TK's Emisar D4 review
5321 posts / 0 new
vresto
vresto's picture
Last seen: 1 day 9 hours ago
iam sorry…i was not following this…its new driver for emisar d4?…
EDC-Mezzol X8R-L nw
Headlamp-Thrunite th30
bansuri
Last seen: 1 day 4 hours ago
Same driver flashed with different firmware.
Check the links in TK’s sig for more info.
dgq3
Last seen: 1 year 6 months ago
Has anyone tried running Emisar D4 with flat top cells?
Thing is… I have both flat and button top Samsung 30Q, all around the same age, but I have felt that with the flat top cell the light output is lower.
Today I have it confimed by a luxmeter in my phone. Ceiling bounce, same setup, flat top cell shows around 360 lux, button top cell 450-ish. Which is quite a significant difference.
Can anyone confirm my findings? Could it be due to lower pressure on the springs because flat top cell si shorter?
varbos
Last seen: 21 hours 38 min ago
Is this what I need to flash driver on Emisar D4?
Quote:
Required hardware:
USBasp V2.0 programmer (ebay, fasttech)
Pomona 5250 SOIC clip (Digi-Key) (Cheaper alternative. See post #167)
40-pin Splittable Ribbon Cable (20cm) (FastTech)
USB extension cable (optional but helpful) (EBAY)
(http://budgetlightforum.com/node/36216)
Thanks
sbslider
sbslider's picture
Last seen: 2 weeks 6 days ago
Quote:
Required hardware:
Thanks
I purchased all those items except the extension cable. you only need 6 wires IIRC, but not I bought a wide cable like suggested. I also bought this item and was glad I did. It allowed me to verify my test setup while I was waiting for the clip. The clip I purchased was the cheaper alternative. The Arduino board is definitely not required, but for a few $ more it provide me chance to practice before connecting with the real part on my board. I used the Arduino board just to connect to the ATTiny85 and verify the rest of my setup was good, I also flashed it with Anduril, just for practice.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
DB Custom
DB Custom's picture
Last seen: 1 day 15 hours ago
dgq3, you’re probably right… spring compression can make a lot of difference in output, I see it all the time on the light box. The flat top 30Q should have better performance as it doesn’t have the added steel button top which has high resistance comparatively. You can see the internal resistance value of the cell on a charger like the Opus or MiBoxer C4-12. Edit: The manufacturer’s make these cells for battery packs, like in drills or such, and don’t put button tops or protection circuits on the cells. Aftermarket sellers add the button top or protection circuit, with a wide variety of issues associated therein. Wink Sometimes these added button top plates are welded on nicely, sometimes not. Sometimes not at all, only being held in place by the insulation disc and the wrapper.
I just put a pair of Samsung 30T 21700 cells on my MiBoxer C4-12 and saw internal resistance values of 13 and 14. After testing with one and putting it back on the charger, it showed 9!
Pavlo
Last seen: 3 hours 4 min ago
A question for D4 owners who own more or have tried more than 1 D4:
Ignoring heat, CRI, and throw, which LED between XP-L HI and 219C has the best tint, and why?
alex64
alex64's picture
Last seen: 2 hours 14 min ago
Pavlo wrote:
A question for D4 owners who own more or have tried more than 1 D4: Ignoring heat, CRI, and throw, which LED between XP-L HI and 219C has the best tint, and why?
I have Nichia and XP-L 3A 5000k and the best tint with no doubt is Nichia, the tint is a relatively white but when illuminating shows very natural colors. The XPL-HI 3A is not a bad tint at all, but compared to the Nichia it loses.
The problem with the D4 Nichia (not so much in the D4S) is the heat, which makes that the stepdown constantly lower the power.
AEDe
AEDe's picture
Last seen: 17 hours 21 min ago
Optisolis-D4 mod.
EDC with 800lm of stabilised 99cri light)
d_t_a
Last seen: 4 hours 31 min ago
probably will let the pics speak for themselves…
wall is about 18 meters away from flashlight,
camera set to “daylight” white balance
control shot:
D4 XPL-Hi “5D” 4000K
D4 219C 90CRI default 10622 optic
D4 219C 90CRI floody 10623 optic
Pavlo
Thank you Alex64, and d_t_a for your input and photos!
