TK's Emisar D4 review
5353 posts / 0 new
dgq3
Last seen: 2 years 1 month ago
Yes, I’ve had it recalibrated already. Its now set at 65 and given the limit is 70, there is not much leeway left for higher settings. It would be nice if there would be higher limit. Or a more precise temp sensor.
I’m adventurous but I know myself – once I disasseble something its never the same again… Big Smile And not in a good way Sad
sbslider
sbslider's picture
Last seen: 7 hours 30 min ago
I don’t believe ( others may correct me) but I don’t think you can set the temperature with the original firmware. But once you set it up the way you want there’s no need to change it again. If its not working for you then you need to change firmware or get a bigger light.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
dgq3
You can not set it precisely by clicking a button (like you can on Andúril firmware), but after the calibration it blinks out the new setting. And mine blinked 65 Smile
sbslider
sbslider's picture
Seem like your set up fine for now then. Hope you enjoy your D4 Smile
dgq3
Yes, it’s a really nice flashlight. Anodizing is flawless, machining is perfect and the amount of light coming from it is just mindblowing. Can’t wait for winter, it will be a great hand warmer too Smile
sbslider
sbslider's picture
Can NarsilM be loaded in the D4?
DB Custom
DB Custom's picture
Last seen: 1 month 1 day ago
Normal and essentially inconsequential dgq3, you’re going to find virtually all the optics have such markations from the molding process.
Don’t worry too much about the temperature readout, set it for what you can handle and the light will be fine. The electronics can take FAR more than you can. The difference between the readout and your means of measuring the external case are both going to have some variance, this can add up to what seems like a lot, but it’s still all about not burning your hand, so just take care of you and all will be well. Wink
sbslider
sbslider's picture
I think I answered my own question when searching revealed This post
moderator007 wrote:
I reflashed the attiny85 with NarsilMQ8.
Just need to find that now.
Newlumen
Newlumen's picture
Last seen: 6 months 3 weeks ago
I dont know this has been told.. sony vtc5a is great in the d4.. i mean vtc5a beat vtc5 by big margin..
Emisar d4 xpl hi 6500k
Sony vtc5a 4000 lumen
Sony vtc5 3600 lumen
dgq3
That is why I smartly measured the difference at ambient temperature, when the light was cold Smile
And it’s kinda like a waiter getting used to handling hot plates, I can’t stop playing with it and can already feel my hands hardening Big Smile Maybe in a few months I could add 10 degrees, but the light can not. Well…whatever, it’s not a real issue anyway Wink
eas
eas's picture
Last seen: 9 months 1 day ago
The “scratches” or striations you marked look to me like the result of turbulence and minor temperature variations during the molding process. I’d guess they are inescapable, and baked in to the original design & specification.
ToyKeeper
ToyKeeper's picture
Last seen: 6 hours 56 min ago
dgq3 wrote:
Also my temperature readout is way off, showing 15 degrees more. But I’ve read I’m not the only one here Smile
Yeah, sorry, the D4 doesn’t have a way to calibrate the sensor. It only has a way to set the maximum temperature.
The D4S fixes this, and I made the D4S code also work on D4/D1/D1S, but I don’t know if Hank will update older models with the new V3 firmware. It would probably need more testing and maybe some tweaks before it can be considered stable on the older models. In particular, thermal regulation settings require hands-on testing with fully-assembled lights, which is time-consuming.
But I run Anduril on literally all of my Emisar lights, and it seems to work pretty well. I don’t use turbo long enough for thermal regulation to be needed though.
ToyKeeper
ToyKeeper's picture
Yes. Just don’t rely on its thermal features, because they’re designed for hosts with a much lower power-to-mass ratio. NarsilM should work fine on the D4 as long as you regulate heat manually.
The Q8 config should work without any changes. I think its voltage readout might be off by 0.1V though, due to a difference in diodes used on the two models. I see in my configs that the Q8 has a fudge factor of 0.35V, while the D4 uses 0.25V.
pennzy
pennzy's picture
Last seen: 7 hours 45 min ago
Can anyone tell me what the mid way flash signifies in the upward ramp?
Man Without Shadow
Man Without Shadow's picture
Last seen: 1 hour 48 min ago
(highest fully-regulated level)
66: 159.46 lm (FET turns on here)
should see it on the way down too
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
pennzy
pennzy's picture
Thanks. About how long will it run at that level?
Man Without Shadow
Runtimes:
Runtimes will be approximate because the ramp is too smooth to be able to stop reliably at any particular level.
