Test/review of Efest LUC V4 Charger 2017
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 6 hours 28 min ago
DSC_0223
DSC_0224DSC_0225
This is a advanced four slot mains powered LiIon charger with 3 different current settings and power bank function.
DSC_0199 DSC_0200 DSC_0201 DSC_0202
It arrived in a cardboard box with specifications on it.
DSC_0210
The box included the charger, a power supply, a car adapter, a warranty card and the instruction sheet.
DSC_0211
The car adapter is a fairly standard one.
DSC_0212DSC_0214
But has Efest colors on it and a nice sensible warning label.
DSC_0227
The charger has a 12V power socket and the usb output on the back.
DSC_0226
The user interface is a display and one button. When charging it can be used to select current or turn the display off with a long press.
When the charger is unpowered it can also be used to turn on the usb output with a long press.
DSC_0941
During power on all the segments are shows: Current selection, Channel 1 & 2, usb output, channel 3 & 4
DSC_0942
Here I am charging 3 batteries at 0.5A.
DSC_0228
Specifications are on the bottom, but not very easy to read.
DSC_0230DSC_0231
The slots uses the classical slider construction and it works fine.
The slots can work from 30mm to 69mm. This will give trouble with some long protected batteries.
supportedBatteryTypes
supportedBatterySizesDSC_0950DSC_0948
DSC_0947DSC_0949DSC_0951
The charger can handle 69 mm long batteries including flat top cells.
Measurements
  • When not connected to power it will discharges with about 0.1mA (0.2 on usb slot).
  • Below 1V the charger will not detect a battery
  • Between 1V and 3V the charger will charge with about 150mA to 50mA
  • Above 2V the charger will use regular charging.
  • At 2A only the center slots can be used.
  • Batteries below 2.5V will not show correct on voltmeter (I often saw 1.64V).
  • Above 2.6V the meter is within 0.02 volt.
  • Charger will restart when voltage drops slightly.
  • It will restart charging on reinsertion of the battery or power cycling.
  • Power consumptions when idle without battery is 0.3 watt (0.2 with display off)
Efest%20LUC%20V4%201A%20%28SA18650-33%29%20%231
The charger use a CC/CV charge curve with termination at about 60mA, this looks fine.
Efest%20LUC%20V4%201A%20%28SA18650-33%29%20%232
This battery is more used and charger has problems terminating.
Efest%20LUC%20V4%201A%20%28SA18650-33%29%20%233
Efest%20LUC%20V4%201A%20%28SA18650-33%29%20%234
Fine termination on these two cells.
Efest%20LUC%20V4%201A%20%28SA18650-26%29%20%231
Efest%20LUC%20V4%201A%20%28PA18650-31%29%20%231
These two cells looks fine.
Efest%20LUC%20V4%200.5A%20%28SA18650-33%29%20%231
Charging at 0.5A also looks fine.
Efest%20LUC%20V4%200.5A%20%28BE18650-26%29%20%231
I did this old cell at 0.5A at it charged perfectly.
Efest%20LUC%20V4%200.5A%20%28KP14500-08%29%20%231
The smaller cell also charges perfectly.
Efest%20LUC%20V4%200.5A%20%28AW18350-IMR%29%20%231
This very old cell is problematic, it looks like the charger has problems adjusting the current low enough.
Efest%20LUC%20V4%202A%20%28SA18650-33%29%20%232
2A requires good IMR cells to get a perfect termination on this charger, I did not use that here.
Efest%20LUC%20V4%201A%20%284xSA18650-33%29
The charger can do 4 cells at 1A.
Efest%20LUC%20V4%201A%2012V%20%284xSA18650-33%29
This requires about 1.8A from the power supply.
Temp4494
M1: 42,9°C, M2: 42,8°C, M3: 43,5°C, M4: 44,7°C, M5: 44,9°C, HS1: 60,1°C
Temp4496
M1: 42,0°C, M2: 42,0°C, M3: 42,7°C, M4: 43,3°C, M5: 38,6°C, HS1: 49,6°C
Efest%20LUC%20V4%200.5A%20load%20voltage%20sweep
Efest%20LUC%20V4%202A%20load%20voltage%20sweep
Sweeping the battery voltage from zero to 4.25 shows charge current at the different charge levels.
I did also add a curve to show how much heat is generated in the charger, most of the time the voltage will be between 3.5V and 4V, i.e. a bit above 4 watt.
Poweron
The charger is a bit slow to start with 4.5 seconds. The current regulation works in in steps and takes a few seconds to find the correct charging current.
CurrentChange
Charge current can be changed at any time, again the charger needs some time to adjust the current.
USB output
  • Output will turn off after 10 seconds when load is below 100mA
  • USB output is coded as Apple 1A
  • Usb output will turn off when charger is powered.
  • Only slot #2 will supply current to usb output
  • Will discharge battery with 0.2mA when usb output is off
Efest%20LUC%20V4%20load%20sweep
Nearly 1.5A before over protection kicks in, this looks fine.
Efest%20LUC%20V4%20usb%20out%2010ohm%20%28SA18650-33%29
Stable output voltage until the battery is nearly empty and then it turns completely off, this is also fine.
But I would have like it to used a bit power energy from the battery, it turns off at 3.3V, using 3.0 would have given slightly more energy.
Efest%20LUC%20V4%20usb%20out%205ohm%20%28SA18650-33%29
The boost converter is strong enough to maintain output at full 1A current.
10ohm
At 0.5A the noise is 4mV rms and 51mVpp
5ohm
At 1A the noise is 9mV rms and 93mVpp, this is very low.
Conclusion
The charger is a fairly good LiIon charger, but it has some problems with termination on older batteries.
Usb output is fairly good, but it uses a old coding and current is a bit low for a smartphone.
Notes
The charger was supplied by Efest for review.
My website with reviews of many chargers and batteries (More than 1000): http://lygte-info.dk/
Splott-Light
Splott-Light's picture
Last seen: 2 hours 49 min ago
HKJ,
Thanks once again for all your efforts in enlightening us!
Cheers,
S-L Smile
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
MRsDNF
MRsDNF's picture
Last seen: 3 hours 31 min ago
Thanks HKJ. Thumbs Up
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
