Hello.
This is my first ever flashlight review so I will try my best :)
Flashlight was provided from Sofirn with 99% discount. My review won't be affected by price.
Specification from manufacturer:
LED: Cree XP-L2 V6-2A-D, 1100 Lumen, 5350-5700K, 11200cd
Operating voltage: 2.8-4.2V
Battery: 1x 18650 Battery
Switch: backward tail clicky
Size: 13.2cm length, 2.5 / 3.2cm diameter, 118g (without battery)
Material: 6063 Aircraft aluminum with Type III anodization
Reflector: smooth
Battery warning: Blinks every 2 sec. And turns off one minute later
Deep discharge protection: yes, at 2.8V
Lens: Hardened glass lance with AR coating
Waterproof: IPX-8 (2 meters for 30 minutes)
PWM frequency: 20kHz
Strobe: 6 / 12Hz
5 Mode: High 1100lm 1h28min; Mid 300lm 4h15min; Low 50lm 18h; Firefly 1lm 147h; Strobe 1100lm 2h56min;
Mode Memory: yes
Tail-stand: yes
Package:
Sofirn SF36, 18650 2800mAh battery, USB charger with 70cm cable, manual, belt clip, 2x o-ring, lanyard
Flashlight has nice feel and looks good quality.
Threads are square but little thin. They are anodised and came well lubricated.
Tube is not reversable.
Tail switch is reverse clicky mounted on 17mm board. It has nice click, but maybe little soft feeling (very easy to press, compared to others)
Flashlight can tailstand, but was not perfect na was wobbly. I cut 1mm from center of rubber tailcap and now perfect.
Driver is 19mm, but you could put 21mm with no problem. It's fixed with retaining ring.
Wires to LED are 24AWG
It has 4 modes with memory and strobe on double click. Modes are nicely spread.
Head has SS bezel. Glass is 27x2mm AR coated and reflector is SMO. AR coating is very light, but it's there.
There is o-ring between glass nad reflector and reflector has groove for o-ring to sit nicely.
LED is XP-L2 and is on 17x1,6mm copper board.
There is 1 screw holding board to shelf. Shelf is fixed, so no pill.
There is good amound of thermal paste between board and shelf.
Flashlight is 132mm long, diameter is 25,5mm at tail and 32,5mm at head.
Beam has some rings in it, not sure what is the reason.
Charger is Thorfire branded, with micro USB input.
It charges to 4.19V (if my multimeter is correct).
Battery is Sofirn branded, with protection. It came with protection sticker on + side.
Tested capacity with Lii-500 is 2628mAh so not that bad.
Some comparison pictures with Thorefire VG10 and Convoy S2+
Current measurements:
Cheap dmm, not sure how accurate it is so I made measurements on some other flashlights to compare.
Used ICR18650-26C battery
SF36 | VG10S | VG10 | S2+ 6*7135 | |
Moon | 0,03A | 0,01A | 0,01A | |
Low | 0,16A | 0,15A | 0,09A | 0,18A |
Med | 0,98A | 0,93A | 0,77A | 0,92A |
High | 3,20A | 3,10A | 2,51A | 2,13A |
