TK's Emisar D4 review
5353 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 17 min ago
I’m not sure, but I think the D4v2 bezel threads may be slightly different than the D4v1 bezel threads. I’ve had difficulty swapping that particular part between the two. I was able to put a v1 battery tube on a v2 head though.
BOO5TED
BOO5TED's picture
Last seen: 2 hours 18 min ago
Cool thanks, just got a D4 on trade and might try it out. Looking to get the deep clip, 10621 optic and the bezel. It’s only a few bucks and if it doesn’t work I can pass it on.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
Firelight2
Firelight2's picture
Last seen: 4 hours 48 min ago
BOO5TED wrote:
I’ve looked through the thread but didn’t see anything and I’m sure it’s been asked already but will the stainless bezel from the D4V2 fit the original D4?
Yes … I have the SS bezel from a D4V2 on a grey original D4 right now. It fits perfectly.
BOO5TED
BOO5TED's picture
Great! I’ll order them tonight.
P.S.
TK, it’s green too lol.
firestorm
Last seen: 7 months 1 week ago
mine did not fit. d4 ti bezel to d4v2 ti
Firelight2
I also tried sticking my blue-colored D4 Ti bezel on my D4v2 Ti’s copper head. it fit fine.
Note however, that some of the titanium pieces… the bezel and the tailcap… will not fit on the aluminum head and body tube. But that is not unique to the D4v2. The original D4 and its Titanium version had the same problem.
firestorm
i tried this one. does not fit. the threads are slightly different. all Ti’s. was gomna swap the heads since the v2 is only available in raw color.
zaxar0580
zaxar0580's picture
Last seen: 1 day 15 hours ago
This video shows that the SS bezel and D4V2 magnet cover is suitable for D4V1 https://www.youtube.com/watch?v=3bG-JNVL0Nw
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 9 hours 41 min ago
Not all V1s fit ss bezel. Only for those from later batches. For example, my black D4V1, which I bought at the end of the V1 sale, has a different thread than the white D4. Ss bezel matches black, but not white. It’s a lottery. If you bought D4V1 late then it will rather match. For some reason, after putting ss bezel on the white, the gap is much larger.
firestorm
Groundhog66
I received a secondhand D4 today, how does one go about updating the firmware on this light?
Also, is it recommended?
I am not a collector.
nick779
nick779's picture
You can if you want to, but it doesnt really matter unless it was avery early D4 with the first gen thermal management. Personally if it hasnt been done already id just switch it to Anduril and call it a day.
Check out the first post of this thread. You need to pop out the driver in order to flash the Attiny with a SOIC8 clip.
Groundhog66
I’m not looking to take anything apart, but what does switching it to Anduril mean?
nick779
nick779's picture
Changing the Firmware from one user interface to another. The D4 originally came with a firmware called RampingOS, later batches of the D4 came with an updated RampingOS or optionally Anduril.
If you dont want to take the light apart, you cant update or change anything.
Groundhog66
What are the differences in the ramping OS’s, how would I know which I have?
Also, what changes does the Anduril have?
Chatika vas Paus
centaurus3200
Last seen: 1 week 6 days ago
i have the original Emisar D4 that Hank kindly flashed Anduril before shipping it to me in June of 2019. not sure which version. i think the OS is technically for the D4S?
anyway, i want to increase the thermal regulation cutoff. i think it steps down too fast on turbo. but even with watching YouTube videos, i still don’t get it.
anybody have straight forward instructions? i think i have to use my infrared handheld thermometer? i don’t think it’s the OS where you just hold the light and click a button when you think it’s too hot to hold. i’m american, so i only understand Fahrenheit Wink
i love this light!
brewster
Last seen: 22 hours 11 min ago
If it is Anduril, the code installed on yours is more likely for the D4v2 not the D4S. In any case, just follow the Anduril instructions in the post immediately before yours.
I believe the late production D4 has the D4v2 driver board with pads for flashing. So you basically have a D4v2 engine but without the fancy bits (secondary leds, knurled battery tube, etc.).
lionheart_2281
lionheart_2281's picture
Last seen: 17 min 22 sec ago
I’m guessing the new K1, D4v2 Ti blue swirl and D4Sv2 will have the above version?
atobe
Last seen: 11 min 15 sec ago
They should just do 15+ clicks and it will blink out the firmware date in YYYY MM DD format blinks.
