New ReyLight LAN available soon
57 posts / 0 new
WWEFANS
WWEFANS's picture
Last seen: 1 hour 57 min ago
A little changed on the body. price 59$
PP/Email: 395090663@qq.com
4000K Nichia 219C high CRI.
Output (AA battery)
Moonlight mode: 0.2 lumens, 30 days
Low mode: 2.5 lumens, 60 hrs
Mid mode: 23 lumens, 4.5 hrs
High mode: 110 lumens, 50 min
Output (14500 battery)
Moonlight mode: 0.2 lumens, 20 days
Low mode: 6.5 lumens, 30 hrs
Mid mode: 81 lumens, 2.2 hrs
High mode: 390 lumens, 40 min
Operation:
Click to turn on, tap to cycle modes.
Click again to turn off.
Starts at moon by default.
Edited by: WWEFANS on 08/31/2017 - 12:12
DavidEF
DavidEF's picture
Last seen: 5 hours 36 min ago
It looks like a nice light. I see you used style elements from some of your other lights on this one.
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
fonfan
Last seen: 3 days 3 hours ago
Always start in moonlight is annoying idea.
WANTED Zebralights. My flashlights
doubleone44
doubleone44's picture
Last seen: 16 min 2 sec ago
Disagree, I think it is a great idea as you won’t blind yourself in the middle of the night.
However, an ever greater idea is to offer both with and without memory mode using (publicly available) advanced software!
Sledgestone
Last seen: 1 day 1 hour ago
Why the design change? It looked good the way it was!
Atom00
Last seen: 1 week 2 days ago
Im looking forward for a brass or copper version. Big Smile
DavidEF
DavidEF's picture
In theory, I prefer my lights to have mode memory so that I can set it where I want it. But, in reality, I nearly always use the shortcut to Moonlight and go up from there when using my Olight S1A Baton. I never use the mode memory.
-Ayn Rand
mattlward
mattlward's picture
Last seen: 2 weeks 12 hours ago
For me, in this size light and always running LSD NiMH cells, starting in moonlight is perfect!
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Olight S1A
Olight S1R
DooMMasteR
Last seen: 2 days 21 hours ago
Is it made of Titanium if yes… drooling
Trevi_lux
Trevi_lux's picture
Last seen: 7 min 19 sec ago
Nice, but I need better perfomance for the AA NiMH……
WWEFANS
WWEFANS's picture
Yes.
DooMMasteR
Then count me in, I take one.
fonfan
List started? I’m in.
WalkIntoTheLight
Last seen: 1 hour 22 min ago
I like my Reylight Pineapple, and this light seems to be the same internals but a different body. But, yes, I wish the output on AA was a bit greater. I know you’re not going to get high output from a AA light with a Nichia 219 LED, but 200 lumens should be fairly easy. I guess they designed it more as a 14500 light.
jon_slider
Last seen: 9 hours 37 min ago
imo
200 lumens is not easy for a 1.5v battery.
for an AA or AAA light w Nichia, a 110 lumen high is normal and reasonable
any AA light you can name that does more than that, does it for 3 minutes or less and then steps down
If you really need 200 lumens, step up to LiIon (3.7 volts)
this is in reference to the previous TiLan:
gunga wrote:
the middle and maximum levels use PWM for dimming (at a reported 9KHz for the frequency). I did … notice it …. I don’t know why it is used in max mode
My question is, does the new version still use the same PWM?
DooMMasteR
I also wonder how the buy will work, I have no Facebook, so I am out of it?
WalkIntoTheLight
The Manker T01 will do over 400 lumens on a AA, without any step-down (using one of the special modes that prevents the step-down). Granted, it does get hot, but it seems to handle it okay.
The Zebralight SC5 will do over 500 lumens, albeit with a 3-minute step-down.
I’m not sure what that power would translate to in a Nichia 219C, but it’s probably somewhere around 300 lumens. I’m happy with a step-down to prevent overheating.
