looking for a good multitool i cannot break.
28 posts / 0 new
snakebite
snakebite's picture
Last seen: 10 hours 52 min ago
i use them hard and often.
cheap chinese ones break with no effort for me.
even my gerber has unacceptable plier jaw flex and eventually get broken.lifetime warranty replaces them about every 2 years without issue.
but i want something i cannot easily break doing a demanding job.
even the leatherman has fallen short and ended up broken.
Pulsar
Pulsar's picture
Last seen: 10 hours 15 min ago
Could try a Victorinox multitool, but I feel you will end up with the same results. Had my Leatherman wave for 10 or so years, and its getting real worn, but its held up to the major abuse I put it through on a daily basis at work. But it is about time to get an upgrade.
Gerbers are not all that good, at least the few multitools and knives I have handled.
Could also browse through the Leatherman site and look at some of their beefier models. But there is a point that you should grab the proper tool for the job and put the multitool up lol
raccoon city
raccoon city's picture
Last seen: 15 hours 17 min ago
I think Leatherman makes the best multitools, but I do not use mine hard.
Tumbleweed48
Last seen: 4 hours 29 min ago
I have several, and my all-time favorite is a Victorinox. It’s a bit larger and heavier than most, but it’s taken a decade of constant carry and use so far without failing.
sp5it
sp5it's picture
Last seen: 1 hour 32 min ago
That multitool will be hard to break:
When you’re born you get a ticket to the freak show. When you’re born in America, you get a front-row seat.
raccoon city
It doubles as a decent melee weapon as well.
Pulsar
Pulsar's picture
As well as acquiring free items, including free transportation and free living quarters
kennybobby
kennybobby's picture
Last seen: 1 day 6 hours ago
sp5it wrote:
That multitool will be hard to break: !https://3.imimg.com/data3/EY/BE/MY-427876/crow-bar-250×250.jpg!
You would think it was indestructible—unless built by people that know nothing about metallurgy.
i bought one at a store that sells lots of pieces of metal that are in the shape of tools, and promptly snapped a tooth off the nail puller fork. Thinking i just overloaded it, i kept it around to use the toe end as a pry bar. Then when i needed that pry function it snapped off just above the heel!
Turns out it was made of cast metal—a casting poured into the shape of a pry bar and painted red.
Back on topic:
i carried a leatherman for 20 years until i wore out the leather holster—very handy to have for repairs in the field. i never broke one, but the grips bite into your fingers and hand such that you would be looking for some real pliers before too long. The gerber version has more of a pad on the grips but feels like it could be broken with hard use.
AlexGT
AlexGT's picture
Last seen: 16 hours 45 min ago
I am wondering what jobs do you use your multitool on that make it break so fast. Wanna share? Smile
snakebite
snakebite's picture
like changing an alternator on a duramax diesel.
almost collapsed the handles getting grip on the bigger bolts.
i expect the tool to take whatever i can give it.
i got it changed but thought this would send the gerber back to the scrap pile at the gerber factory.
its slightly sprung but still usable.
there was a $5 ratchet set in the truck but the socket split on the first try on the long mounting bolt.
will34
will34's picture
Last seen: 1 hour 24 min ago
I recently got a Gerber center drive, and at first I wasn’t very sure because I had bad experiences with Chinese made gerber products in the past. However the center drive seems to be holding up fine, what’s nice about it is that it can drive screws with ease as the axis is centered and can take standard 1/4 hex bits.
Adahn
Adahn's picture
Last seen: 17 hours 43 min ago
Do you have to do these jobs out in the wild where you have no place for a real toolbox?
Otherwise I learned the lesson the hard way to always use the right tool for the job…
carmantl
Last seen: 12 hours 50 min ago
I work heavy construction in ironwork. I swear by the Leatherman Surge. It’s a Wave on steroids. It gets used and abused every day. Yes, I have broken screwdriver blades off when using them as prybars. But those huge strong pliers have held up to just about everything. It’s heavy for a MT, but…I’ve got 30 pounds of bolts in my bags and 2 spud wrenches and a sleever bar and bullpin and 6 pound beater on me also. Weight is very subjective……..
AdrianWA
AdrianWA's picture
Last seen: 6 hours 58 min ago
Have you tried buying proper tools that you use for the job? Lets face it a multi-tool is not designed for heavy or rigid jobs.