ᕦ(ò_óˇ)ᕤ I can always be wrong, probably 75% of the time.
lionheart_2281
Good tip, is there somewhere that gives date brackets with firmware versions?
centaurus3200
i figured it out. i have an infrared thermometer. calibrated the temp to 25C… i did 40 clicks above 30C… so 158 degrees. a little nutty, but i’d turn the thing off way before that. it still steps down… but sucks the battery dry a lot faster. is 40 clicks possible or is there a limit to the thermal cutoff?
Tom E
Tom E's picture
Last seen: 22 min 28 sec ago
70C is the limit. You can click more than that, but that will set it to the max of 70C anyway. If you want to fake it out to get the max set to 85C for example, calibrate room temp to 7C or so. That should help even more. 22C is ~72F (22 * 1.8 + 32).
centaurus3200
thanks Tom! yeah, i was wondering about cheating the room temp calibration… but other than experimenting with the“limits”, i realize it’s kinda pointless to make the thing melt in your hand. LOL!
it still dims even in my hand… given it’s RIDICULOUSLY hot when it does it… i assume the light hits an internal temp of 158 degrees on turbo fairly quickly anyway?
Tom E
Tom E's picture
Well, probably, but I'm not sure I trust that internal MCU temp sensor much. Can't do much with 4 LED's maxed out in such a small mass with such a small surface - not much of a thermal path, or, the thermal path is so good getting to the outside, that's why it heats up so quick. Gotta take a light like this for what it is - super power in a small package for short uses, or any lower power level you'd like for practical longer term use. For example, a few mins ago I used my EDC18 on a low setting to trouble-shoot my gas furnace. The mag tail meant I could place it perfectly above the area I was working in, and at 100-200 lumens or so, it can run comfortable at room temp.
 Better heat sinking of the driver would help - most of these kind of lights don't take the driver heat sinking seriously. More metal to metal contact between the driver and shell would help, as well as potting the driver. Now that we got external pin re-programming capability, potting should be considered.
centaurus3200
totally, i LOVE the D4. it’s such an insane little pocket rocket. turbo is mostly for “shock and awe”. but yeah… from moonlight to like 300 lumens. it’s super useful. and the candle light and lightning settings are relaxing. LOL!
centaurus3200
You are probably right. It definitely has the pads. Hopefully that means the later attiny chip too.
I’m guessing hank just put the V2 board in with anduril, rather than reflash an old board? If so, nice guy!
It still has that “notch” when the light switches from Regulated to FET. not sure if that means anything.
I kinda want a V2… But there’s nothing wrong with my D4.
ToyKeeper
ToyKeeper's picture
About the thermal response, if it regulates down, that doesn’t necessarily mean it has already gotten too hot. It means that it thinks it will be too hot soon if it continues along its current trajectory, and it’s trying to “turn into the curve” to avoid overshooting.
So it can sometimes adjust down before it’s overheated… and conversely, it can sometimes adjust up while it’s still hot, if it thinks it’s cooling off too fast.
Usually this effect is only noticeable during the initial burst at a turbo level, because at that point it heats up very quickly and the estimated future temperature easily goes over the limit. It doesn’t know enough math to figure out that the temperature rise will slow down naturally on its own.
If you update the firmware though, it may behave a little better. The thermal code has been completely rewritten. It’s not perfect, but it seems to behave better and it’s a lot more stable now after it gets close to a sustainable level. Older versions could go too far, overcorrect, and bounce or oscillate sometimes… or even just randomly go on a wild tangent because of noise in the measurements.
It means it switched from regulated to FET. Smile
It’s like how, on a know to change the panning of a sound from left to right, there’s usually a notch at the center point. It indicates that the adjustment just hit a meaningful level. It could be totally smooth instead, but then it’d be harder to feel where that point is.
iamlucky13
Last seen: 55 min 20 sec ago
I don’t understand the organization of Launchpad very well, but I think this link can help you find what you’re looking for:
https://bazaar.launchpad.net/~toykeeper/flashlight-firmware/fsm/changes/
And I think that’s the development branch, not the trunk. I don’t know if that makes a difference with respect to what Emisar’s ship with.
centaurus3200
Thank you TK!
That makes sense. When I double click back into turbo after it started stepping down the first time, it stayed brighter longer once it was already warmed up.
Not sure if I’m slick enough to update the firmware. It does have the pads though.
I might just quit while I’m ahead. Turbo for me is pretty much just for shock and awe for friends. I mainly use the light from about moonlight to 300 lumens. And I find the lightning storm and candle modes really relaxing. Haha!