But, yeah, that’s kind of leading-edge for 1xAA lights.
Anyway, I’m not really concerned, since I don’t use my Pineapple as a bright light. It’s used as a bedside light, and it does a good job in that function. I suppose I could use a 14500 to get the higher outputs, but I have other lights for that.
Good question, but I presume the answer is yes, because it doesn’t sound like this version has changed the driver. The Pineapple has PWM on all modes. It would benefit from using higher frequency PWM, if it can’t go constant-current.
djozz
djozz's picture
Last seen: 36 min 31 sec ago
It is only a few manufacturers who manage to make good boost drivers for AA cells, and of them Manker is the most affordable. The new Manker E03H AA-headlamp manages to get 240 lumen from a 90+ CRI 4000K 219C (350lm for a cool white XP-L). I doubt that it runs on a 14500 btw, the specs do not mention it.
jon_slider
I agree, different lights fill different niches. The LAN does a very good job of offering both High Lumen or High Runtime options
WWEFANS wrote:
I think it is a very good looking light, and has a lot going for it, including being dual compatible w both Primary and LiIon power. I especially like that the moonlight stays at the same low level on both types of power. The PWM helps maintain consistent High CRI Tint, all good things. I like the trit options too..
I also like the teardrop design elements in the head, a bit like the LunaSol
the head also reminds of Muyshondt Aeon. The TiLan also shares a body design element similar to the Flieger..
Imagine owning a titanium light, not for $600, not for $400, now you can have it for less than $100! Buy more than one Smile
Trevi_lux
Trevi_lux's picture
My last AA lights are Utorch UT01, Manker E11, Klarus Mi7, zebralight SC5 MK II, EagTac D25A, Olight S1A…. sorry, but I do not think that 200 or around 180 lumens are strange thing…and not for only 1 minute…. 110 lumens is fine for a flashlight AA NiMH of 3 or 4 years old…but not for 2017….. and for 100 lumens now we can see without problem 2 hours or better…
Ok, we can not hope the same data for nichia, but I think that will be great better perfomance.
(In any case I have bought one of the Rey Light brass, and I love it… )
DooMMasteR
When getting a lot of power from such a light, you should also consider the thermal properties of titanium which are a lot worse than those of aluminium.
At least a continuous power of ~2-3 Watts seems to be the limit, 3-4 Watts would be too much for such a design in titanium.
tempo
Last seen: 7 hours 9 min ago
This is probably the best AA Titanium light out there!!
Trevi_lux
Trevi_lux's picture
Yes is one possibility…or perhaps is this
You will have to try both to make sure …. Wink
tempo
@Trevi
Could you please make a full review of TiLAN?
james y
Last seen: 12 hours 9 min ago
I am interested too. Do you have access to some trits and options to put some on as your previous lights?
DooMMasteR
I already contacted OP, but so far the buying process seems “grey” to me Sad
WWEFANS
WWEFANS's picture
You can paypal to 395090663@qq.com
hunter1
hunter1's picture
Last seen: 5 days 23 hours ago
Just got the new LAN v2.0 in house here now.
I got the bead blasted version, nice and grey.
It is a little longer – 3,5mm than LAN v1.0 and 3,3g heavyer.
The LED, Nichia 291C 4000k, is a little more warmer than the LAN v1.0.
DooMMasteR
Mine is on its way, I expect it to be held by customs, but hey. 3-4 weeks at least.
WalkIntoTheLight
Is the battery tube the same diameter as the Pineapple? One thing that bugs me about the Pineapple is that it can’t take my Keeppower 14500 cells. They’re too thick. The battery tube is just wide enough to accept Eneloops, or unprotected 14500’s.
Since I’m not sure if the light has proper low-voltage protection, I’m reluctant to use unprotected 14500 cells in it. So, I’m stuck running it on AA’s, which makes it under-powered by today’s standards.
WWEFANS
WWEFANS's picture
My nitecore and olight, xtar 14500 , protected, could work well. It does not have low voltage protection.