AEDe, the optisolis mod with buck boost driver looks amazing. I wish I had the skill to do that! Thank you for sharing.
AEDe
AEDe's picture
It hard to get from gtranslation, but author choose more simple way. Boost driver with s2p2 led config. You can see there that mcpcb has bypass and cut to change config.
varbos
Is there any news that D4 on Hanks store will receive latest firmware (with configurable ceiling) ?
djozz
djozz's picture
Last seen: 13 min 55 sec ago
The black D4 has been sold out for some time on intl-outdoor, if Hank would have been in time making new ones his sales would be better (I do not see the black D4 ceasing to be popular any time soon, even with new models, the D4 is simply the best Emisar light). Does that maybe indicate that an upgrade D4 is in the make?
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 18 min ago
I don’t really know Hank’s plans. I fixed a stepped ramping bug though, and am going to send him an updated copy of RampingIOS V3 for each Emisar light.
The bug isn’t a serious one; it just acted weird when two ramp steps were exactly 128 levels apart and the step size happened to land exactly on the guess from imprecise integer math.
Anyway, I’ll send it but I can’t guarantee he’ll use it.
flucero28
Last seen: 6 months 1 week ago
Can anyone tell me the screw size for the two screws that hold down the LED PCB? My aluminum D4 has flat head screws which allows for my 3D printed glow gasket to fit just fine. My D4 TI I just got has round head screws. Much too large to allow the 3D gasket to fit under the optic. I would like to get two flathead screws for my D4 TI.
lowprofile
Last seen: 1 year 3 months ago
My aluminum D4 has the round screws too, but the threads will be the same.
I could take one out and measure it tomorrow when I have my tools, but any fastener store worth its salt should be able to help you if you bring it in. They will be able to measure the length, diameter, and thread pitch, and if they don’t have it they should be able to tell you where to get them.
Emisar D1S, D4S, Convoy C8, many many lesser lights
You have to squeeze a lot of lumens if you want to make lumenade
mortuus
mortuus's picture
Last seen: 40 min ago
How come he decided not to sell the green and blue anymore, would u know TK ? i think the colors now are really boring even tho its a nice light we need more color options like before, even if price goes up let it be so..
...where Frugal meets with Flashlight!
lowprofile
Question:
Is the D4/D4S circuit diagram available anywhere?
I can probably figure it out myself (trained in college) once I open it to flash it, waiting for my soic clip, but before taking it apart I was wondering if there are any spare outputs on the AVR microcontroller.
sbslider
sbslider's picture
lowprofile wrote:
Question:
You don’t need a circuit diagram to flash the part. You just need to be able to identify pin 1 on the IC, and how to wire up the flashing interface of your choice. I can’t answer the question definitively about spare pins, other than I know pin 1 is not used in circuit, in order to make it easier to flash. I suspect there is another unused pin, but my bare board is at work right now, otherwise I would inspect it to see. Based on the picture in this post, I believe pin 7 in unused. The picture should help you find pin 1 also.
ToyKeeper
ToyKeeper's picture
Pin 7 is available.
On the D4, pin 3 is also available, and even has a solder pad connected to it. This was set aside to control aux LEDs or a button LED, but it wasn’t used. It is used on the D4S though.
I don’t know why Hank changed the colors available. I think he said the green was very difficult to get right though.
funkychateau
funkychateau's picture
bansuri wrote:
Wow, I just put TK’s preconfigured Anduril on a D4. Awesome! Love being able to configure the ceiling and still have turbo if needed. Will really help with battery life. Of course all of the special modes are super-cool, will be going to bed with the Sunset or Candle mode every night! Fully configurable beacon is the best beacon yet. Thanks TK for all of your hard work!!
Does the fully-configurable beacon allow you to independently set on-time as well as repetition rate? The biggest complaint I have with my D4 beacon is that it is really just a “blinker”. A true beacon should have a very short on-time so that it can be full brightness yet still preserve battery life.
