New BLF GT Narsil M Cheat Sheet for v1.2 NEW VERSION
46 posts / 0 new
joechina
Last seen: 1 month 1 week ago
What JasonWW said. Smile
Read please the sentence in the cheat sheet above your mark in the right corner.
There is Narsil and NarsilM
M stands for Multichannel. The firmware supports up to 3 output channels.
Joe
lichtpfadfinder
lichtpfadfinder's picture
Last seen: 2 days 16 hours ago
Damn it. I have NarsilM 1.2 already on my Q8 and was thinking the newest Cheat Sheet already took the new features into account. My fault.
JasonWW
JasonWW's picture
Last seen: 1 day 3 hours ago
So you updated your Q8 yourself?
Here’s some notes for NarsilM v1,2.
For Vers 1.2 2017-10-16:
ADDED : (from MAD777, maybe others) if strobes are disabled, a 2X click from 2X turbo should restore the previous level you were at
FIXED: 4X clicks in modes operation engages lockout – not supposed to
ADDED: operation change: make click&hold in MODES or STROBES wrap from 1st mode to last
FIXED: in LVP switch LED control: the LED sometimes is left on after an LVP drop, and is not blinking the way it should be. The “bug” is that I’m trying to control the switch LEDs from multiple places so it’s getting turned off quickly after turned on, and left on when it should be left off. It’s a timing thing, so has sort of a random pattern – sometimes left on, sometimes left off. The 8 sec LVP blink need to be qualified better, and should not be calling Setlevel() as is because it wants to control the LED
FIXED: temp stepdown should not happen right away from turn ON. Delay it by 15 seconds
FIXED: for temperature stepdown, in moon mode, a temp stepdown is actually done because moon mode is marked as special level 255, which is considered as a high level of output instead of very low. The stepdown results in the light switching much brighter. This should only happen id the temperature threshold is set to a low temp, or the light is still hot and not cooled down when moon mode is chosen. It can also result in an immediate jump to the stepdown level as soon as the light is turned on in moon mode. Might appear as a bright flash when ramping first starts.
There’s more previously implemented:
- added momentary/tactical mode via 5X clicks in ramping mode – only active til a power reset (full turbo only when switch is held down) – It’s only accessible from ramping mode, not Mode Set operation
- full BLF GT buck driver support
- capability of setting max ramping to less than full max FET (Hi mode), while the 2X click still goes to full FET turbo. This is being used for the GT buck driver configuration.
- added more compile switches, little better custom configuration of the source in header files
I’m sure it’s just a matter of time and we will get a cheatsheet for this new UI.
lichtpfadfinder
Yes I flashed it today. Don´t know why, but somehow I thought was for NarsilM 1.2 already... I think I´m getting old laughing
joechina
No, I want to release wenn v1.2 is no longer beta.
And i try to find a way to keep the versions for GT and Q8 in sync. Right now it will be manual copy + paste.
The newest on the Google drive has the modes table changed to be the same as in the manual.
And the notes below as user help.
A problem is it was never intended to use the CS without reading the manual first. But it seems people jump on the cheat sheet first.
joechina
The Cheat Sheet for NarsilM v1.2 is ready.
Name:
NarsilM CS v12 Q8 2017-11-23.pdf
I also made a Rev. C for NarsilM v1.0
I hope it’s the last one
Name:
NarsilM CS v10 Q8 2017-11-23.pdf
(only Lazy-R-us must update Smile )
Both are under http://bit.ly/narsil-cs
The name key:
CS cheat sheet
v10 version number v1.0
Q8 Lamp (GT should follow soon)
date (more newer, more better, more stuffed)
steel_1024
steel_1024's picture
Last seen: 1 day 9 hours ago
That’s great.
Thank you joechina
Sorry for my poor english.
MRsDNF
MRsDNF's picture
Last seen: 6 hours 48 min ago
steel_1024 wrote:
That’s great.
Thank you joechina
+1. Nice work. Thumbs Up
lichtpfadfinder
Great News. Thanks Smile
joechina
Hello,
two new cheat sheets for NarsilM v1.2 are up
- one for the Q8
only mayor change is a link to a video for beginners to program Narsil.
http://bit.ly/narsil-vid3 from 8min30sec on
Name is:
NarsilM CS v12 Q8 2017-12-03
- one for the BLF GT
Name is:
NarsilM CS v12 GT 2017-12-03
Look for it under http://bit.ly/narsil-cs
steel_1024
BLF-GT user manual V1.2 draft
Link below:
BLF-GT user manual draft12.pdf
LichtAn
How do I get into moon mode with the “modes” setting?
JasonWW
JasonWW's picture
Simply turn on moonlight in the settings, then it becomes part of the normal levels.
For instance, with all the default settings, if you switch to mode sets you will have 4 brightness levels. If you turn on moon mode, you will now have 5 brightness levels.
joechina
I found a review with two nice UI-Diagramms for the Q8.
Maybe they are better to understand. The setup / programming part is missing.
Look here:
http://www.candlepowerforums.com/vb/showthread.php?443580-Review-Thorfire-BLF-Q8-5K-lumen-designed-by-FLASHAHOLICS!
ahirshy
Last seen: 5 hours 7 min ago
Hey Joe - these cheat-sheets are a fabulous piece of work!
Would never know where to start without your and CRX diagrams handy. Incredible firmwares between Tom E and ToyKeeper's offerings.
Between all the various versions, settings, configurations in just Narsil, Bistro & Anduril, plus juggling all the other niche, budget and designer flashlights with their own UIs, it's becoming impossible to figure everything out without a guide. And I consider myself a techy, flashaholic with a good memory!
I'll even admit that many of the more advanced UIs I frequently end up resorting to a Reset, just to make sure I haven't left it in some ridiculous mode or advanced setting!
Anyway, was just wondering if there are any plans or status for the NarsilM v1.3 guide?
It's the default UI on the Astrolux S43 since 2018, and Banggood are even linking to draft documentation in their product pages:
Operation Instroctions:
Click Here To Get: User Manua1
Click Here To Get: User Manual2 ( Detailed Explanation Of The Manual )
Assume you'd provided these and agreed to their dissemination, so hoped there was an official version to become available on your Google Drive...
All the best and thanks again for all the hard work and continued efforts,
ARH
