Review: Rofis TR15 (EDC with rotating head, XP-L Hi, 1xAA-14500)
4 posts / 0 new
Budda
Budda's picture
Last seen: 3 weeks 6 days ago
Due to severe time limitations, this review is published with a reduced amount of writing, pics, data.
I received the TR15 from Rofis for the review.
The TR15 is the latest flashlight from Rofis: a compact 1xAA/14500 (Included) flashlight with XP-L Hi emitter, electronic switch and their trademark rotatable head.
Here the specs from Rofis:
Following is the detailed specification of TR15:
• Adjustable-head flashlight, multi-functional usage
• Tail built-in magnet
• Utilizes a CREE XP-L HI V3 LED
• Maximum output of up to 700 lumens
• Boasts a peak beam intensity of 3175 cd and a throw distance of up to 113 meters
• Innovative single button offers access to three brightness levels and three special modes
• Integrated power indicator light to remind the user the battery power will close to depletion
• Memorized function ability
• Ultra compact and lightweight (diameter 22mm, length 97.5mm),net weight 62g
• Switch incorporates a specially designed lock function to prevent accidental illumination
• Reverse polarity protection prevents damage from incorrectly inserted batteries
• The mental clip can be attached to backpack, belt or pocket for easy carry
• Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
• A micro-textured reflector offers wide angle lighting
• Waterproof in accordance to IPX-8 (two meters submersible)
• 1 -meter impact resistance
• Tail stand capability
Inside the box: TR15 (with a Rofis 800mAh Protected 14500 cell), lanyard, spare o-rings, manual.
The TR15 in the linear configuration. The clip comes already installed and is not reversible.
XP-L Hi CW emitter in a small OP parable will still give reasonable throw.
The light has an overall smooth and linear design, with some knurling on it.
The switch is on the head and is wide and with a good feedback.
Here you can see the trademark rotation of the head, that convert a linear light into a L shaped one.
This feature allows you to use the light when clipped to your clothes as an angular light, or, to better direct light when the TR15 is attached to a metallic surfaces, thanks to the removable magnet inserted in the tailcap. Note the smooth but not anodized threads (physical lockout is not possible).
The rotating feature will add something in size, but the TR 15 remains hand sized in both configurations, with the switch always easy to operate.
UI:
- Press the switch once to turn it on and off.
- When the light is on, keep the switch pressed to cycle between the 3 modes: low, mid and high, in loop.
- Triple click activates the strobe.
- From off keep pressed the switch for 3 seconds to activate electronic lockout.
The switch has a red led underneath it that will blink red when battery is running low.
Beamshots at 0.5 meters from the wall
Output and runtime
My thoughts
The TR15 is well built and finished.
The TR15 is another addition to the Rofis line with rotating head, featuring the new LED and the double chemistry (nimh li-ion) compatibility. Despite the rotating head, the light remains quite compact for the form factor, and the magnet in the tailcap makes the light more usable in some situations.
It offers a simple interface, with 3 levels that gets considerably brighter with a 14500. Regulation on the tested levels is good.
I find TR15 lacking of an additional mode, between the 137 and 655 lumens of the mid and high mode: I’ll add a 300ish lumen mode of continuous output.
Also I’d like the TR15 to have quick access to high and low mode (yet with only 3 modes, it’s quick to scroll them to get to your desired one).
I’d like to see the TR15 come with a NW tint and a reversible clip.
Thanks to: AntoLed for the camera help and the luxmeter.
All my reviews, in italian and english, here: Lumenreviews.com
Edited by: Budda on 07/19/2017 - 19:06
MascaratumB
MascaratumB's picture
Last seen: 4 hours 37 min ago
Budda, thanks for your review, despite the time constraints! Nice light there!
As I may be interested in this light – if I get a nice coupon or discount Cash – I went to see other reviews and I found a mention to a “hidden” low mode. (http://budgetlightforum.com/node/55234)
I also like a quick access to low and turbo, and at least this light might have it.
Can you confirm if through a long press we can access to lower mode? And after that, does the cycle restarts?
Thanks again! Thumbs Up
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
glide 1
Thank you for this review.
Budda
Budda's picture
