=STRK:MEWAX:IT#ht_1956wt_955
which agenthex gave me a hint to.
The color is the main thing here not the brightness, so I´ll probably need to buy it anyway to see for myself Smile
agenthex
agenthex's picture
I gave a review of the Solarforce LC-Yellow drop-in here:
http://budgetlightforum.cz.cc/node/638#comment-9927
Just got the LC-yellow. It's similar but slightly better than the DX neutral. It's about 4000K as they said, but NOT a p3-8b.  Draw is 1.1A instead 0.6A of DX one, so it's brighter, but slightly warmer (DX is maybe 4500K).
The driver's also different. DX maintains constant current at 0.6A, so with two batteries, it's about as bright as SF, whereas the SF ramps to about that on 2 cells. However the DX maintains its brightness better as 1 cell goes down.
So there you have it. Perhaps a bit better on 1 cells, tint is close enough, but not a huge win. Worth the price.
Biggest plus is that at least it'll be in stock.
Nautic
Nautic's picture
Thanks for update and information on the Solarforce warm white. I think my KD is too yellowish,
so if I´ll get another one is gonna be the SF. Good that its brighter.
You know I got the Warm White 502B and that will be enough for the moment together with the
one from KD. I use them where I have to get as much natural light as possible to identify things.
agenthex
agenthex's picture
Another data point on the LC-Yellow: as implied above, the output drops pretty quickly. When the cell is at 3.8v, the draw is only .45A
