So why CAN'T the driver go in the tail ?
27 posts / 0 new
wle
wle's picture
Last seen: 11 hours 30 min ago
So why CAN’T the driver go in the tail ?
Someone on this thread: “The FW3A, a TLF BLF special, elegant, triple, powerful flashlight” ( http://budgetlightforum.com/node/54239 ) asked this question.
It seems like that would help with the heat-dissipation problem: the LED gets hot, and the driver gets hot, so why not separate them?
The same current has to travel from battery to driver, as from driver to LED, so that can’t be it…
It would make ‘active switches’ or ‘soft switches’ and lighted tail caps easier to implement..
What would make that not work?
wle
L4M4
L4M4's picture
Last seen: 8 hours 56 min ago
Well, you would need very long cables between driver and the LED – plus a thicker tube with place for those cables – or if you make it flatflex, you still need that.
It makes it just more complex – for example, how do you change the battery? You will have some cables in the way, no matter where you open the case
The Miller
The Miller's picture
Last seen: 2 weeks 1 day ago
Yes it can be done
But wires need to be guided to the LEDs 2 drawbacks here, 1 the round rube nicely fits the round cells and resistance of longer wires
In case of drivers with some sort of thermal stepdown one want it close to the LEDs.
wle
wle's picture
The Miller wrote:
Yes it can be done
OK, so one wire, or two (with thermal sensing).
Enderman
Enderman's picture
Last seen: 10 hours 32 min ago
Not needing any wires going up the tube is the main reason, it simplifies manufacturing a ton.
Drivers typically produce very little heat, a few watts or tenths of a watt, so it’s not an issue to have it near the LED.
Even flashlights with charging in the tail cap choose to use a double ended battery (with both + and – on each end) to avoid any wires or other complications in the tube.
eebowler
eebowler's picture
Last seen: 2 days 14 hours ago
The Imalent DM 21 has driver and USB charger in the tailcap without wires running through the body. It is possible. Driver, battery and switch are all in series, so it shouldn’t matt where these component are in the string.
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
emarkd
emarkd's picture
Last seen: 14 min 25 sec ago
I’m not sure that’s true. They’re all in series along the negative current path, but the driver has to have access to Vcc too, just like the emitter. So that side of the circuit is parallel.
Enderman
Enderman's picture
Nope.
Most drivers have + and – contacts for the battery, then + and – wires for the LED.
Lexel
Lexel's picture
Last seen: 3 hours 10 min ago
It is easily doable with 2 tubes for the driver positive and LED-, like Klarus build their lights
there is no need for the LED positive cable to go to the driver, as its connected with the battery +
It can be done without any cables or double tube, with a battery that provides positive and ground to the driver in the tail and use a p channel fet for the LED+ and battery ground for LED-
Ozythemandias
Last seen: 1 day 2 hours ago
Or the HDS method with a wire in the body.
jimahi
The Imalent DM21T does not have a wire going to the head. The driver (with brightness control knob) and usb charging are in the tail. It can be done without a wire running from driver to battery +.
The one thing the DM21T is missing is LVP. The driver does not have direct access to the battery voltage. LVP in their design would require a more complicated driver that approximates battery voltage by measuring current and knowing the Vf of the LED at that current.
Enderman
Enderman's picture
This is not true.
Maybe on some very basic drivers, but not the large majority.
Just take a look at the PCB, you can see it does not just go straight through.
The Miller
So you see it can be done, but all that do charge a hefty price for their lights
For Narsil and Bistro based drivers that allow temp stepdown using the MCU it still is best to have led and driver close together or a temp sensor needs to be installed, adding complexity in parts and assembly AND sacrificing a MCU pin for the read out.
kiriba-ru
kiriba-ru's picture
Last seen: 9 hours 2 min ago
FET is not driver Grad
The Miller
I am talking about BLF developed firmware that has the option to use the temp sensor build into the MCU for user calibrated thermal stepdown vs using extra parts to measure temperature.
It is quite useful to have the MCU located in the area where it can actually sense temp Wink
kiriba-ru
kiriba-ru's picture
You are talking about pretty names that some useless parts of firmware used to call here. Simple thermal resistor on pcb can do this job (thermal stepdown) better (much better) than mcu-integrated sensor (regardless what firmware do you use). There is no sense in applying so much efforts in firmaware which should manage so simple hardware.
FET is not driver. You can not garantee any value. Each of them will be always different. Simple things that are usual printed on brand light boxes – smth like runtime@100 lumens – cant be calculated, because fixed mods do not exist.
wle
wle's picture
Good Discussion! Smile
About the “modern/fancy drivers need direct access to + voltage” argument, though …
Couldn’t there be a “leakage path” up at the LED, so the driver is never really without current?
Then the driver, or micro, or whatever you call it (the active electronics) will have some juice to run on, without a direct connect to the + terminal.