Bort
Bort's picture
Last seen: 1 day 12 hours ago
Came here to say this, multi tools are not meant for regular heavy duty use, they are meant for light duty very occasional use
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
wle
wle's picture
Last seen: 4 days 3 hours ago
i;m pretty sure no multitool is designed for heavy use
just convenience , basically
wle
spinynorman
Last seen: 9 hours 59 min ago
I think I remember an episode of MacGyver where he removed the lug nuts from a deuce and a half with the bottle opener on a Swiss Army knife. So he has that going for him, which is nice.
mattlward
mattlward's picture
Last seen: 1 hour 49 min ago
I have carried the same one for over 10 years. I have broke blades and tips but the plier is a strong as when it was new. Get one of them with replaceable carbides and never look back! They have even seen time in the US military. I hated multitools before I got one of these on a WalMart close out for 20 bux!
http://www.gerbergear.com/Collections/MP600
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Olight S1A
Olight S1R
No Agenda
Last seen: 5 days 21 hours ago
I have multi tools from Gerber, Leatherman, and Victorinox and I would have to say the Victorinox is the highest quality of them all. I only have the Spirit X model from Victorinox but the SwissTool X which is a little bigger and heavier duty might be a better option for you.
DBSAR
DBSAR's picture
Last seen: 6 days 7 hours ago
I have had many different multi-tools, and the Leatherman Supertool is the only one that can survive my abuse. ( both gerber & Sog failed me) if you break that, then i’m guessing a crowbar as mentioned above. Big Smile
LumenHound
LumenHound's picture
Last seen: 1 week 3 days ago
Have a look at the Leatherman Charge ALX. Not as heavy as the titanium Charge and tough as nails. The optional expanded bit kit and bit extender are also well worth the money.
jealous57
Last seen: 5 days 14 hours ago
I have an old Gerber (Made in USA) that thing is a tank, A Leatherman Surge, I snapped the jaws on this one, was replaced under warranty, but haven’t broken it since. It stays at work. I also have a Skeletool CX that I have snapped the jaws on, also replaced under warranty.
I’d look at something built like the Surge, I am sure there are other models that are as beefy. The Vics also look like a decent option.
A quick look on leatherman’s site:
http://www.leatherman.com/heavy-duty-multi-tools
srs2000
Last seen: 7 months 1 week ago
snakebite wrote:
like changing an alternator on a duramax diesel. almost collapsed the handles getting grip on the bigger bolts. i expect the tool to take whatever i can give it. i got it changed but thought this would send the gerber back to the scrap pile at the gerber factory. its slightly sprung but still usable. there was a $5 ratchet set in the truck but the socket split on the first try on the long mounting bolt.
Unless I were stuck out in the middle of no where I don’t think I would even attempt that with a multitool. They just aren’t great to use.
You can pick up a Husky socket set with wrenches from Home Depot for around the price of a good multitool. I’ve had a set for over 10 years and nothing has failed with them and I don’t baby them. If anything goes wrong I believe it can be replaced at any Home Depot. I paid extra for black to make them harder to misplace. If you go with chrome you can get it a lot cheaper.
Sprinkles
Last seen: 15 hours 41 min ago
I don’t abuse my gerber mp600, so I can’t attest to how well it would hold up under extremely heavy use. However, it all comes down to what features are most important for you. I was curious about some of the options mentioned here, so I started looking some up. I didn’t see it mentioned here, so it probably warrants some further research, but it looks like the Leatherman Crunch might be one to look at. It’s something I hadn’t seen before, having a vice grip instead of a traditional plier.
teacher
teacher's picture
Last seen: 1 hour 46 min ago
I have both Leatherman & Gerber… but unless it is an emergency I use them within their capabilities. It has been my experience, anything can be broken.
Both of mine are still going strong…. even after a few emergency uses.
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
atbglenn
atbglenn's picture
Last seen: 8 min 43 sec ago
I have this barely used first gen Leatherman Skeletool CX for 6 or 7 years. It’s still in just about perfect condition. I might end up selling it to get the Leatherman Surge. If I end up selling it, I’ll only ship it within the continental USA.
I'm a second amendment guy all the way
alpg88
Last seen: 1 week 5 days ago
doing building maintenance for about 20 years , i use wave, for at least 10 years, it did brake few times, but was replaced under warranty no questions asked. before i used gerber, vix, and other no name tools, leatherman beats all of them,
tempo
Last seen: 3 days 16 hours ago
i got the surge after trying some victorinoxes
never looked back since
one needs big hands for the surge pliers though. one cannot get a firm grasp with small hand
