Project Excalibur - Next Generation LED Thrower (many pics) - UPDATE 2018-01-24
173 posts / 0 new
MRsDNF
MRsDNF's picture
Last seen: 27 min 58 sec ago
Smile nice.
luminarium iaculator
luminarium iaculator's picture
Last seen: 3 weeks 1 day ago
Really, really nice Wink
The_Driver
The_Driver's picture
Last seen: 9 hours 13 min ago
Thanks again guys! Wink
I think these might be the last ones for a while. The long distance ones where always my goal.
The_Driver
Maxabeam Gen3 @75W vs Project Excalibur :
270m:
M4D M4X
M4D M4X's picture
Last seen: 1 min 56 sec ago
impressive light!
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
slmjim
slmjim's picture
Last seen: 8 hours 10 min ago
Fine craftsmanship + advanced skills = near-priceless tech.
Respect.
Great... Carnac the Magnificent tells me I just signed up for yet another expensive hobby.
Smile! It makes others wonder what you've been up to.
The_Driver
The Osram Black Flat that is currently in the light has started to become damaged. There is a black dot in the middle that is growing over time when the light is used. To recap, this led has it’s maximum brightness at 4.45A (tested on a large, passively cooled heatsink) and it’s driven at 4.5A in the light. I sometimes run the light for longer periods at max output.
My plan is to put the new Osram Boost HX LED into the light when it becomes available. The light was designed with such a high-current LED in mind (driver goes up to 12A, lots of mass). Using a more conservative current (6A-7A?) and advanced heatsinking techniques (soldering the led with Indium, liquid metal thermal paste) should ensure that the LED never dies again. With a bit of luck the luminous intensity should stay the same and not drop as much when the light is running.
The wider beam with at least 50% more lumens will be more visible making the light more impressive.
DB Custom
DB Custom's picture
Last seen: 2 days 3 hours ago
The black spot forming is usually because the emitter got something on it, a spec of dust, oil from the hands, a bit of thermal compound or a splash of flux from soldering… something on the face of the die burns into it when running and ultimately kills it. I had this happen to two emitters in my 17 emitter monster, had to disassemble it and replace them which was not easy. Totally understand how it feels, so disappointing but in the end it can be a good thing as we learn along the way, right? Wink
I need to learn to anodize without ruining the parts I just made… Wink Your light is very nice looking, bet you can’t wait to make the new improvements.
The_Driver
Yes, that is also a possibility. In this case the spot is exactly at the center of the die where the highest temperature is reached. I think the LED is overheating by quite a bit. The strongly degrading brightness that I measured (down to 70%) also points to this conclusion.
Most people use this LED in smaller lights with DD drivers. The current falls quickly in those lights. In my light the LED is driven slightly beyond it’s absolute maximum continuously until the batteries are empty (2h).
I think I need to be much more conservative regarding the current.
DB Custom
DB Custom's picture
Is the MCPCB isolated from the copper pillar? The Black Flat requiring isolation from ground due to the negative lead sharing the ground pad is problematic when trying to keep a good thermal path, I’ve found. My answer is to glue the MCPCB down with Arctic Alumina Thermal Adhesive, it allows a good thermal path but isolates the current. That or re-flow the MCPCB to the copper sink and just use direct drive with the current limited, no modes….
Enderman
Enderman's picture
Last seen: 43 min 13 sec ago
Could this be from that laser you had pointing at it? Or was that a different LED?
The_Driver
No need for isolation. My light was designed for this. Thats why we used a battery carrier that has both contacts on the same side (thus no current flows through the flashlight body).
No, we would never use a cherry picked LED for such testing.
Lexel
Lexel's picture
Last seen: 26 min 20 sec ago
why not use a white flat for it?
link to that LED you mean
DB Custom
DB Custom's picture
I see, good thinking. Wink
For more beamshots, have you considered having someone operate the light from a set point and you, with the camera (or the other person) go to a different position closer to the target area for a closer picture of the object being lit from afar? It really makes a difference to see the object from fairly close, with light on it from a long way off. I did this with a water tower and my wife ran the flashlights, just amazing the effect. (Illuminated the water tower from 1.9 miles)
This was a 2 photo comparison to show the difference between a warm white and a cool white (yes, 2 lights), in a light misty rain. I was positioned about 200 yds from the tower, wife was 1.9 miles away to the left and behind me.
The_Driver
Because the Boost HX is a better version of the 2mm^2 White Flat. Is tolerates higher currents because of its larger package (lower thermal resistance). Upgrading my light is costly and requires a lot of work ((dis)assembly, cherry picking the led, focussing etc.).
Here a German description.
@DB Custom
Interesting idea. Maybe I will try that at some point. Wink
Enderman
Enderman's picture
@DB Custom
Your thermal design through that copper rod is already pretty restrictive, a 1mm white flat would probably perform much better than a boost HX due to the current the boost HX will need to match its intensity.
Unless you just want a brighter beam with more lumens, then yeah the boost HX is a better choice.
The_Driver
@DB Custom
Yes, I want more lumens instead of even more Candela. 1.7Mcd is quite a lot.
The thermal design is far from perfect, but compare it to many other lights that are modded around here. Many lights have threaded pills. This design was chosen to make focussing easier.
Enderman
Enderman's picture
CFT90 Big Smile
The_Driver
CFT90 Big Smile
I wish it were possible…
The host is too small for this led and I find it too expensive.
LouieAtienza
Last seen: 1 year 2 weeks ago
Awesome build and construction quality!
DB Custom
DB Custom's picture
I have yet to put this to the test, but have discussed it with a couple of friends that also have long distance throwers… we calculate the maximum throw distance based on 1/4 lux (the approximate brightness of a full moon) but how cool would it be to go out there, at measured distances, and see if you can read by the light of the flashlight. Say at 2 miles away can you read a girls phone number (or a guys or the pizza delivery or whatever) written on the inside cover of a matchbook? At what maximum distance is it still possible to use the light from the flashlight to read such a note?
With today’s technology it wouldn’t be so difficult to take a photo of the light and use the geo-tag for location, same for the matchbook out at distance… take a photo with the phone and use the geo-tag to locate it and then measure between the two points. It’d take a special kind of place to allow a higher position for the flashlight and plenty of room to walk out to the end of the beam… keeping my eye open for just such an arrangement. Big Smile
Edit: Oh yeah, I figure the matchbook holder could use a laser pointed straight up so the flashlight holder would know where to shine the light. Communication via the phones would be helpful as well. This would allow more minimal use of the lights cells so as to keep output to a maximum. Wink
The_Driver
It would be interesting to put the Osram Ostar Projection PC-green KP CSLNM1 F1 into the light. It would do around 2.4Mcd or even more.
I prefer to wait for the Boost HX though.