With a 3000mAh cell:
Standby: 0.02mA / 17 years
Lowest mode: 1.7 lm / 9.6mA / 13 days
Medium mode (lvl 65): ~150 lm / 350mA / 8.5 hours
Highest mode: 2000 to 4000 lm / TBD / maybe 15 minutes
The output on the low levels (from moon to ~150 lm) should be fairly stable as the battery drains. The lowest mode might sag over time though, due to the brand of 7135 chip used. I’ve informed Hank about this, and I hope future batches will use one with better moon-mode performance.
The output on turbo will drop quite a bit over time due to heat, voltage sag, and thermal regulation.
On the medium and high modes, from ~150 lm to maximum, output will drop over time proportionate to how bright it is. For levels like 200 lm, the graph should still be pretty flat, but for 2000 lm it will sag quite a bit. Performance in these modes is a hybrid between current-controlled and direct-drive, so the typical direct-drive sag becomes more prominent as the light goes into higher and higher levels.
pennzy
pennzy's picture
Thanks again. I’m trying to figure out where to set it for sustained use like taking walks etc. Helpful info.
sbslider
sbslider's picture
Edit – I just read over the NarsilM UI again and it looks like everything I want is already in Anduril.
Thanks for the feedback. I just got a Second D4 and I may change the firmware to NarsilM to compare it to Anduril.
ToyKeeper
ToyKeeper's picture
Go for it, it sounds like fun. Smile
But I may be biased; I think everyone should get a soldering iron and firmware flashing tools, and dive into modding. Nothing will ever be exactly how you want it unless you create it yourself.
For someone just starting out though, the BLF Q8 or Emisar D4S are probably the easiest. In both cases, the processor is accessible without unsoldering anything. The Q8’s driver comes out with just a couple of loosened screws, or the D4S has flashing pads where they can be reached without removing the driver at all.
Just be careful to get the fuse values right in avrdude, because bad fuses can kind of “brick” the processor. It’s still recoverable with a high-voltage programmer, but those have a much higher barrier to entry. Known working values are in the bin/flash-85.sh script.
DB Custom
DB Custom's picture
FWIW, TK is pretty demanding on her code. I have randomly flashed Anduril to quite a varity of lights with no adjustments to the firmware and have yet to see any discrepency. YMMV
sbslider
sbslider's picture
After reviewing NarsilM I realized everything I am interested in can be done with Anduril. I wish my D4 had flashing pads, but even that light is pretty straight forward to do, now that I have flashed one D4 already.
vresto
vresto's picture
Last seen: 2 days 22 hours ago
what about this flashlight and panasonic flat top the green ones? are this 18650 ok for this flashlight?
thanks a lot
EDC-Amutorch X9 XHP50 nw,Sofirn If-25A cw
Headlamp-Thrunite TH30 nw
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 2 days ago
@vresto, in this light, you want flat top 18650s that can handle a lot of power.
That means green Panasonics, like the NCR18650B, are not suitable for the light, since they are low drain.
You want something like a Samsung 25R, LG HE4, Samsung 30Q, LG HG2, Sony VTC5/VTC5A/VTC6 to get good performance out of the light.
vresto
vresto's picture
but this green ones are unprotected…its matter? is it a big difference between them in lumens??
BlueSwordM
@vresto, yes it does matter. Unprotected is always better, but what matters the most is the power the 18650 can output.
A Panasonic NCR18650B is rated 4.875A of continuous discharge current, while a Sony VTC6 can sustain 20A of continuous discharge current.
That means that the NCR18650B is rated at a max of about 15W, while the VTC6 can sustain 70W of power.
That means that not only will the Emisar D4 lose a lot of lumens if ran on an NCR18650B, it will also make the 18650 degrade much faster.
vresto
vresto's picture
oh okok.thanks a lott:)))))))))))))ň
goshdogit
goshdogit's picture
Last seen: 1 hour 29 min ago
BLF member ‘moderator007’ posted about Arrow.com offering free overnight shipping with no minimum order in the US, and a low price for Samsung LH351D 5000K 90CRI emitters.
I saw that Arrow.com also carries Carclo’s 24mm quad optics that the D4 uses. Its stock optic is the 10622 narrow spot.
10623 medium spot frosted
10624 wide spot frosted
This is an inexpensive (and fast!) option for Emisar owners in the US who’d like to try a floodier D4. I’m getting one of each. Party
bansuri
Last seen: 5 hours 11 min ago
Wow, I just put TK’s preconfigured Anduril on a D4. Awesome!
Love being able to configure the ceiling and still have turbo if needed. Will really help with battery life.
Of course all of the special modes are super-cool, will be going to bed with the Sunset or Candle mode every night!
Fully configurable beacon is the best beacon yet.
Thanks TK for all of your hard work!!
sbslider
sbslider's picture
