question about manafont generic t6 drop in
6 posts / 0 new
lakemonster1
i just got my generic t6 drop in from manafont.  it puts out a hell of a lot more light than an xr-e but there is almost no focused beam(hot spot).  it seems to just flood the hell out of anything i shine it on.   it came with an op reflector that is made for an xr-e emitter and the reflector just sits on top of the emitter base.  is the reflector just not shimmed properly or something?  how am i able to adjust the beam so i get some throw out of this drop in?  at present, it just lights up the whole area upto about 100ft and thats it.  i know it doesn't throw as far as say a q5, but i expected more than i'm getting now.
thanks,
monty
lakemonster1
anyone?  my thinking is it should have a reflector made for that type emitter.  plain reflector instead of op wouldn't hurt either.
resley.elvisp
Last seen: 6 years 4 months ago
Since XM-L has a larger die, you might have less throw than a XR-E.
When I compare my different P60 drop-ins, my XP-G Drop ins has a tighter, more visible  hotspot, but in my opinion the XM-L dropins has about the same performance but also adds the flood.
how2
Last seen: 5 years 16 hours ago
Try unscrewing the reflector, also you could get a smooth reflector for more throw.
lakemonster1
thats just it, there isn't much if any focused beam.  it's all flood.  i'm assuming that with the reflector supplied with this drop in, i am not able to get enough of the emitter into the reflector to focus the beam.
joelmyer
Last seen: 8 months 2 days ago
+1.  Just got some 18650s & went out to play with the UF504 & SFL2P.  Range seems about the same but lights up the rest of the world out to the sides.
Joel