The Miller
kiriba-ru wrote:
The Miller wrote:
I am talking about BLF developed firmware that has the option to use the temp sensor build into the MCU for user calibrated thermal stepdown vs using extra parts to measure temperature. It is quite useful to have the MCU located in the area where it can actually sense temp Wink
You are talking about pretty names that some useless parts of firmware used to call here. Simple thermal resistor on pcb can do this job (thermal stepdown) better (much better) than mcu-integrated sensor (regardless what firmware do you use). There is no sense in applying so much efforts in firmaware which should manage so simple hardware. FET is not driver. You can not garantee any value. Each of them will be always different. Simple things that are usual printed on brand light boxes – smth like runtime@100 lumens – cant be calculated, because fixed mods do not exist.
Hm. Sounds a bit negative.
I am not talking about FETs just stating hoe Narsil and Bistro achieve thermal stepdown without the need for a thermistor.
Yes as I wrote a dedicated part for measuring can be done.
Yes as you write, there is a big difference in how each individual driver without it measures temp.
(I have read it is the MCU doing the measuring not the FET)
Hence the clever workaround, one selects thermal stepdown instead of the default timed stepdown and the light starts on turbo, one selects the desired stepdown temp and it doesn’t really matter that other same hardware drivers measure temp different for it is setup based on that individual unit.
So i don’t disagree with what you say, I merely explain why IMHO things are done how they are done in the lights I know a little bit more about Wink
kotobuki
Last seen: 23 hours 57 min ago
This Costco Duracell 700 lumens flashlight has driver circuit in a tail:
Batteries, LED and driver circuit are in serial, but it needs a 24 Ohm resistor parallels with LED to pre-feeds power for driver circuit. Circuit likes that will “eat” some more energy (~ 200mA) from batteries when turns ON (because of current goes through LED and resistor at same time).
pilotdog68
pilotdog68's picture
Last seen: 3 weeks 2 days ago
Yes it can be done (at least with a linear driver). It is a DC circuit, current is flowing in one direction so Pos+ Voltage is available anywhere in the circuit without any extra wires. It is this principle that allows the illuminated tailcap to work.
So why isn’t it popular here?
1. It makes a bigger tailcap necessary, which can be really ugly and is not accommodated by many hosts.
2. Driver modding started with Qlite drivers (which have a Pos+ battery connector), and evolved from there.
3. See below:
warzi1975
Last seen: 1 day 19 hours ago
Ultrafire UF10 and UF9 have Drivers in the tail and they are my coolest 16340 lights. You can drill the tube to fit a 18350, I made it on three lights.
Robert
Enderman
Enderman's picture
An illuminated tail cap is literally just another LED in the circuit, that’s why it only needs to be in line to work.
For any kind of modern not-super-basic driver there needs to be separate positive and negative to both the driver and LED for it to work properly.
Stuff like LVP, battery indication, cc regulation, etc…
That stuff is not possible if you simply have battery->driver->led->battery.
In this case the driver would literally just be an in-line resistor, it would not have any other functionality.
EasyB
Last seen: 2 hours 11 min ago
With our drivers the battery positive does “pass through” to the LED, but it’s still connected to the driver. The MCU needs the connection to the positive to work.
Jerommel
Jerommel's picture
Last seen: 1 month 3 days ago
So it’s impossible to have a driver without +
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
Enderman
Enderman's picture
Technically you can, it would basically be the same thing as a resistor.
Maybe it would be possible to have it switch between different resistances too to change the brightness.
But for most drivers, the advanced kind we use in flashlights, it would not work (not properly, at least) if you connected + directly to the LED bypassing the driver.
pilotdog68
“just another LED in the circuit” still requires Pos+ and Neg- just like a full driver does.
As I quoted in my post LVP would be difficult to get accurate, and I agree with all of your Pos+ running throught LED the LED would have to be on for the driver to be powered, but this is currently true of clicky lights anyways. This configuration would not work for a an e-switch driver, granted.
I mentioned the illuminated tailcap because I was met with the same resistance with it “It’s not possible, it won’t work” even after it had been proven to work.
We already have existing lights with the driver in the tail and no additional wires, so it’s ignorant to still say “It’s impossible!”. It’s just a matter of “how much do you want it?”
Lexel
Lexel's picture
drivers in tail without double tube or wires
or special battery with both battery contacts to tail
the lights from Imalent have big drawbacks
first 33 Ohms bleeder resistor, jes 33 no 0 missing, so in lowest mode the bleeding current is on a normal Vf of the LED a bit over 100mA
2. slow PWM at 400Hz even at full brightness to power the driver in the off time
this pwm can be noticed by eye in multiple situations
3. LVP is almost impossible to do in the Off time, because it may be tricky to sense this while the inductor is draining power through the bleeder, to drive the MCU during on time
