Test/review of Ebat 20700 3000mAh E7-20P30 (Blue)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 8 min 22 sec ago
DSC_0342
Official specifications:
  • Model: E7-20P30
  • Normal voltage: 3.7V
  • Normal capacity: 3000mah
  • Charging voltage: 4.2V ± 0.5V
  • Discharging cut-off voltage: 2.5V
  • Discharge rate: 40A
  • Rechargeable: Yes
  • Size: 18±2mm Dia 70±1mm Length
  • Cycle life: > 500 times
  • Operation Temperature Range: Charge(0~45°C ) Discharge(-10~60°C )
Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-info
Ebat also have a battery in the new size 217100, capacity is not that high, but it can deliver lot of current.
DSC_0341
DSC_0343DSC_0344
DSC_0345
DSC_0346
DSC_0347
Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Capacity
The discharge curves looks good with nice matching between the two cells and nearly constant capacity at any current.
Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Temp-15.0
Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Temp-20.0
Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Temp-30.0
At 30A the battery gets warm, but not too warm, i.e. it can handle the current.
Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-CapacityTimeHours
Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Energy
Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-PowerLoadTime
Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-TripCurrent
Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Charge
Conclusion
This is a nice high current battery and the slightly large size compare to a 18650 can be seen on the improved performance.
This battery is mostly for people that needs well above 10A, for lower currents look at a 18650.
Notes and links
The batteries was supplied by EBat for review.
Compare to 18650 and other batteries
Compare to 26650 and other batteries
My website with reviews of many chargers and batteries (More than 1000): http://lygte-info.dk/
DavidEF
DavidEF's picture
Last seen: 21 hours 34 min ago
30A continuous is good. But, the 3000mAh capacity is a bit disappointing.
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
Henk4U2
Henk4U2's picture
Last seen: 1 hour 47 min ago
Thanks for your review. I always keep an eye open for them.
Especially when it concerns batteries with dimensions 20700 and 21700.
I always think long and hard before I say something really stupid.
will34
will34's picture
Last seen: 3 hours 45 min ago
Thanks for the review. Nice to see more 20700 batteries come to the market.