ToyKeeper
ToyKeeper's picture
Nope, it’s 0.5s on, (N – 0.5)s off. But if you want to change the duty cycle, it should be very easy to do by changing one or two lines of code. It’s open-source.
funkychateau
It’s tempting, especially after reading through the 5K or so posts in this thread and seeing that many users are successfully modifying their code. But it would be a first effort for me, and I’m reluctant to risk one of my favorite toys in a learning exercise. And I remember someone (was it you?) may have mentioned that certain missteps result in an inoperable and unrecoverable (without special hardware) brick.
The D4S seems to be slightly more mod-friendly, and I’m already tempted to buy one of those. And I seem to remember reading someone’s (you again?) notion that maybe a beginner’s hardware/software programming kit could be offered as a turnkey “get started” package. I’m more likely to get my feet wet that way, then look at the D4 after gaining some confidence.
ToyKeeper
ToyKeeper's picture
I haven’t managed to get any stores to carry a starter kit yet, but I still hope that can happen sometime. One of the main steps right now is finding a way to manufacture Lexel’s flashing key, and getting more brands to use it on their drivers.
However, it’d also be nice to have a kit based on a more common chip clip. (SOIC8 clip)
Man Without Shadow
Man Without Shadow's picture
Last seen: 2 hours 53 min ago
Here is close to a “kit”:
I’ve read hundreds of posts and finally successfully flashed. Here is a condensed version of the hardware and software you would need if running a Windows computer (I use Windows 10)…enjoy!
I had some trouble figuring out exactly what to buy, but I figured it out after reading all the posts for months. Just get those three things I linked below for hardware.
I bought this:
https://www.amazon.com/gp/product/B00AX4WQ00/ref=oh_aui_detailpage_o02_s…
and these:
https://www.amazon.com/gp/product/B077×7MKHN/ref=oh_aui_detailpage_o02_...
and this from ebay:
https://www.ebay.com/itm/Programmer-Testing-Clip-SOP8-Pin-SOP-SOIC-8-SOIC8-DIP8-DIP-8-IC-Test-Clamp-NEW/172420293749?hash=item28250ce475:g:sjYAAOSwK~RaTaoE
you have to bend the clip pins a bit, but works fine and it’s not 20$!
ya…cheaper from china…but not by much, and I prefer Amazon reliable quick ship. Not worth saving 3 or 4$ ordering from china and waiting a month.
Windows programs:
uspasp driver:
here is the driver and manual for the chip programmer…read page 7 for install
scroll down for the driver download and manual pdf
https://protostack.com.au/shop/accessories/usbasp-avr-programmer/
avrdude flashing program:
https://sourceforge.net/projects/winavr/files/
hit the green download button…installs an “install” program…
TK’s hex files library:
http://toykeeper.net/torches/fsm/
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
sbslider
sbslider's picture
If you plan to do this for the first time, I would recommend adding a board like this to your purchase list. It allowed me to program a dummy part without tearing apart my light and risking damage the first time. The one I bought was local and cost less than $4. In the total cost of things it was worth it for sure.
Also DEFINITELY use a wooden tool to try to remove the board. I forgot this on my second attempt, broke a chip resistor using a metal object, and still have not recovered, even after replacing the broken part. I think my clip is just not connecting, but I have put this project down for a bit.
DB Custom
DB Custom's picture
sbslider, that’s why he’s interested in learning on the D4S, it has programming vias on the driver board so you don’t even have to remove the driver. Wink
sbslider
sbslider's picture
Blushing
DB Custom
DB Custom's picture
Hey, it’s a good tip though, what you said… for sure I’ve busted up some driver components trying to bust glue before just like you said. I’ve learned to eyeball down in the hole and maybe feel around a bit with the tip of a small jewelers screwdriver in an effort to get on the pcb before hitting it. Wink
I remember one that was a true PITA, couldn’t get it to budge. Finally got it all apart and it was the strangest set-up, they had a small driver board up top of the contact driver board and I had knocked the screwdriver all the way through that first board! Totally annihilated it, what a mess! lol (a solarforce light, if I recall correctly. Had a top board soldered into a brass holder and the bottom board also soldered in then the assembly is press fit, sure a trick to get out)
